Question about Keurig B31/K10 Mini-Plus Personal Coffee Maker - White
K10 keurig makes buzzing sounds when brewing - Keurig B31/K10 Mini-Plus Personal Coffee Maker - White
SOURCE: keurig turns off after making only one cup, when
I just solved this problem with my Keurig Plantnum. It seems that the valve that lets the water in is sensitive to clogs or sticking. Or perhaps like me, you have very hard water and calcium is starting to build up. Anyway, what worked for me was filling the resevoire all the way and turning the unit on. Then while the pump was buzzing I lightly jiggled the reseviore and all of the sudden the water level started to go down.
Posted on Jan 25, 2010
  • 60 Answers
SOURCE: The Keurig is heating up the water, yet is does
Descale, Clean out the needles with an unfolded paper clip, Take out the K cup holder and clean it out
Posted on Mar 23, 2010
vetteman3002
  • 2299 Answers
SOURCE: Problem with the Keurig Elite
Keurig is having a big problem with this. When you turn it on, pick up the reservoir and place it back down. What you are hearing is the unit trying to pull the water through and it won't. It will try for a minute and then shut itself off. So power on, lift and lower water unit and it should be good. CALL KEURIG and tell them about the problem. If enough of us call then maybe they will do something.
Posted on Oct 27, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: keurig coffee maker makes loud noise single cup
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Posted on Dec 21, 2010
heatman101
  • 43501 Answers
SOURCE: My Keurig b40 brewer is not brewing. When I turn
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
llllllllllll;
Posted on Feb 26, 2011
Why won't it brew?
Have you cleaned the two little holes in the head?
Mine quit working and I used a paperclip, straightened out, inserted into each hole then ran a cup through, inserted paperclip again, ran another cup of water through, then it worked like new again. These little holes get filled with coffee grounds as they punch through the top of the pod, this is where the water comes out to make your coffee. I now clean these two holes every 3 months or so. Keeps it working beautifully!
Nov 25, 2015 | Keurig K10 K-cup Mini Plus Coffeemaker...
Keurig troubleshooting
Is there water in it? There probably is so the next thing to try is to lift the tray and close it again after the machine is ready to brew. This resets the brewing function. Good luck.
Aug 07, 2014 | Keurig K10 Personal Coffee Maker w/ 30...
Keurig k10 stops
there is not enough water
Aug 03, 2014 | Keurig B30 Mini Coffee Maker
Keurig K10 water spills out top and sides while brewing
Check to make sure the rubber gasket is still on the water output in the brew head. It goes around the water output needle in the top of the brew head. Without that gasket, there is no seal on the top of the k-cup and water can leak. Run it with no K-cup in it and see of water does not leak this way. If it doesn't leak then it points to a missing seal. Hope this works for you.
Mar 22, 2014 | Keurig Coffee Makers & Espresso Machines
My K10 MINI Plus keeps shutting off by itself
The shut down may come from a safety standpoint, whereby if a heater gets too hot, lines get plugged, or chambers are not filled with water as necessary; the unit could shut down accordingly. Try to clean the ports/lines/ and cup holder. Fill water to line (Not Over the line) and descale to clean the interior chamber.
Feb 19, 2014 | Keurig K10 K-cup Mini Plus Coffeemaker...
I have a K10 mini cup keurig brewer. It worked fine until this morning. When I try to brew a cup, it comes out the top. It does with this with or without a k-cup in. I tried to clean out the needles...
First: You need to check a Upper Rubber Gasket (fits around the top puncture pin). If it missing you will have leakage because here's no seal to protect leakage. You can buy it online or call Keurig Customer Service (if you still have warranty)
Second: Upper Rubber Gasket not making a seal with the K-Cup or Reusable Filter and the water and/or coffee grounds leak out. To fix it simply move Upper Rubber Gasket 1/4" down. This should close the gap between K-Cup and upper needle.
Oct 27, 2013 | Keurig Coffee Makers & Espresso Machines
When I brewed coffee from my Keurig mini k10 brewer, the coffee came out of the center and the side (spilling coffee into the drip pan) but the resevior was not overfilled and the coffee was not finished...
Sometimes things can build up on the inside of the machine, even though you may have only had it for a short period of time. You should try cleaning it to make sure nothing is clogged in the filters.
Oct 14, 2013 | Coffee Makers & Espresso Machines
Keurig turns off after making only one cup, when turned bsck on, it makes a loud buzzing sound for a few minutes, then shuts off again (during this buzzing, always says "not ready", never gets back to...
Jan 23, 2010 | Keurig Coffee Makers & Espresso Machines
Keurig B31/K10 Mini-Plus Personal Coffee Maker - White Logo
65 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
