BAY28X153A need to wire to new thermostat
Wiring Honeywell 9580 to old furnace with no C wire
This is not going to be easy. Check the wiring in the wall to look for the third wire. If they did not run one, you have to run new wire to the furnace and thermostat. If they stapled that wire to the walls inside studs, then it is going to be even harder to run the new wire. Once you run that new wire then you have to locate the connection in the furnace that has the common (c) wire for the transformer. Check you tube to see if the have any how to video.
Oct 13, 2015 | Honeywell RTH8580WF WiFi Thermostat
Rheem Heat Pump Thermostat Replacement (#41-20804-15)
you need a 2 stage heat and cool t-stat hunter t-stat is not 2 stage
Feb 19, 2013 | Heating & Cooling
How do i wire analog thermostat to digital
You need to get a different thermostat.you can change an analog thermostat to digital, but you have to replace the motherboard with a digital compliant one. You can't just change the thermostat. Your best bet is to put back the old thermostat or upgrade to a different compatable thermostat
Jan 20, 2018 | Dometic Rooftop RV Air Conditioner
Can I change a arcoaire thermostat (mercury) with a White Rodgers Digital thermostat? The digital is very easy to install. Is is easy to dismantle the arcoaire?
If you have heat and air there needs to be 5 wires inside the thermostat, heat pump will need six. If you have heat only there will need to be three wires. If not, the new thermostat will only operate on batteries. Pay close attention to which wires go where and make them correspond on the new thermostat. Also remember mercury is a hazards waste product. Please recycle responsibly.
Jul 06, 2010 | Heating & Cooling
Need wiring diagram for Honeywell RCT8100
The old thermostat has a second stage heat which is W2. The new one doesn't have second stage heat.
The wiring your describing on the old thermostat is telling me you have a heat pump with second stage heat and the new thermostat is for air conditioning only. You will need to get a thermostat for a heat pump.
Apr 02, 2010 | Honeywell Electronic Programmable...
I bought a Honeywell programmable thermostat RTH2310 to replace my 10 year old Honeywell thermostat. My old thermostat is a 4 wire system but also has a jumper from Y to 1. New system does not tell me what...
It depends on the type of thermostat you have.
Do you have a 4 wire or 5 wire T'stat?
The red jumper wire was for a 5 wire t'stat with 1 transformer, the red jumper actually should have been from R to 1.
So you need to trace the wires back to the furnace and make sure they go to the locations identified below.
if you have a 4 wire t'stat then you don't need that jumper, if you have a 5 wire t'stat then you do need that jumper but it should go from Rh to Rc.
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
t'stat?
Nov 14, 2009 | Honeywell Programmable Thermostat Heater
Switching old thermostat to Hunter thermostat model 44155c
By describing the wires from your new thermostat and your old one, it sounds like your new thermostat is not compatible with your system. If you have seven wires now, then you more than likely have a heat pump system and you have to get a thermostat that is compatible with this type of system. Then you will have the connections you need.
Jul 11, 2009 | Hunter Fan Company 5/1/1 Programmable...
Honeywell Electric Baseboard Heater thermostat
You need to take the wires off the thermostat. And touch the red and white wire together. If the heater works then you need a new thermostat, if it does not work then you need a new ignitor. It all depends on the t-stat. Dont worry about the wires there are not enough volts to hurt you. It is milli volts so just touch them together and the unit should fire up
Apr 22, 2009 | Honeywell Programmable Thermostat Heater
Old mercury thermostat, New furnace wiring issues
Two wire hookup on the old thermostat tells me that it was set up for heating only. You will most likely need a modern thermostat. But in the meantime try this with the old one. The two red wires on the furnace are probably Rh & Rc. If so these can be put "together" on the R terminal on the old stat. The two W's on the new furnace are probably W1 &v W2 This is for first and second stage heat. You can put the two "together" on the W terminal on the old stat. Do not hook up the greens (blower fan wires). Do not hook up the blue wires (They would go to the Y terminal on a modern stat for airconditioning.
Who ever sold you the furnace should have offered you a new thermostat.
Good luck....
Mar 29, 2009 | Honeywell Programmable Thermostat Heater
Changing out old thermostat
your old thermostat is a milivolt and the wire runs from the heater to the thermostat. You have to open the back of the new one and connect the wire as per the instructions on the wireing diagram that came with the new one. I just installed a similar one myself, you will be very happy with it.
Jan 24, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
14 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
