Question about Sewing Machines
Brother vx 1125
What light bulb does it use ? a screw in or baynet type.
3 Suggested Answers
  • 109 Answers
SOURCE: i have a brother vx-1125 and the top stich is fine
If the bottom stitching is a mess it usually means that the TOP thread is not threaded correctly. What happens most of the time is that the thread is not snug in the tension discs. First re-thread your machine with the presser foot UP and when you get to the tension discs (sticking up at the back of the machine) hold your thread like you're flossing and go back and forth in the disc to make sure you have tension on it. You should hear a little click when it's in there. (Test it...floss it on and pull it off so you can hear the click.) If the thread isn't between these discs your bobbin thread will be loopy. Finish threading the machine and you should have no problem now. Also, make sure your upper tension is set at 4 and your stitch LENGTH (on the right front) should be 2.5 or 3 for a normal stitch. Hope this helps. Let me know! Thanks for using FixYa
Posted on Sep 10, 2010
  • 1564 Answers
SOURCE: i have a brother vx-1125 the cotton keeps snapping..but the tension is correct..please advise..
I agree with Debbi. Tension adjustments must be made with each change in fabric type and thread type.
You don't say whether the thread breaks at the top thread or the bottom thread. Maybe more detail is advisable.
Posted on Aug 17, 2012
Need the light bulb for the 6005 Elna. I've had this machine for many years and its been a real work horse, but now the light bulb has gone out in it.
Looking here, it looks like a capless bulb like in cars.
Lamp Socket Unit Elna 395723 43
In fact it is, a 12 volt 5 watt capless auto bulb
Changing the Light Bulb The sewing light is located behind the face plate. Unplug
the machine. Remove screw cap and screw. Pull away
face plate.
Pull out light socket. Pull out light bulb. Push in light bulb
with pins aligned to holes in light socket. Push in light
socket.
Replace face plate, screw and screw cap.
NOTE: Only use same type light bulb rated 12 Volts, 5
watts
6005 Elna light bulb Google Search
similar
ELNA 6200 Instruction Manual Changing The Light Bulb Feed Dog
Feb 05, 2018 | Sewing Machines
Would like to find a screw that holds the needle in a Bicor vx 1005.
If, I am not mistaken your machine is made by Brother. Take a look at www.sewingpartsonline.com and look at needle clamp screw for Brother. Worst case scenario, replace the needle clamp assembly for about $20. I don't know what kind your needle clamp screw is, ie. set screw or just threaded screw with knob roughly $4.00.
Jan 16, 2018 | Sewing Machines
What light bulb fits 4300 Morse sewing machine
The Morse 4300 and 4400 use the same small 15W screw in light bulb as many other sewing machines. This is one vendor: https://a1sewingmachine.com/LB716sm~Bulb%2C+15+Watt+Small+screw+in+base.htm . Another source is https://www.sewingpartsonline.com/light-bulb-white-7scw.aspx .
I hope this helps. However, if you have a bulb in the sewing machine, take it out and confirm that it is the screw in type. (If there is no bulb, look at the socket for some turns for threading in a bulb.) If the bulb or socket doesn't have threads, then look for a 15W push and twist bulb at sewing machine parts suppliers.
Nov 08, 2017 | Sewing Machines
How to change a belt on model vx810
Hello again Mary
Your manual is here but nothing about changing belts!
http://www.manualslib.com/manual/219387/Brother-Vx-810.html?page=36#manual
  • Brother VX810 Sewing Machine Parts www.sewingpartsonline.com > Home > Brother Parts
    • 4.8/5
    • 68K RATINGS
    Brother VX810 Parts These parts and accessories are guaranteed to fit your Brother VX-810 Sewing Machine. View Parts. ... Motor Belt 20 7/8", Singer #130944-001
  • BROTHER SEWING MACHINE Parts ' Model VX810 - Sears ... www.searspartsdirect.com/model-number/VX810/0150/1220000.html Shop for BROTHER SEWING MACHINE repair parts for model VX810 at Sears ... manuals & diagrams for any BROTHER Mechanical Sewing Machines repair project. ...
  • Brother VX-810 sewing machine - YouTube www.youtube.com/watch?v=toFRHM3fsfo
    • BY TPERSELLIN
    • 19 SEC
    • 7.1K VIEWS
    2013-05-14 · Video embedded · Brother VX-810 sewing machine TPersellin. ... Threading a Brother DB2-B735 Industrial Sewing Machine & Sewing Various Stitch ...
  • BROTHER VX-810 USER MANUAL Pdf Download. www.manualslib.com > ... > Brother Manuals > Sewing Machine > VX-810 Brother VX-810 Sewing Machines: Users Manual. VX-810 Sewing Machine pdf manual download. Sign In. Upload. ... VX-810; User manual; Brother VX-810 User Manual.
