Question about Apple iPod nano
Ipod won't change to lower level menu when selected
  • Steve Brown
    Steve Brown May 11, 2010
    i would like to clarify what menu you are trying to get.
    when you scroll to the section on the main menu and press the center button nothing happens?
    or when you are trying to reverse from a section like a song playing back to the menu.
    let me know and I will help as best as i can.
    you may have a bad clickwheel in your ipod.
    using you thumb and rubbing it around the clickwheel will scroll to a section.
    pressing the center button will cause an advance action
    pressing menu will cause a reverse action
    in essence to get a song scroll to music or playlists and press center, repeat the process until you reach the song and it plays
I perfomed an "Update Procedure" to the IPOD from iTunes. That fixed the problem.
Posted on May 19, 2009
My volumn on my ipod 4th gen is not working and when i go to settings it only shows languages no volumn setting
One of the major warnings Apple includes with all of its iPods is the permanent hearing damage that could occur if you have the volume on your iPod turned up too high.
To help combat the problem, the iPod comes with a feature that allows you to set a maximum volume level that your iPod can be played at that level is controlled by a combination that can keep others namely children from turning the volume up to dangerous levels.
The good news is, if that combination falls into the wrong hands, it can be reset.
Use your iPod's click wheel to scroll down to "Settings."
Press the center button located in the middle of the click wheel to select the settings menu.
Scroll down to "Playback" and press the center button to select it.
Scroll to "Volume Limit" and press the center button to select it.
Use the click wheel to scroll to the first number of the old combination and press the center button to select it.
Repeat this process for all four numbers of the old combination.
Use the click wheel to scroll to where you want the maximum volume to be set and press the center button.
Use the click wheel to scroll to "Lock" and press the center button.
Use the click wheel to enter the first number of the new combination when the message "Enter New Combination" appears on the screen repeat the process for the three remaining numbers.
Once the four numbers have been entered, your iPod's maximum volume will be set and your password will be changed.
hope this helps
Oct 17, 2012 | Apple iPod Audio Players & Recorders
Tip
Change iPod Language
Disconnect your iPod from your computer, then press the Menu button until the menu title says "iPod," regardless of the language displayed. This means you are at the main menu.
  1. Scroll down to the last menu option but don't select it.
  2. Scroll up one menu item. This should be Settings.
  3. Press the Center (Select) button. This takes you to the Settings menu.
  4. Scroll down to the last menu option but don't select it; in English, this is the "Reset All Settings" option.
  5. Scroll up to the third menu item from the bottom one. This should be Language.
  6. Press the Center button to select Language.
  7. Select your preferred language from the list.
on Feb 10, 2008 | Apple iPod MA446LL/A MP3 Player
Volume wont turn up
Resetting the volume limit on your iPod Nano affects everything you listen to, from music to audio books. You can adjust the volume for each individual item on your Nano using the click wheel, but the highs and lows of the sound will depend on the overall volume limit setting. Volume levels will vary with different ear buds and headphones, and using external devices like docking stations to play your iPod Nano will also cause variation in the volume.
Instruction:
1 Press any button on your iPod Nano's click wheel and turn it on. Press the "menu" button at the top of the click wheel until you reach the iPod menu.
2 Select "Settings" from this menu by scrolling down until "Settings" is highlighted, then click the center button.
Select "Playback" from the menu choices that show up.
4 Select "Volume Limits." You will reach a screen with a speaker icon and dots indicating the level of volume your iPod is currently set on.
5
Scroll the wheel up or back to adjust the volume limits. Press the center button and you will have the option to lock in your settings by selecting a four-digit combination lock. This is not a necessary step; you can click on "done" and finish. Setting the combination allows you to have more control over any future changes to your iPod's volume limits. Scroll the click wheel to select your combination. Press the center button and you will revisit the volume limits; adjust it as you like and press the center button.
Goodluck
Dec 10, 2011 | Apple iPod nano
Volume wont turn up on my mp3 - volume too low
How to Reset the Volume Limit on the iPod Nano
Instructions
3 Select "Playback" from the menu choices that show up.
5 Scroll the wheel up or back to adjust the volume limits. Press the center button and you will have the option to lock in your settings by selecting a four-digit combination lock. This is not a necessary step; you can click on "done" and finish. Setting the combination allows you to have more control over any future changes to your iPod's volume limits. Scroll the click wheel to select your combination. Press the center button and you will revisit the volume limits; adjust it as you like and press the center button.
Tips & Warnings
If you set up a combination and forget it, you can reset your iPod Nano and start over again. Resetting will not lose any of your downloads, but you will need to restore or reset many of the settings you initially chose when you first set up your iPod.
Changing the volume limits on your iPod Nano covers everything on your player, but the sound levels for songs, audio books and shows will vary based on how they were recorded.
How do I change the volume on my IPOD Nano. Its too loud and hurts my ears.
  • Press any button on your iPod Nano's click wheel and turn it on. Press the "menu" button at the top of the click wheel until you reach the iPod menu.
  • Select "Settings" from this menu by scrolling down until "Settings" is highlighted, then click the center button.
    hope this help. :)
    Nov 04, 2011 | Audio Players & Recorders
    I need to change the lanuage from japanese to engish on a ipod and I know absolutely 0 japanese
    If you have an iPod nano or Fifth Generation iPod (iPod with video):
    If you have an older iPod with color display (including iPod photo)
    1. Scroll to the fourth menu item in the screen and press the Center (Select) button. This takes you to the Settings menu.
    2. Scroll down to the last menu option but don't select it; in English, this is the "Reset All Settings" option.
    3. Scroll up to the third menu item from the bottom one. This should be Language.
    4. Press the Center button to select Language.
    5. Select your preferred language from the list.
    If your iPod has a monochrome display (black and white):
    1. Scroll to the third menu item in the screen and press the Center (Select) button. This takes you to the Settings menu.
    If the instructions above don't enable you to change the language on your iPod, try using the "Reset All Settings" option at the bottom of the Settings menu. If the Reset All Settings option does not work, you can restore your iPod back to factory condition and reselect the display language.
    Apr 29, 2010 | Audio Players & Recorders
    How do u change the language back to english
    If this does not work.
    Reset your iPod—Depending on how much you've used your iPod since selecting the language, simply resetting your iPod may cause it to forget the current language setting, enabling you to select a new one. See "How to Reset iPod" for instructions.
    • Connected. Eject before disconnecting
    • Sync in Progress. Please wait...
    • Do not disconnect
    Note: When you reset your iPod, all your music and data files are saved, though you may need to reset some customized settings.
    Jul 03, 2009 | Apple iPod nano MP3 Player
    Language change
    Hi, Let me provide you the steps to change the lnaguage on your ipod mini...
    OR
    Feb 21, 2009 | Apple iPod MA446LL/A MP3 Player
    How to get my language back to english
    Select your language.
    for more details just click the link below http://support.apple.com/kb/HT1824
    rate the solution if it helps. thanks.
    Jan 05, 2009 | Apple iPod nano
    Changed language to french!
    Feb 09, 2008 | Apple iPod nano
    Apple iPod nano Logo
    Top Apple Audio Players & Recorders Experts
    TO Lady
    Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
