Question about Breezaire WKL-2200 Wine Cellar Cooling Unit Max Room Size = 265 cu
Breeze air wkl 3000 blinking temperature al - Breezaire WKL-2200 Wine Cellar Cooling Unit Max Room Size = 265 cu
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 50 Answers
NEW UNITS HAVE A VISUAL ALARM PRE SET TO KICK ON AT 62 DEGREES OR ABOVE, WHE THE WINE COOLING UNIT READS 62 OR ABOVE IT WILL FLASH "AL" AND THE TEMPERATURE NUMBER THAT FORVED IT TO KICK ON, IT IS JUST A VISUAL ALARM IT WILL NOT TURN UNIT OFF OR STOP IT .
THIS FEATURE WILL SHUT OFF ONCE THE UNIT READS ANY TEMPERATURE BELOW 62 DEGREES.
Posted on Jul 21, 2014
WK[L] 3000 unit can not change the set temperature. It is stuck on 64 degrees. The unit continues to run and the temperature shows 55.
IVE SEN THIS ISSUE BEFORE
THE FACT THAT YOU CANT CHANGE THE SET COOL POINT ON THE UNIT BELOW 64 IS A SYMPTOM OF A DAMAGED CONTROL BOARD (SENTRY III), NOW THE UNIT CONTINUING TO COOL DOWN BELOW THE SET COOL POINT OF 64 AND GOING ALL THE WAY DOWN TO 55 IS MOST LIKELY THE RELAY.
I HAVE FIXED THIS EXACT SAME ISSUE BY REPLACING THE CONTROL BOARD AND RELAY ON THE UNIT.
Sep 23, 2014 | Breezaire WKL-3000 Wine Cellar Cooling...
Al 1217 error code H3
Heat roller abnormally high
temperature
Check the heater lamp blinking
with SIM 5-2.
When the lamp blinks normally:
Check the thermistor and the
harness. Check the MCU PWB
thermistor input circuit.
When the lamp lights up instead
of blinking:
Check the lamp control circuit of
the power supply PWB and the
MCU PWB.
Clear the trouble with SIM 14.
May 07, 2014 | Sharp AL-1217 Copier
Wont run. It blinks
YOUR UNIT WKL 4000 CONTROL BOARD HAS THE FOLLOWING FEATURE ON START UP UNIT WILL RUN FOR 30 MINUTES IF IT DOENST BRING THE TEMPERATURE IN THE CELLAR BELOW 70DEGREES IN THAT TIME IT WILL SHUT OFF AND DISPLAY E1, YOU NEED TO UNPLUG UNIT FOR 15 MINUTES(NO LESS THAN THAT) AND THEN PLUG IN AGAIN IT WILL RUN AGAIN FOR ANOTHER 30 MINUTES ABD IF IT DOESNT BRING THE TEMPERATURE BELOW 70 IT WILL SHUT OFF AGAIN.YOU WILL HAVE TO REPEAT THIS CYCLE TILL IT GOES BELOW 70DEGREES (MOST CUSTOMERS WILL HAVE TO DO THIS CYCLE TWICE).ONCE THE UNIT BRINGS THE TEMPERATURE BELOW 70 IT WILL RUN NON STOP TILL IT MEET THE SET COOL POINT.IF YOU REPEAT THIS STEP SEVERAL TIMES AND THE UNIT NEVER BRING THE TEMP BELOW 70 DEGREES THERE HAS TO BE SOMETHING ELSE GOING ON, LIKE A REFRIGERANT LEAK.CHECK THIS LINK FOR THE INSTRUCTIONS THAT EXPLAIN THE FEATURE I TALKED ABOUT AND OTHERS ON THE CONTROL LER OF YOUR UNIT(SENTRY III)http://www.breezaire.com/downloads/sentrymanual.PDF
Sep 15, 2012 | Breezaire WKL 4000 Wine Cooler
This unit is 15 years old and the drain tube was never hooked up believe it or not and it leaked terribly with now a rusted out bottom. The unit works however and I was wanting to fix it. Can a new...