  • BROTHER SEWING MACHINE BELT VX800 VX802 VX807 X808 ... www.ebay.co.uk > ... > Machine Parts & Attachments BROTHER SEWING MACHINE BELT VX800 VX802 VX807 X808 VX809 X810 in Crafts, Sewing & Fabric, Sewing ' eBay. Skip to main content. eBay: Shop by category. Enter ...
  • Belt Motor Brother VX807 VX808 VX809 VX810 VX847 ... - eBay www.ebay.com/itm/BELT-Motor-Brother-VX807-VX808-VX809-VX810-VX847... BELT Motor Brother VX807 VX808 VX809 VX810 VX847 VX880 VX890 VX900 VX920 VX940 + in Crafts, Sewing & Fabric, Sewing ' eBay
  • Replace Belt ' Brother support.brother.com/g/b/faqend.aspx?c=ca&lang=en&prod=mfc9970cdw... Replace the belt unit following the steps below: ... *If your Brother machine has a Touchscreen, please follow the steps under "For Touchscreen models" below.
  • Sewing Machine Parts - Brother Parts - Brother VX-810 ...
  • www.thesewingoutlet.com/brother-vx-810 Change Currency. Loading... Please wait... ... Brother Parts; Brother VX-810; Sort by: ... Brother VX-810. Sort by: ...
  • http://www.bing.com/search?q=change+a+belt+on+brother+vx810&qs=n&form=QBRE&pq=change+a+belt+on+brother+vx810&sc=0-30&sp=-1&sk=&cvid=F80CBC7C1B0340DFBBA06B46207E0E5E
    Jun 18, 2016 | Brother Sewing Machines
    Manual brother vx-1130
    Sue, I will post links below for your manual.
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
    Brother VX 1120 User Manual
    Brother VX 1120 Sewing Machine Threading Diagram
    Manual BROTHER VX1130 Operating Instructions Service
    Brother VX 1120 Sewing Machine Troubleshooting eHow
    Mar 03, 2016 | Brother Sewing Machines
    Where can I buy a bulb for my XL 3520 sewing machine
    Is it a push in and twist bulb? Or a screw in bulbs like the old Holiday lights? Both can be had in the states but we have different power voltage.
    I looked at your manual from Brother's download and it looks to me like it's a push and twist (some folks call it bayonete style) but I can't tell for sure.
    Here is a UK source... once you determine which bulb... these folks should have it for you.
    http://www.sewingmachine-sales.co.uk/catalogsearch/result/?q=sewing+machine+light+bulbs&x=0&y=0
    Aug 27, 2012 | Brother Sewing Machines
    I have a brother vx-1125 the cotton keeps snapping..but the tension is correct..please advise..
    The needle thread breaks
    1. the needle thread is not threaded properly
    2. The needle thread tension is to tight
    3. The needle is bent or blunt
    4. The needle is incorrectly inserted
    5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
    6. the threads were not drawn to the rear after sewing
    7. The thread is either to heavy or to fine for the needle
    Aug 17, 2012 | Janome Sewing Machines
    How to change the light bulb of my brother xl2600i
    on the left of the machine you should see a plastic plug, gently pry it loose with a small screw driver & it should show a hidden screw, undo the screw & the plastic cover should come off, to replace the bulb, the replace the cover & screw & plastic plug
    Feb 25, 2012 | Brother Sewing Machines
    How to open the right front cover on a brother Ls2125? The manual only talks about how to change the light bulb.
    I look at my manual & at the back of the of the thread take up lever ,where the thread guide is behind the machine on the top left hand side is a screw, just unscrew it take off the face plate & change the bulb & put the screw back in
    Dec 10, 2010 | Brother LS-2125 Mechanical Sewing Machine
    Brother VX-1120- The needle is not picking up bobbin thread.
    I had the same problem with my brother vx-1120 sewing machine. I set the needle to lowest position by using the hand crank. Then I loosened the knerled set screw that holds needle in place. Then I moved needle shaft till the eye of needle is just lower than the hook on the shuttle loop maker. It made my mechine work. There are instuctions for ajusting timing on machine but I think these mechines are built to not fix and throw out. Just because there where no ajustment marks at all on machine, any machanical machine will needed to be ajusted sometime.
    Jul 08, 2008 | Brother CS-8150 Computerized Sewing...
    Sewing Machines Logo
    26 people viewed this question
    Top Sewing Machines Experts
    Tally Girl
    Tally Girl
    Are you a Sewing Machine Expert? Answer questions, earn points and help others
