Question about Lands Phones
Garfield Phone will NOT dial out.
I have a TYCO wired Garfield Phone and I can call the phone and it will answer with no problem. When I pick it up to dial out there is a dial tone but as soon as I push any one of the numbers(or even if I push all the numbers), I lose the dial tone and then I get a operator message telling me to ''try again, or ask for operator assistance''. So it is not dialing out properly.
LR40992 is the part number for the pulse dial IC. This particular IC is not getting any power to pin 1 or any of the other pins.
Do you know of any telephone schematics that I could possibly get that might help me out to figure out this problem. Or perhaps might you have any ideas?
Thank You for taking the time to read this.
Jerry W
Where can I get a cell phone repaired in Garfield Heights, Ohio 44125?
Hello, Go to this website for names, addresses and phone numbers for phone repair in Garfield Heights , Ohio. Google
May 30, 2014 | Cell Phones
How to recieve a fax ?
If your printer is connected to a modem make sure that the port has a dial tone. To check for dial tone, try to plug in a phone to the same port that you printer is connected to. If it doesn't have dial tone, you might want to check with your phone provider. Or you can plug in the printer straight to a wall jack.
Once the printer is connected to a line that has dial tone, you can then setup the printer to receive faxes. To set it up, on the control panel of your printer, press on Setup > Fax Setup > Ringing and Answering.
If you have an answering machine, set your printer to pick up 3 rings higher than your answering machine. If not, set it to pick up on the 5th ring that way you will still have time to pick up the phone if it's a voice call.
If you have a voicemail service from your phone provider, you'll need to contact your phone provider to get a distinctive ring feature. Once you'll have that feature, you can assign a distinctive ring to your printer. You can find that under Fax Setup > Ringing and Answering > Ring Pattern.
May 29, 2012 | Lexmark Interpret S405 Wireless All-in-One...
No dial tone
  • First, try to check every telephone line is properly plugged into its phone jack. If you have a problem with just one phone, plug a different phone into that jack. If the second phone works, the problem lies in the first phone.
  • Then unplug each phone and answering machine in your house, one at a time. Wait 30 seconds after unplugging the first device. Pick up another phone to see if there's a dial tone -- if there is, then the first phone may be faulty. If not, continue unplugging phones in the same way and check for dial tone. If you find a phone that doesn't work, plug all your other phones back in and see if they work properly. The faulty phone should be replaced.
  • or disconnect the plug from the test jack inside the exterior box. This disconnects your inside wiring from phone company's line. If you have more than one line, select the test jack for the line that is causing the problem. Plug your phone into the jack; this plugs you directly into the phone company's line. If you have a cable modem, plug the phone directly into the jack on the modem.
  • Then pick up the phone receiver to see if there's a dial tone. If there's no dial tone, the problem is with your outside wiring. If there is a dial tone, the trouble is caused by your inside wiring, equipment or jacks.
  • Hope it will help you. Thanks for using FixYa.
  • Oct 19, 2011 | Lands Phones
    We have a 4-line system in our office, but it is not working properly. For instant, when line 4 rings...it only comes into one of the phones. All lines are working properly with dial tones. If we would...
    Now here's a conflict. Does line 4 work on any other phone where it doesn't ring? You say all lines are working properly wiith dial tones, tnen you say you can't pick it up from another phone.
    I don't think these phones have "private lines", but the dial tone comes from the 2nd RJ-14 jack on the wall. On every phone, you could swap the plugs so that line 1 comes into line 3 and line 3 comes into line 1 (you'll lose the intercom) and see if you get dial tone on line 2 which will be the phone that works line 4. The point being to determine if you have a wiring issue or a programming problem.
    Carl
    Mar 21, 2011 | RCA 25423RE1 Phone
    I pick the phone up, no dial tone. Display says
    We called the phone company.....There was a problem up on the telephone pole. They fixed it, no charge.
    Jan 21, 2010 | Vtech Cordless 6041 Phone
    Exact same problem.
    Is this a system phone?
    It sounds as though your set is not programmed with a line appearance. and line preference is not set, this can be set for intercom, or a line or nothing when you pick up the phone. You can do a pick up code to answer until an appearance is programmed on your set.
    Aug 05, 2009 | Lands Phones
    How do you answer another phone in the office by using your own phone
    Ascertain from your system administrator the directed call pickup feature access code, this will allow you to pickup any ringing call as long as you know what ext number is ringing.
    Jul 11, 2008 | Mitel 5220 IP Phone
    Storing Speed Dial Phone Nmbers
    Emergency/quick dial numbers: Pick up handset, push store, enter the phone number (it will not call the number), push store again, Push A,B or C. hand up handset. Frequently called numbers, pick up the handset, push store, enter the phone number, push store again, push key pad 1, or 2, etc. for memory location. Hang up handset. How to change a stored number. just repeat the sequence. How to clear a stored number, repeat the storage skip step 3 (do not enter the phone number). How to correct an error while storing, just hang up and repeat.
    Feb 26, 2007 | GE Telephone pr521w
    Lands Phones Logo
    177 people viewed this question
    Top Lands Phones Experts
    Computer Repairing
    Computer Repairing
    Are you a Lands Phone Expert? Answer questions, earn points and help others
