Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
MOWER RUN WITH CHOKE HALF OPEN BUT PUSH THE CHOKE IN RUN REALY BAD AND THE IDLE GO UP AND DOWN UP AND DOWN
  • rjivaro May 11, 2010
    Mix is too lean.
    Problem Solver:
  • 4 Answers
Check to air screws on the carb.
Posted on May 19, 2009
My honda vtx 1300 will not run with choke all the way in but will run with the choke half way in. what is the problem?
If your bike will only run with the choke half way out it's starving for feul. You have a clogged jet. By choking the bike you cut off the air and allow more feul to run through the carb.
Oct 30, 2012 | Honda Motorcycles
LAWN MOWER ONLY RUNS ON CHOKE
RUN ONLY WITH CHOKE, IS FUEL PROBLEM. CHECK FUEL CAP TO REMOVE FUEL LINE FROM CARB. NEED FUEL RUN OUT LINE.
May 14, 2012 | Garden
How to start the generator
Hi Joe, I had asked for a little clarification and have not received any information. I will answer this question based on the generator is in good working order and it is a recoil start. Open the petcock, (this is the fuel valve) and give it about a minute to fill the fuel bowl on the carburetor. If your generator has an engine an on/off kill switch, set to on. If the generator has an auto idle switch set it to off. If the engine has a throttle lever located under the carburetor, push it all the way down (full throttle). Pull the choke knob out completely, there is a detent on the choke for half choke, pull it past this for full choke. pull the recoil starter rapidly. As soon as the engine starts running push the choke knob to half choke, this will allow the engine to run smooth while it's warming up. Depending on the climate that you are in, warm up time will vary. After a minute or two in cold climates start pushing the choke knob in, if it starts to run poorly pull it back out too the half position and let it warm up some more. When you can posh the choke in without the engine faltering it is ready to go. In warmer climates you might be able to start the engine without the choke or in the halfway position. Robin Subaru makes some of the finest small engines available. I would choose a Robin over a Honda every time. I hope this gets your generator going, and once again this is based on the generator being in good working order. Good luck, Michael Burke.
Dec 03, 2011 | Coleman Powermate Subaru 5000W Portable...
The van will start, but have to push pedal to the floor, once it starts it will idle great but dumps a lot of gas into the carb., once you push down on the pedal it dies.
carb problem sounds like choke is stuck or float is stuck remove cover and air cleaner and watch operation when starting see if choke blade is open or shut on carb and if shut watch to see if it opens when u let it idle. if not choke pull off solenoid is bad. if working tap on carb to free float.if that don't work carb may need to be rebuilt or get new one .
Mar 28, 2011 | 1989 Chevrolet G20
2nd use of chainsaw pp3516avx, it won't start, choke lever will not stay extended. I followed the instructions to start and nothing works
The choke system is connected to the half throttle position, if you lift the throttle trigger the choke pull will automatically return, whilst trying to start do not lift the throttle trigger, the starting procedure is, pump the primer bulb as many times as it takes to 3/4 fill the bulb, pull the choke pull fully out, this will switch the saw on and engage the half throttle, crank the engine until it fires once, do not continue to pull,it will actually not run on full choke, if you do continue to crank with the choke fully out, you will very quickly flood the engine, now push the choke fully in, now crank the engine until it fires up, lift the throttle trigger once, this will dissengage the half throttle, and it should now come down to idle.
Mar 19, 2011 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Have to choke or idle for mower to run
try a new carb kit.Thank you for asking and I hope this helps you.Please leave me a 4 thumbs up.
Jul 17, 2010 | Yard Machines Garden
How do I start rental model 96.
Place the saw on full choke with the switch on. Pull the rope until it fires. Place the saw on half choke, and pull again, and it will start running. Half choke should release as soon as you hit the trigger.
Mar 23, 2010 | Husqvarna Chain Saw 20" Bar
My 9N is having trouble starting. It turns over fine but seems to be flooding. When it finally sputters to a start, it takes a while to run smooth. Also the idle seems to be fast and there is no change in...
Shut off fuel to carburetor, drain carburetor. Open fuel and count to three then shut off fuel. Crank engine then pull choke for 1 second then push in. If engine starts open fuel valve at tank. Also try lowering float level in carburetor. Good luck.
Jun 26, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
374 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
