Question about Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum... Side by Side Refrigerator
Samsung rs2555sl icemaker
Have a samsung refrigerator, problem is tht icemake stopped working. Found broken wire..repaired and got icemaker to run but no water. Tried to trouble shoot..frozen line, power to selinoid..etc. Found no power to selinoid. Replaced entire icemaker. Still no water to icemaker. Replace selinoid. And still have no power to selinoid. Switched power at selinoid with door water switch and got water to flow to icemaker. What else in the electrical lines would prevent power from the icemaker to the selinoid??
  • mmalc Aug 20, 2008
    I have the exact same problem. No power to the icemaker solenoid. If it truly is the circuit board that needs to be replaced, does anyone know where the board is located, what the part number is, and how to replace it? Thank you in advance.
  • Anonymous Mar 29, 2014
    line going to icemaker frozen
Replaced circuit board. Problem solved
Posted on Oct 26, 2007
Why is my icemaker not working
My Samsung French-door frig had the same problem - try resetting ice maker - red button on the side of the ice maker. If that doesn't work call Samsung service - I had a bad circuit board which needed to be replaced by local Samsung repair service.
Apr 05, 2010 | Samsung RF265AA Bottom Freezer French Door...
My samsung model #RS2578BB AUTOMATIC ICE MAKER IS NOT MAKING ICE PLS ADVISE
TOOLS NEEDED:
Eyes (fair to good shape)
#2 phillips screw driver
Flashlight
Lets assume it was working at one time right? And the FREEZER temp is BELOW 20degs
REMOVE storage bin to see icemaker.
LOCATE test button on underside or rightside of clear motor asembly.
(should be black)
Press until icemaker starts, then release button. Watch the tray twist and return to upright the should fill with water.
If icemaker worked: ICE SENSOR MAYBE BAD> ORDER NEW ICEMAKER IF THE ICE DOES NOT EJECT AFTER 4
If icemaker did not Start by pressing the test button.: UNPLUG the frig or go the Main Service Panel to the house (BREAKER BOX) and shut off the power and verify NO LIGHTS INSIDE THE FRIG>
Remove the concealed screws holding the icemaker to the ceiling.
PULL the icemaker forward to release icemaker. Using the Flashlight
LOCATE the wiring harness on the ceiling. Look for the RELEASE and Squeeze and pull down. Inspect the electrical pins to make sure all pins are equal and secured. If all is well there?
THE PROBLEM COULD BE either: ICEMAKER or Main PC Board
I would order a Icemaker assembly first since it is the least expensive.
1-800-Samsung
Good Luck and Cheers!
Seen It B4
Your Welcome
Jan 02, 2010 | Samsung RS2578BB Side by Side Refrigerator
My freezer degree keeps flashing and a beeping noise comes on about every minute and lasts for roughly 6 beeps. What is it?
Your icemaker sensor is out of its place. unplug the unit . check bottom of your icemake, the sensor looks like a little ***** , insert it back. turn unit on, and reset the board, Hold power freez, Power Cool for about 10 seconds.
Oct 27, 2009 | Samsung RB1955 Bottom Freezer Refrigerator
Model #10657051791 Icemaker just stopped
CHECK PWR TO UNIT, CHECK MAIN PANEL BREAKER FUSE IF GOOD , CHECK BIN SENSOORS AN WATER PUMP
Aug 19, 2009 | Samsung 18.8 Cu. Ft. Bottom-Mount...
Samsung RS2545SH refrigerator just stopped making ice. any advice?
Samsung Fridge  RS2545SH stopped cooling. The fridge section is about 50/55 and freezer is around 45. It wont go below. At one point, there was rumbling rattling sound from the compressor. Icemaker also stopped woprking.
Jul 18, 2009 | Samsung RS2630SH Side by Side Refrigerator
Samsung rf267aars icemaker stops making ice, icemaker makes clicking noise.
unfortunately it sounds like you have a broken tooth on the drive or driven gear of the ice maker, in this case you should replace the ice maker. The good news is that you can get a new one for about 85 bucks at your local appliance parts store.
Jun 23, 2009 | Samsung RF265AA Bottom Freezer French Door...
Samsung refrigerator RS267LABP icemaker
it could that your thermostat is set too cold making the ice crack and brittle
Mar 18, 2009 | Samsung 26.0 Cu. Ft. Side-by-Side...
ICEMAKER
check the valve connections at the entrance of water supply. Sometime that will get lose. And check if you have water on it and not having a line kinked
Apr 26, 2008 | Samsung RB2155 Bottom Freezer Refrigerator
Icemaker won't freeze - Samsung RS2578SH
Did you ever get any advice for this problem? Please repost if not.
Oct 07, 2006 | Samsung RS2578BB Side by Side Refrigerator
Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum... Side by Side Refrigerator Logo
967 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
