Question about Kitchen Appliances - Others
Scotsman cme306 The freeze cycle is only 3min long then it tries to harvest ice.after that the red Refridgeation light comes on and it shuts down.
  • 958 Answers
SOURCE: Hoshizaki KM-450MAB Ice Machine
maybe not. it could be that the heating cycle is taking a lot of time to remove the ice from the evaporator that is why the electronics is shutting off the compressor as a protection. check the heating cycle if it is working fine. check the evaporator for dirt that would hold the ice slab from falling down quickly. check the level of the unit. it may have move and now its out of level. the unit must be leveled with the ground.
Posted on Feb 21, 2008
  • 202 Answers
SOURCE: ice sheets too thick to shatter when dropped
timer not working properly replace if necessary
Posted on Jul 24, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: cme256 scotsman ice machine
Clean the bin eyes found in the back of the ice machine where the shoot narrows. Look on the left and right sides of the unit, you will see plastic vanes that are pushed into rubber grommets. Just pull the eyes out and clean with ice machine cleaner.
Posted on Apr 21, 2010
  • 112 Answers
SOURCE: Scotsman cme 506ae-1a harvest to soon. Where is
The water float rod in front of the unit serves as the fill stop as well as the harvest initiate. Difficult to remove to clean really well but not impossible. Harvest time is handled by the controller. First two or three harvests are long as the controller times out the harvests based on the blinking light of the bin full indication. After that is should get shorter.
Posted on Dec 11, 2010
SOURCE: hi.my scotsman mv 450 ice machine harvest cycle is
hi i have mv 1000 scotsman my problim is very early in harvest if i pull ice sensor connector in the mudule the unit is making ice after 20 min i put again the ice sensor in the module so that i can harvest the ice.
somebody could help me this problim?
Questions
1.is my ice sensor basted?
2.there is wrong with my module?
3.can i adjust in the trimer?
Posted on Aug 18, 2011
Scotsman icemachine constantly freezing up no matter how small you put the setting?
Max harvest cycle just keeps it in a harvest longer. if you set the freeze setting to its lowest point and ice is still to thick then replace the freeze stat.
Feb 22, 2015 | Scotsman Ice Machine, Cuber, 1930 lb....
Why does my cme306 scotesmen go into the harvest cycle in just 40 sec. of starting up
The first thing it does after a failure or power disruption is go into a harvest cycle.It will be a prolonged cycle at the first start . then it should operate normally
Jun 28, 2014 | Scotsman Cooled Modular Contour Cuber Air...
WHY scotsman iec machine shuts down on the refridgeration light ON CM3 CONT
Is the machine producing ice thick enough to come off the evaporator plate? the machine will try to harvest 3 times before it locks out on long harvest. Harvest cycle: The compressor and hot gas valve are both powered during the harvest cycle. The fan and pump are off at this time. The machine stays in the harvest cycle until the evaporator thermistor senses 52 DEG F. If the bin is not full, the unit goes into another freeze cycle. I would check the Thermistor
May 28, 2014 | Scotsman CSW45 15" Ice Maker with 26 lb....
Scotsman cme306
Ice thickness probe disconnected or faulty.
Mar 31, 2014 | Scotsman Freezers
Scotsman cme256 as-1d sticks in harvest cycle
The only thing that tells the machine that a harvest cycle has completed and takes it back into a freeze mode is the ice level control. when the machine go's into a harvest the ice drops through the ice level control and brakes the beam and switches the machine back to freeze cycle. Pull the the ice level controls and replace them. if there is nothing wrong with them than it is the electronic controller. part number for ice level controllers are 11-0540-21. The part number for the control board is 12-2838-24
Dec 07, 2013 | Scotsman Kitchen Appliances - Others
Ice machine harvest two times and shut off
These unit time freeze time and harvest times and keeps track of them. If your freeze time exceeds 35 minutes or harvest time exceeds 3 minutes, it will place unit in lockout. The biggest cause for excessive time to harvest is the harvest valve not functioning properly, and undercharged unit or a dirty condenser. The most probable cause is a dirty condenser. Under charged units can be determined by checking compressor outlet temperature while running, it should be 150 to 190 degrees depending on atmospheric conditions present. If it is harvest valve, the downstream temperature will stay at or near compressor discharge temperature. It should cool down to ambient temperature in a few minutes after freeze cycle begins.
Nov 25, 2013 | Scotsman Ice Maker 600LB CM3 30inW...
Low ice output
Low ice production has multiple causes. First check condensing coil to see if they are dirty and not passing air. This is the most probable cause for low ice production. Next, measure freeze cycle time and harvest time. Freeze time is typically 20 to 30 minutes and harvest time is normally 1.5 to 3 minutes. If freeze time is long (> 35 minutes), first check water valve shuts after reservoir is full. If it does not shut off the water solenoid operated valve needs replaced. Second, find the harvest solenoid operated valve which branches off the compressor discharge and port high temperature gas into evaporator during harvest and see that evaporator side of harvest valve cools down to surrounding temperature in a few minutes 8 - 10 after freeze cycle starts and harvest time stops. If it does not cool off the valve is leaking by its seat and will require a technician to replace. Lastly, if long freeze cycle could be due to low refrigerant and will require and tech to charge properly. Ice machine are critically charged and a tech will know how to charge the right amount. Again, it is possible the metering device is not passing enough refrigerant and a technician can determine this by checking the superheat and subcool. Low subcooling <3 and a high superheat >20 typically indicate an txv (metering devise) needs replaced and will require a tech to replace.
Oct 13, 2013 | Scotsman Ice Machine - 290lb...
Scotsman cme306
Here video. Was long freeze error. found out that it was bad ice thickness probe. Hope this helps to someone
May 21, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman ice maker cme 506 makes ice and turns off and blinks refrigeration
First check to make sure condenser fan is running during freeze cycle. Now check to make sure condenser coil is clean. Her is all the specks on the machine.
1. Ice production ( 500 at 70/50
2. BTUs per hour ( 7000)
3. Maximum times in Minutes. ( 50 freeze, 14 harvest.
4. Refrigerant charge ( R-404A ) ( A-D series: AC 32oz, WC 20 oz. E series AC 23 oz, WC 14 oz, F series AC 23 oz, WC 13 oz
5. Suction pressure ( PSIG ) 35-37 - end of freeze, 120-125-Peak in harvest.
6. Discharge pressure ( PSIG ) 240-260- 5 min in freeze.
165-175- minimum in harvest.
7. Metering device.( TXV plus distributor, E series and higher have two TXVs. superheat 3 to 15 deg F.
8. Average comp.amps. 10-11 during freeze, 11-12 during harvest.
9. Batch Weight. 6.5-7 lb
10. cycle time, 23 minutes @ 90/70. 19 minutes @ 70/50
Feb 24, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman dc33pa ice maker
Make sure the curtain is not torn and there are no leaks from the resivoir. If ok check to make sure you have enough water pressure to the machine. Make sure you have enough water passing through the valve during harvest cycle. To check... turn the timer cam to harvest cycle. Water should come in quickly behind the curtain on the right side and the timer should advance three minutes to freeze portion of cycle and stop running. Water should spray and form ice for approximately 25min. Then the timer advances for 5 minutes into harvest cycle and it refills with water again.
Nov 21, 2007 | Scotsman CSW45 15" Ice Maker with 26 lb....
Kitchen Appliances - Others Logo
46 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