IF YOUR UIT IS IN FACT 15 YEARS OLD IT CAN NOT BE A WKL MODEL, WKL ARE DIGITAL UNITS, WHAT YOU HAVE IS A WK4000 WITH A SCREW TEMPERATURE ADJUSTMENT IN BETWEEN THE GRILLS.
A 15 YEAR OLD WK 4000 IS AN R-22 SYSTEM AND NOT WORTH REPAIRING AND IF THE METAL IS RUSTED YOU CAN NOT BUY MORE METAL BASES FOR THAT UNIT FROM THE MANUFACTURER, BREEZAIRE HAS DROPPED ALMOST ALL THE COMPONENTS FOR THE UNIT ONLY THINGS AVAILABLE ARE FANS,COILS AND THERMOSTAT.
BUY THE REPLACEMENT WKL4000 DIGITAL SAME DIMENSIONS AND COOLING CAPACITY.
http://www.breezaire.com/wp-content/uploads/2011/04/WKL-Insrructions-3-11.pdf.pdf
CHECK THE LINK FOR THE INSTRUCTIONS ON THE NEW WKL UNITS
Sep 19, 2011 | Breezaire WKL 4000 Wine Cooler
WKE 3000 temperature panel has stopped working - unit still turns on and off properly.
IF YOUR UNIT IS A WKL IT SHOULD HAVE A SENTRI III CONTROLLER(BOARD) THAT HAS A LCD DISPLAY GREEN NUMBERS ON IT WITH BUTTONS(SET, WARMER, COLLER) IF SO THE ONLY OTION IS TO REPLACE THAT BOARD, A VERY SIMPLE PROCESS 10 TO 15 MINUTES MINIMU TOOLS, CONTACT BREEZAIRE AT 858-566-7473 THEY WILL SELL YOU A BOARD OR CONECT YOU WITH A DEALER TO BUY THE REPLACEMENT BOARD ARROUND $150 APROX
Nov 11, 2010 | Breezaire WKL 4000 Wine Cooler
Unit runs but does not cool.
IF YOU UNIT IS IN FACT A WKL UNIT(DIGITAL DISPLAY) IT COILD BE TWO THING A BAD BOARD THAT IS NOT SENDING POWER TO THE COMPRESSOR OR A FREON LEAK.
ON MAJORITY OF CASES ON A FREON LEAK THE UNIT WILL FORM ICE ON THE COIL, SOME TIMES A LOT OF CONDENSATION ON THE BODY OF THE UNIT AND IT WOULD LOOSE COOLING GRADUALLY UNITIL IT WOULD RUN NON STOP.
CONTAVTTHE MANUFACTURER FOR A BOARD OR ASK FOR A TEMPERATURE DIFERENTIAL TEST TO CHECK FOR A FREON LEAK.
Oct 25, 2010 | Breezaire WKL 4000 Wine Cooler
WKL 3000 is creating excessive condensation and icing on the bottom of the unit. It is about 13 years old.
There will always be condensation. The problem may be that the drain that carries the water off is partially plugged.
Sep 20, 2010 | Breezaire WKL 4000 Wine Cooler
Radiator fans not working on 96 plymouth breeze
Its either of the following. ECTS(Engine coolant temperature sensor), Radiator Fan Motor, Radiator fan Relay, or possibly a wiring issue that leads to the radiator fan.
Apr 16, 2009 | Mustek DV-3000 Digital Camera
Blinking blue light on ionic breeze s1871
Wher can you return it? Does anyone have and address? My Dads unit has a blinking blue light and the folks at sharper image say to bad so sad only after 2 months out of warrenty. Is there any one out there that can help? I am done buying things from Sharper Image with their attitude! hlaytos@aol.com
Mar 22, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
Breezaire WKL-2200 Wine Cellar Cooling Unit Max Room Size = 265 cu Logo
234 people viewed this question
Top Breezaire Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Breezaire Furniture Expert? Answer questions, earn points and help others
