Question about Gemmy BIG MOUTH BILLY BASS THE SINGING SENSATION
Big mouth billy bass head wont move - Gemmy BIG MOUTH BILLY BASS THE SINGING SENSATION
    Problem Solver:
  • 9 Answers
Gear most be cracked try gluing it
Posted on Sep 27, 2014
2 Suggested Answers
SOURCE: Our Singing Bing Crosby Santa doesn't move his
I have had the same trouble. I had to take his head apart and there is a string that is attached to the motor that works his mouth. The string has come unattached and needs fixed. The head is put on with a type of staple around the neck.Take them out and you will see what I mean.
Posted on Jan 16, 2011
Big mouth billy bass no audio
it should sound like this and the speaker must be dead or the wires are dead
Feb 13, 2013 | Gemmy BIG MOUTH BILLY BASS THE SINGING...
What bait should I use to catch small mouth bass?
Crayfish is probably the most useful bate because small mouth bass love them.
Jan 14, 2013 | Fishing
Dean sings his arms and body move but his mouth does not i saw that someone replace d the string is there a diagram to show the workings of the doll
slide tux collar down and find 4 staples in neck, with small flat screwdriver work stales from neck, they are quite long and it takes some time. then with thumb under mouth at chin, gently wiggle and pull owtwards until mouth slides from head, mouth must be removed before head will lift from neck. once head removed, you will see drive motor near top that drives mouth. there should be a smoll nylon string connected to small plastic wheel on end of this motor, most times the adheasive that hold this string in place has let loose and string is still in tact. before reconnecting press activation button and be sure motor is spinning, if so simply reconnect string to plastic end, and reassemble head I used 2 part epoxy (JB Quick) Note if motor is not turning when activated then this too needs repaired
DW Mylin.
Sep 28, 2012 | Gemmy Bing Crosby Big Head Doll
Mouth does not move
Motor operating mouth assembly is bad. The process to remove it is tedious and the motor is specific to the design. This was a common problem with all of the motors in this series. Especially the one operating the mouth. The input pulsing necessary for the mouth to move, was to abusive to the motor, and subsequently shortened its life.
Dec 18, 2011 | Gemmy Bing Crosby Big Head Doll
MOUTH IS NO LONGER MOVING
probably it needs some serious spanking :)
Jan 25, 2011 | Gemmy Bing Crosby Big Head Doll
Our Singing Bing Crosby Santa doesn't move his mouth any longer, but his head and microphone still move while he's singing. Can we get his mouth repaired somewhere????
Dec 14, 2009 | Gemmy Bing Crosby Big Head Doll
Gemmy Santa Bear mouth does not move
I would like to first tell you what the problem is with either your Bing or Bear head. Inside the head is a motor that works the mouth. On this rotating motor is a pulley type system, which has a twine or you could call a heavy string piece. It is attached to the motor, and when the is activated it rotates the thread round the spindle on the motor and the mouth operates.. It is quite a difficult to take this head apart. I worked on my Bing for some time to find out this problem.. The string comes away with use and of course time, that is is why the mouth no longer moves. If you wish to try and repair, you first have to remove the head from the base. If you look there are 4 heavy duty staples just round the collar neck area. They will come out with a small head screwdriver or something pointed. Just work it slowly under till staple raises up, then just pull it out. Once they are all removed the head should be loose. This is only to give you access to seeing the internals firstly. Now comes the hardest part. The soft moving part of the mouth needs to be removed. You need to work it of slowly as there is a glue base on it, so care is needed here and can take time. If you managed this all is left is the metal pin it was on. Now inside is the plastic unit that moves the mouth this is glued in which is the main problem. And this is the issue, it is pushed on and the only way is to remove is to have a precision head screwdriver and work it off... Best done by someone who is quite good with their hands and very patienced. Because it may break. Took me severals hours to remove. When you get it off the internal workings will come out of the head. There is no other way of doing this. Having the head loose allows you to look at the piece and the workings. A small torchlight held by someone is best as you work out the mouth fitting.....As i said it is no easy job and took me long periods of time to get to this point. I wish you all the luck in achieving this.......
Dec 15, 2008 | Gemmy Rocky Balboa Big Head Animated...
Gemmy BIG MOUTH BILLY BASS THE SINGING SENSATION Logo
184 people viewed this question
Top Gemmy Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Gemmy Toy Expert? Answer questions, earn points and help others
