Question about D-Link Xtreme N DIR-655 Wireless Router
Not able to configure and connect to internet using router
I bought a new WBR-1310 Dlink wireless router. Have been unable to configure or connect to the internet. Summary: 1> Have Windows Vista 2> Ran the wizard which comes with the router. 3> Wizard fails and complains that new router was not detected.(I reset, plugged/unplugged both modem and router but same error).4> Changed the router thinking it may be defective, but the new one also has the same problem.5>Tried connecting modem to WAN port,LAN port to laptop (after unplugging, wait for 30 sec, restart computer). 6> access the 192.168.0.1 webadress, page not found. Basically comp is not able to connect to wireless. Any help would be appreciated. Tried resetting, unplugging power supply, nothing helps.My wireless card works fine, as I can connect to other networks.Modem to computer works absolutely fine, so no problem with modem
  • 700 Answers
Manually configure the setting in your LAN, this could help.
Connect a LAN cable between LAN1 of your router then to the LAN port of your computer. Power the router.
Goto Lan settings, highlight TCP/IP, then click properties.
In your lan settings manually input IP address 192.168.0.52, Subnet 255.255.255.0, gateway 192.168.0.1
You can input also the DNS number of your IP.
Then open web browser type in the address bar 192.168.0.1. You should go straight thru router utility setup security log in.
This can also be set wirelessly. Leave comments if I miss something.
Posted on May 18, 2009
    Novelist:
  • 149 Answers
Try 192.168.0.0 which would be the default address to access your modem. This should allow you to go into the modem and adjust changes. I know on the bottom of my router there is an administrator default password that can e used to access the mainframe of the modem. Check out these features in there. I would start first by connecting via LAN again and then try to conntect to it via a WAN but again see if you can access the modem using the 192.168.0.0.
Have a Dlink wireless router, however I am unable to set up a wireless connection. ssid=unknown, additionally all other data other than p/n, s/n ip:192.168.0.1, pass=ADMIN. I have a wireless laptop, hp...
theres a couple of version of this router http://www.dlink.com/products/default.aspx?pid=WBR-1310&tab=3 I'm using the manual from here http://www.dlink.com/products/?tab=3&pid=WBR-1310&rev=WBR-1310
you should be able to loginto the router and setup the wireless - if you are not able to login - you may need to do a factory reset and then login using the default settings and reset up
a useful tool for detecting wireless networks is this http://www.xirrus.com/library/wifitools.php you can use this on the PC to see if the wireless is broadcasting, if you can detect it on the PC
Mar 18, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Error 103
Press in and hold the reset button on the back of the router. Connect directly with a patch cable and configure your wireless settings by typing 192.168.0.1 in address bar. Download the manual here:
Mar 08, 2010 | D-Link 802.11g Wireless Router WBR-1310...
I HAVE A DLINK WBR-1310 ROUTER WHERE DOES THE BLUW
Hi!
You can use any UTP cables. Here is how the connection would look like:
DSL -> DLINK WAN PORT
DLINK PORT 1(or any other ports) <---> COMPUTER
If the router is set to give out IP addresses automatically(DHCP), you should be able to connect flawlessly.
Oct 25, 2009 | D-Link 802.11g Wireless Router WBR-1310...
I have comcast cable net and D-link WBR 1310
Hi, forget about the USB connection since you wanted to use a router for your wireless connection. Contact Comcast asnd make sure they assist you in making your computer connect to the Internet using the ethernet connection because you are going to use the ethernet connection for the modem-router connection. Once your computer is online with the ethernet connection, you can connect your Dlink router to the modem and configure it for Internet connection. There will be more steps before you can use the wireless connection. Just make sure you can get online with ethernet connection first.
Jul 23, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Dlink WBR 2310 cannot connec to internet
Try to bypass the router and connect to your modem. Make sure you have Internet connection.
>If you have Internet connection. connect back your modem to the router.
>access the configuration page of your router.
>If you are given a specific IP by your Internet Service Provider, use that one.
>Login to your Dlink (type in on the address bar 192.168.0.1)
>Click Setup and Internet > Click on Manual Configure
>My Internet connection would be Static IP
>Type in your IP address, Subnet Mask, Default Gateway, Primary and Alternate DNS
>Click on Save Setting on top.
but if your Internet Service Provider did not provide you those informations
> Under My Internet connection Type choose DYNAMIC IP
>Click on Clone Your PC MAC address
>Click on Save Settings
>If it ask you to reboot, click on Reboot.
>At the very top click on Status
>Under Status look for WAN
>Under WAN look for IP address
>If you have values beside from zero it means you have Internet connection otherwise, call your dlink manufacturer for manual configuring your router for Internet connection.
Jan 30, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Dlink WBR 1310 error 109 internal error
Remove the CD setup. Try calling your Dlink Manufacturer to help you install the WBR-1310 manaully.
Jan 03, 2009 | D-Link 802.11g Wireless Router WBR-1310...
I forgot the username of dlink wbr-1310 wireless router
As an initial info try to do a hard reset on the unit, this process will restore the system into a original settings. you can find the reset switch on either on the left of right sight of your router.
or
you may visit this SITE to recover again your current password without erasing or removing the current settings made.
Reset Password.
Hope this idea helps you.
Thank you for using fixya.
Nov 20, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Dlink WIreless Router
refer to your router manual... you need to run a internet browser then at the address space type the address of your router...
usually it is 192.168.0.1.. then at that point you should refer directions to your router manual and ISP settings should alway with you...
Jan 21, 2008 | D-Link 802.11g Wireless Router WBR-1310...
How do I secure my dlink wireless connection?
Type 192.168.0.1 (you can type the router address if you have changed) and enter on browser's addressbar. Router's interface will appear.
Click on SETUP and Click on the WIRELESS SETTINGS at left side. on the page you will see the option of WIRELESS SECURITY by drop down menu you can choose the Security mode that you wish. here is the link for the emulator
http://support.dlink.com/emulators/wbr1310_revB/wireless.htm
Please post your question if you need further assistance
Good Luck
Jan 19, 2008 | D-Link 802.11g Wireless Router WBR-1310...
D-Link Xtreme N  DIR-655 Wireless Router Logo
367 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
