Question about Meiko FV 40.2 Dishwasher
How to convert 3phase to single ecostar 454d - Meiko FV 40.2 Dishwasher
Juki SC-800 3phase. How do I make it run on single phase? Tried VFD. Gives alarm 0001 and beeps.
If a VFD won't work you are best to obtain a single phase motor of Chinese origin. They are inexpensive and available widely on eBay. Just make sure to get one within the rating of your fixed supply wiring. You can also get mounting plates of different sizes.
Dec 27, 2016 | Juki Sewing Machines
Dayton electric heater model 3UF94 can you rewire from 3phase 240v to singel phase 240v
You can wire any heater with elements to single phase because all heaters are single phase. It will require a larger feed because your amp draw is going to go up doing away with the third leg. You split the heaters up from 3 phase to 2 legs amp draw is going to go up 30 percent or so.
Feb 06, 2012 | Heating & Cooling
Have a 3 phase compressor model vr5-8 want to know if it can be converted to single phase 230 volt and how
A 3phase motor cannot be rewired to run on single phase power. You need a phase converter. A 3-phase motor will only run on 3-phase power, and a phase converter will convert single phase power to 3 phase. Just google phase converter. There are two basic types, electronic and rotary. The rotary type are more powerful and efficient, but lot's more expensive than the electronic ones. Your only other option is to replace the motor with a single phase motor. Good luck.
May 17, 2011 | Garden
Sorry bought magnum compressor 3phase but also runs 240v cannot get it to run on 240v any info would be realy helpfull ta Peter
if you have a 3phase motor it will only run using 3 phase power no matter what voltage or you can get a phase converter but they are pricey and varies with what horsepower your motor is
Oct 19, 2010 | Magnum Air Tools & Compressors
Only have two phase power power company refuses to install three phase can i run my hobart h600-t mixer serial#31-1068-582 ml# 104385 with just two phase?
first thing, there is no 2 phase pwr. there are only single phase or three phase.you have 2 choices either you can convert mixer from 3phase to 1phase which will be expensive, or you can get a rotophase which will make 1phase pwr to 3phase pwr to run mixer, dont go with static phase inverter, only the rotophase inverter
Jan 19, 2010 | Hobart H600 Stand Mixer
I have an 3phase roof top unit the owner was told it can run on 1phase wiring. is this true.
yes you can , but it would be cost prohibitive because the compressor would need to be changed out with a single phase unit( that is if they make a single phase unit this large) and anything else as in condenser/evaporator motors would also need change out if they are 3 phase motors, as for just wiring it to a single phase line, it can't be done
Nov 19, 2009 | Cell Phones
Need to convert 3 phase Hobart dishwasher to single phase
It will not be inexpensive to convert your dishmachine over to three phase. With everything that you will need to replace, depending on the model if converyor or not it may run close to what it costs to have 3phase run to the building that you plan to move into.
Jun 08, 2009 | Dishwashers
Converting from three phase to single phase
Do you want to convert 3 phase to single phase?What voltage do you currently have (220v 3phase)?
May 07, 2009 | Kitchen Appliances - Others
3 phase to 1
hi,
u can change the 3phase heater to single phase.apart from all the component are of 1 phase.but consumption of current will be mre.apart from machine will run normally.
Mar 21, 2009 | Meiko FV 40.2 Dishwasher
Wrong voltage rating
Hello. If the unit is rated 460v, 3phase, the only way you can get it to meet your supply of 208v, 3phase, is:
a) have a transformer installed to make 460 from your supply by an electrician, or call your power company and see if 460 could be supplied to your building, but it would only be for that machine.
or
b) replace the heating elements for the 208v supply, have the pump motor checked to see if it will work on 208v, and a control transformer for the control circuit, as well as all the wiring related to the pump and heaters, as on 208v, they will draw more current than on 460.
so, can it be done? yes. Is the expense worth it? only you can answer that, However I would suggest that you resell that machine, and get the correct one from the start.
Hope that helps, and thank you.
Feb 16, 2009 | Jackson 25 in. TempStar HH Free-standing...
Dishwashers Logo
18 people viewed this question
Top Meiko Dishwashers Experts
jdthefixer
ray gallant
Mister Danger
Are you a Meiko Dishwasher Expert? Answer questions, earn points and help others
