Question about Stanley Garden
Pressure washer will not work
Motor turns on no water
3 Suggested Answers
Monster80
  • 463 Answers
SOURCE: pressure washer has no pressure
Try and back flush the washer..Take spay nozzle off washer and back flush with hose...If any kind of sand or deposits get into the Pump it will hold pressure valve open not letting it build pressure.after back flushing hook back up washer and before you put spar nozzle back on or start washer turn water on and make sure all air is out of washer..hook spray nozzle back up and hold it open with washer still off.when you see that there is no more air coming out of washer start it and you should have pressure.Hope this helps you and have a great day!!
Posted on Apr 05, 2009
  • 6468 Answers
SOURCE: pressure washer pump pressure kills gas motor
the pressure regulator valve is stuck take it apart and clean it
Posted on Jun 09, 2012
Why won't my pressure washer pump?
If its turning and you have no water or pressure is there a hose with a valve
a water seal that are connected the wrong way around ?
if not , the intake basketfilter on water drain hose.
if there is water and all iss clean and the motor runs no water then there is lime inside the valves fixed Liming most times its not running for a long time and has possible standing quite a long time been under a warm temperature in cellar if thats also not the answer then there should be a bypass connection thats not working because of lime thats actuates a microswitch (modern pressure washers an auto-stop for the motor if there is water demand only then the motor runs and by old pressure wachersthe bypass is only to have a microcirculation without stopping the motor to run but works by demand , most times there is a cuff-kit necessary but be aware it could be a bit expensive for budget models pressure washers that its relating not worth a repair . if a new pressure washer is cheep. it depends on the user and his priority on which he used the machine.
Nov 13, 2015 | Garden
I have lost the pressure of water but the motor is still working.
If the motor was ran without the water being attached to the washer it would crack the pistons which is what creates the water pressure for you.
Aug 18, 2012 | Karcher K 391m Pressure Washer
Cant pull start the pressure washer
Turn water off to the pressure washer, release pressure by applying hand pressure to sprayer. After water pressure is released, turn water back on (should not have motor running without water.) then try to pull start.
Jun 18, 2011 | Honda Karcher G2400HH-R Pressure Washer
Water goes thru. have hydrulic oil to level. gun semas to stick on. NOT GETTING ANY PRESSURE AT NOSSEL.
Hydraulic oil?
Is this a pressure washer?
Pump should be half full of SAE20 or SAE30 non-detergent motor oil.
Engine should have 10W30 motor oil.
If you have a pressure washer ... and not water is coming out end of gun:
Take all hoses off machine.
Look at incoming water hose connection.
The should be a filter washer.
Clean or replace filter washer.
Hook up water and turn on water.
Water should come out other side of pump.
Turn on power washer and see if water coming out of pump is pressurized.
Now hook up pressure hose without gun.
Turn on pressure washer and see if water comes out of hose and is pressurized.
Finally, the gun may be bad.
We used to replace guns when they went bad.
Oct 24, 2010 | Dewalt 3800 PSI Pressure Washer
I have a k7.91 pressure washer the motor runs but stops or pulses
This sounds like a problem with the pressure sensor which is located on the water inlet side of the pump. This switches the power to the motor when there is sufficient inlet pressure and water flow. This pressure switch can get partially siezed up, and not operate correctly.
You will need to dismatle the unit and identify the pressure switch, dismantle it and lubricate it with silicone grease.
Feb 28, 2010 | Karcher PSI Electric Pressure Washer
Karcher k3.48 pressure washer appears to be seized up?
if the machine is blowing fuses then it could be the motor! if not then maby the start cupasitor has failed
Jun 01, 2009 | Karcher PSI Electric Pressure Washer
Karcher Power Washer that surges up and down with water pressure.
Before you start it up:
1. Disconnect the high pressure hose 2. Connect the water supply and turn on 3. Make sure water is flowing through the pump
Start the motor, run for about 10 seconds and then turn off.
Turn off the water supply, connect the high pressure hose, turn water back on, start the motor and away you go.
May 29, 2009 | Karcher 2500 PSI Pressure Washer
Pressure washer has no pressure
Apr 05, 2009 | Garden
I have a Karcher 3.99 Pressure Washer. The motor appears to be working and water is passing through the machine when turned to the detergent application setting. However when the lance is tightened to turn...
Hi I have a karcher 3.99 the motor comes on and water comes out however thre is no pressure i have tested the lance on my brothers washer and this is ok what is wrong
Feb 21, 2009 | Karcher K 5.85 M Electric Pressure Washer
Garden Logo
80 people viewed this question
Top Stanley Garden Experts
Dennis Key
Dennis Key
Jim Goldsmith
Jim Goldsmith
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Stanley Garden Expert? Answer questions, earn points and help others
