Question about Kenmore 700 sq. in. Cooking Area Gas Grill 14116325
I have a Kenmore Gas Grill model #146.23678310 during assembly I found an orange wire not connected to anything and nothing about in the assembly Instructions. What should this wire be connected to?
5 Suggested Answers
  • 37 Answers
SOURCE: Do I need lava rocks for my Kenmore 141.16322?
you dont need to have lava rock on it
Posted on May 05, 2009
SOURCE: need help assembling
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0401207.pdf
Posted on Jul 19, 2009
  • 3 Answers
SOURCE: Kenmore elite16690 gas grill - main burner replacement
Call 1-800-4MYHOME and request a brochure for that model. Then you can call the Parts line at the same number and order the parts you need.
The actual grill model number is 141-16690
Posted on Sep 08, 2009
  • 43 Answers
SOURCE: Gas is not getting to the burners on my Sears Kenmore gas grill.
check if regulator fully screwed to tank, turn on tank,then last burner,should hear/smell gas. if not replace regulator
Posted on Jan 07, 2010
How to replace regulator/hose/valve assembly on char-broil gas grill?
Follow the hose back to where it connects to the gas rail , and go from there , to see what has to come off if anything .
Apr 21, 2013 | Grilling
PRPOANE GAS REGULATOR ASSEMBLY BROKEN. MODEL# 842-0200-0
The model number 842-A250-0 does not match any Brinkmann gas grill models in my data base. However, if yours is a standard gas grill, that uses a 20lb LP tank, you can purchase a hose/regulator assembly at any home center or hardware store that sell gas grills and accessories. Make sure to take you old one with for comparison purposes (ie hose length).
Further, if you regulator has GDA on it. It was recalled by Brinkmann during a voluntary Safety Recall. If your regulator hasGDA on it, contact Brinkmann Customer Service (800) 675-5301 between 8:30 a.m. and 5 p.m. CT Monday through Friday. They will provide you with a free repair kit. You must provide and accurate Model Number & Serial Number of your grill, to take advantage of this Safety Recall.
Hope this helps you find the hose/regulator assembly you need. Please let me know.
May 05, 2011 | Brinkmann 842-A250-0
How do I connect the wiring to my igniter switch on a patio 2 Tec grill?
Hi, You will need to remove the front face plate. There are 4 phillips head screws holding the face plate on - one in each corner. Remove the screws wth a #2 phillps head screw driver. Once the face plate is removed you will have access to the orange pilot assembly wire. Simple plug the orange wire into the igniter on the face plate. Bolt the face plate back in place.
With your gas supply off - turn your rotary ignter and make sure there is a spark present at the pilot assembly.
GrillTechs,LLC
customercare@grilltechs.com
Nov 06, 2010 | Tec Patio II Grill
Replacing hoses and regulator on gas grill
I work for a propane co. I get many customers that bring in their melted or leaking bbq grill hoses and regs. Bring the bad hose/reg to your local propane gas co and see if they can make a custom hose for you. You may have to buy a new regulator to use it with the new hose, but that's better than buying a new grill. Call around first and see which ones can do it. You'll eventually find someone that can fix you up.
May 15, 2010 | Kenmore Grilling
Oven quit working
Hi. this is common in many old gas range ovens. There is a set of coils that are attached to the gas valve assembly. These coils , when activated and operational, open and close the main and secondary valves in this unit. They are controlled by the main ERC(clock/oven control board). I recommend checking these coils and there respective wiring harnesses. if the clips and wires are worn and corroded, simply replace the entire wire harness.
Now, if the wiring harness and wires that are connected to the coils look good and there are no signs of corrosion on the wires and connector clips, this will confirm that the coils have failed and you will need to replace them.
You can also preform an additional test with a multimeter. simply connect your multimeter or voltage meter to both terminal posts located on the coils. once your meter is connected, start the oven cycle. you should register some sort of current during this test at this time. if the current is sufficient and the coils do not initiated the valve action, this will confirm coil failure. if the meter dosen't register a current during oven operation, this will confirm ERC(control) failure. you will have to replace the Oven control board in this case.
The Most common issue in this situation will most defiantly be the coil assembly and not the control.
Please rate and god bless:)
Apr 21, 2009 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
May 03, 2008 | Kenmore Elite 900 sq. in. Cooking Area Gas...
Kenmore gas grill 141-16228
I would love to know the answer myself, I can't figure it out now that I have the grill half taken apart.
Jan 14, 2008 | Kenmore 700 sq. in. Cooking Area Gas Grill...
KENMORE Gas Grill 141-152210 Kenmore 437 sq. in cooking will only heat to 250 degrees
sudsy, this exact same thing would happen to me every time I changed a tank. I know it's nothing to do with the grill itself. I would have to seat and reseat the regulator hose to the tank a couple of times before it would start heating normally. Your model has 3 burners and I suspect that the flame is real low on each one even on the high setting. Try connecting and disconnecting the tank a couple of times and see if it comes to life. If worse comes to worse you can order a new regulator hose. Part number P3632L. Catriver..post back.
Apr 03, 2007 | Kenmore 437 sq. in. Cooking Area Gas Grill...
Kenmore 700 sq. in. Cooking Area Gas Grill 14116325 Logo
214 people viewed this question
Top Kenmore Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
