Question about Eastern Tools & Equipment ETQ IN1800I 1,800 Watt 3.4 HP 4-Stroke OHV Portable Digital Inverter
Owners manual I am trying to clean the carb an I cannot get the carb off. I have taken off the 2 nuts that hold the air box and carb in place, that loosens off the parts, but there is still something fastening the bottom of the air box so that I cannot remove the carb. Can you tell me how to get this bottom fastener off? Thanks
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
No, you just have to dig into it further to find your issue. sorry but these generators I don't see very often. Like I've worked on 5 in the last 6 years yet they aren't all the same
Posted on Dec 28, 2013
Where do I put the carbeurator gaskets on husqvarna5521?
this link shows how to rebuild a carb. I suggest cleaning the jets before you try anything else, if you havent done so already. At the bottom of the carb there is a not that holds the bowl in place. Remove yhe nut and bowl. In the nut there are tiny holes, clean them out using a wire (bread tie will work) you can also use an air compressor, A shot of carb cleaner wont hurt. More often than not this is the cause of most small engine issues. How to Fix Lawn Mower Carburetor eReplacementParts com
Jun 15, 2014 | Husqvarna 160 CC Honda OHC Engine 21 in
Can,t get carb off to clean ETQIN1800i
There are two plastic nipples that are pressed into rubber grommets, just grab the bottom and pull straight out while wiggling the air box assembly. Make sure you pull the rubber fuel lines out of the way so that the air box cam come straight out. The resistance you are feeling is either the rubber grommets or the fuel lines in the way. I have had mine apart a dozen times!
Dec 28, 2013 | Eastern Tools & Equipment ETQ IN1800I...
The air cleaner fell off and the nuts that hold the air cleaner on also holds the carb. on
If the studs are there to hold it all in place then just buy the correct ( metric probably) nuts for it.
Dec 08, 2013 | Sunpentown 2,800 Watt 6.5HP Power...
Remove carburetors
remove air box , cables and pipes ! use and open ended 12mm spanner on the 4 bolts at the base of the carbs and they come off !
Oct 23, 2013 | Yamaha Motorcycles
Oil in the gas tank
Not a big deal. Im assuming this is a 4-stroke push mower and not a leaf blower.
Remove the air box cover, air filter, and air box back plate. Careful there is a gasket on the back of the backplate that if damaged the primer bulb wont work, part # 272653. Remove the fuel line from the carb and drain the tank. Using a 1/2 inch wrench remove the bowl nut from the float bowl on the carb, hold the bowl to the carb as to not break the gasket seal, drain the bowl and replace the bowl nut. If you tried to run the unit and oil is in the cylinder remove the spark plug ( clean the spark plug) and spray some carb cleaner in the hole and pull the starter rope several times to purge the cylinder. Reinstall the spark plug, reattatch the fuel line, install the air box back plate ( leave the air filter and cover off for now), add fresh fuel.
Take unit outside and start, you may need to give it a shot of carb cleaner in the throat of the carb to help it start. It may smoke, it may blow oil out the muffler. Let it run until it quits smoking ( usually around 5 minutes) . Shut it off and complete assembly. It should be fine.
Oct 05, 2012 | Toro Lawn Mower With Toro Power Tools
Will not start
hello sir, mower will not start or run, does it have good spark,good compression,or only runs on full choke,engine surges up and down, are you getting fuel to the engine if not try this, your carb. is clogged up here is what you can do for a simple repair and other things if you want to, you will need a new air filter,spark plug, oil, if you want to a new blade also ,sears has a mini tune up kit that you can buy. now for the carb, empty fuel tank, place mower on side to where carb is facing up place a rag under carb to catch excess fuel,remove the bowl nut and bowl careful of the gaskets,now spray carb cleaner in the small port holes in the carb steam in the middle of the carb until clean,now spray the bowl nut holes until clean there are three,after cleaning put bowl on the same way you removed it with dip towards front of float,put bowl nut in, now while you have mower on side drain the oil remove filler cap to drain,put pan under spout,mower holds 21 o/z of 30 wt oil,you can remove blade to get sharpened or put new one on,to remove blade put a pair of vice grips on the body where the blade can stop and not turn it is usually a 9/16 or 1/2 socket, put blade on add oil,add new and fresh gas,you should be good to go,hope this helps,what i am telling you here is what i would do if it was here in the shop,any comments welcome,thank you.
Feb 18, 2012 | Cub Cadet Garden
How dose the carboretor work
Feb 10, 2012 | Garden
Honda gx160 starts briefly, then dies
IF ENGINE IS EQUIPPED WITH NEEDLE
VALVE ON CARB TO REGULATE MIXTURE,
TRY ADJUSTING. PATIENCE, TRIAL AND ERROR WITH VALVE ADJUSTMENT WILL
PROBABLY GET YOU THERE.
Jun 20, 2009 | Honda 8 HP Engine
Starts runs min. or two then stops....
Go to toro.com then click customer care, then click manuals and parts. Type in model no. and download the owners manual. This should get you the spark and flywheel gap. Probably still something in the carb. Some orifices are very hard to find and to clean but they must be clean. Also check for dirt dopper nest in the muffler.
Apr 05, 2009 | Toro Lawn Mower With Toro Power Tools
How to remove carbeurator on honda gx 390
remove the wing nut on top of the air filter housing. remove housing. remove next wing nut over air filter. remove air filter and bottom of housing. next, remove the 2 nuts on those threaded bolts you saw. there is one more bolt that you must remove located between the air filter and the exhaust. now the carb can be removed. this is possibly going to be very difficult but trust me, it can, and must be done. the carb should slide off of those bolts once you break it free from the intake. get your pry bars ready but try not to break any of those plastic parts! good luck.
Jan 17, 2009 | Honda Pressure Washer PSI 3000
Eastern Tools & Equipment ETQ IN1800I 1,800 Watt 3.4 HP 4-Stroke OHV Portable Digital Inverter Logo
255 people viewed this question
Top Eastern Tools & Equipment Electrical Supplies Experts
Bernie Knutson
Bernie Knutson
Level 1 Expert
jhnolson
wadingriver
wadingriver
Are you an Eastern Tools & Equipment Electrical Supply Expert? Answer questions, earn points and help others
