Question about Dryers
Samsung dv220ae thermostat
Runs but does not heat
2 Suggested Answers
  • 3074 Answers
SOURCE: our samsung DV220AE dryer wont
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Posted on Nov 26, 2010
Troubleshooting heating element on samsung steam dryer
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot or not heat at all. . If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Dec 10, 2016 | Samsung Dryers
Samsung Dryer dv203aes/xac will not heat. Drum is rotating and lint was cleared from exhaust.
Check the following:
1. Does it have 220 volts (yes it runs, but dryers run on 110 volts)?
2. Check the heating element and the safety thermostats located on the heat element canister. Low air flow from any restriction like lint build up or mashed ducting or blocked air exhaust vent cap can either trip the safety stats or burn out the element. Clean dryer and exhaust ducting thoroughly and replace bad parts before placing back in service. Poor air flow is the number one problem with "No Heat" dryer issues.
Sep 20, 2016 | Samsung Dryers
Dryer is spinning but not heating. we cleaned vents, unplugged dryer and replugged in. now it still won't heat and an hourglass symbol has appeared on control panel
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Apr 11, 2015 | Samsung DV419AE Dryer
I have a Samsung dv220aew xaa dryer that does not produce heat. I've replaced the heating element, the thermistor, and the thermostats with the problem remaining, what could be the problem?
ARE U GETTING THE RIGHT AMOUNT OF VOLTAGE AT THE CONNECTION,? i VE SEEN IN SOME CASES WHERE THE MACHINE ONLY GETTING 120 AND WILL RUN BUT NOT CREATE MUCH HEAT? THE DRYER USES 120 TO RUN THE CYCLE BUT NEEDS A FULL 220 FOR THE HEAT CYCLE TO WORK, THUS IF UR MISSING VOLTAGE IT WILL NOT HEAT? ANOTHER CULPRIT COULD BE A BAD TIMER STUCK ON COOL DOWN OR FLUFF CYCLE AND WILL PRODUCE NO HEAT?
Sep 25, 2014 | Dryers
My samsung dryer dv330aew/xaa wont heat up is there a reset switch?
you can check the element with a multi meter for continuity. may also want to check the hi limit thermostat and the cycling thermostat, do u have full voltage at the terminal? sometimes a tripped breaker will give you half voltage say 110 instead of 220 and what u get is enough power to run the dryer motor but not the heat as it takes a full 220 to run heat
Sep 08, 2014 | Samsung DV330AEW Dryer
Where is the cycling thermostat located?
may not be the cycling thermostat, check ur heating element, and the hi-lo limit thermostat, and make sure u have full 240 at the outlet bcuz if u have only 120 and not 240 u have enough to run motor but not the heater thus no heat? something may have tripped ur breaker. u will need to test with multi meter
Jul 12, 2014 | Samsung DV210 27 Electric Dryer with 7.3...
Samsung Electric dryer Model No. DV220AE: The drum will not turn; is it the belt that needs to be reinserted or replaced? The dryer is only 6 months old. Bad product?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 07, 2011 | Samsung DV328AG Gas Dryer
Our samsung DV220AE dryer wont dry (NO HEAT)
Nov 26, 2010 | Samsung Dryers
Samsung dryer wont heat
If it does not heath at all check the heating element, circuit breakers, thermal fuse, and also the thermostat.
If heat is scarce check thermostat and faulty heat relay.
Jul 08, 2010 | Samsung 7.3 Cu. Ft. Electric Dryer
Samsung dryer blowing thermostats, constantly
you may need to replace both thermal fuses and or the heating element itself but check to make sure you have the proper temp rating for the thermal fuses
Feb 20, 2009 | Samsung DV337 Electric Dryer
Dryers Logo
Top Dryers Experts
