Question about Faberware Coffee Makers & Espresso Machines
WON'T PERK COFFEE IT PERKS FOR A FEW MINUTES AND THE LIGHT COMES ON AS IF IT'S DONE BUT THE GROUNDS ARE NOT ALL WET, THE COFFEE IS COLD AND BARELY COLORED. 36 CUP FARBERWARE COFFEE URN MODEL # F S U 2 3 6
  • keves52 May 22, 2009
    We cleaned the bottom center of the pot where the post fits in - clean and shiny, but the coffeemaker still only perks 2 min max. the water is only warm and the coffee is barely brown. More suggestions?
  • keves52 Jun 09, 2009
    Apparently it's the fusable link or thermostat that needs to be replaced. I'll look into buying a different brand - sorry Mr.Farberware.
    But thank you FixYa. Appreciated your advice.
  • 15,935 Answers
Your main heating element, fuseable link, or thermostat has failed.
You will need to test each to find out which is problematic. (however your tests will be in vain) - see bottom of this answer)
The design of a percolator uses superheated coffee to rise up the tube and shower the coffee on top.
The 1150Watt element is directly under the tube and looks like this...
If the coffee is not heated - the tube does not fill with coffee - and you will never get the percolating.
If the thermostat is out - the element will not turn on properly to heat the water.
If the fuseable link were bad - the coffee wouldnt heat at all (so this is probably not the failed component)
Unfortunately - There are NO replaceable parts available from the manufacturer for this unit.
Quoted from another website -
I will not purchase another Farberware product.
I have the FSU 236 urn, which has been used only at family gatherings. When last used, it switched to the warming mode prematurely so all we had was an urn full of tepid dark water. Things break, no big deal.
Well, it is a big deal because a replacement thermostat is not available for this unit. I could not get a hit when I googled the part number stamped on the thermostat and Farberware/Applica/Salton indicated it is not a "consumer replaceable item." Odd, since you can get a thermostat, heating element, warming element, and fuse link for older Farberware urns.
Fine customer no service, at least direct me to a repair shop that would have the part and can fix the urn. Nope.
Then please look in your UL file and tell me the approved thermostats. Nope, that information is "not available and cannot be supplied."
I could understand if this model was discontinued, but it is currently being sold new. No more Farberware for me!
On the bright side, at least I have a lovely pot to ... never mind.
Someone has alread done the legwork for you.
All I can suggest is calling the manufacturer yourself to try your luck.
800-233-9054
Thanks for using FixYa!!
Posted on May 22, 2009
    Sergeant:
    Champion:
  • 219 Answers
he well at the bottom of the pot where the tube fits in can get coated with mineral deposits from hard water, and this causes the problem you're having.Some brands of coffee makers come with a cleaning tool for this. It's a flat metal piece that fits the well, and you use it to work a piece of steel wool (plain, not a soap pad!) back and forth to scrape off the buildup. If you don't have the tool, you can just cram a wad of steel wool into the well and twist it around by hand. It also helps to pour in Lime-Away (or a similar kind of cleaner) to fill the well and cover the bottom. Let it soak for a while, use the steel wool (wear rubber gloves to save your hands), and finish up with a thorough washing.
Thanks!
Sandy
Posted on May 20, 2009
Service center
Have you cleaned the outlet behind the brew unit? It is a trapezoidal shaped small hole below the plunger window. It gets clogged easily. Squirt some water into it and above it. It should come out clean. If it's clgged the water backs up into the grounds
Dec 10, 2012 | Solis Master 5000 Espresso Machine
It seems to be perking correctly but stops and then starts to perk again and again, this continued until I unplugged it, and also the light to indicate it was done never came on
Your pot needs a keep warm element. the main element works ( perks and perks) The thermostat works ( it turns the main element on and off.) The pot goes on and off because the water is getting cold The problem is the keep warm element. The reason, your pot perk's and it gets hot near the thermo, the thermo turns off the main element. The keep warm element is not on so after a small amount of time the water cools and the thermo turns the main element back on again, thus making the water hot. The K W element is supposed to be on all the time the pot is plugged in, it is instrumental in perking the first brew making it really hot, the thermo turns off the main element and the K W element keeps the water hot. The K M element is very a easy fix, it is the small looking white rope that runs around the bottom of the pot. Thanks and please ask if you need more help. Go to repairshack.com for the part. Ron
Sep 25, 2010 | Faberware 10-22 Cup Coffee Urn
Coarse grounds and no water!
Hi
Its your grinder that is the problem. It may have come apart. Look at the center burr and see if it is off to one side. If it is that is your problem.
Jul 19, 2010 | Saeco Easy Espresso Machine
When I get to level 15 it will let me upgrade my stats but won't let me pick a perk. The done choice is shadowed as if I'm not allowed to pick it so the game is basically over there.
To choose a perk, besides reaching a new level, you must also have certain amount of points in specific skills, for instance, for the Cyborg perk you must have level 14 and science 60% and Medicine 60%. Try reaching level 16 and you may see available perks for you to choose.
Jun 07, 2009 | Bethesda Softworks Fallout 3 for Xbox 360
Maker clicks on, but doesn't perk or heat the plate.
Unlike older coffee makers, the new Mr. Coffee designs seem to have reliability issues in regard to their circuit boards/controllers. You are right in your thoughts. If the unit is under warranty, I would suggest returning it for a replacement. E-mail your concerns directly to the company.
BTW--there are no user serviceable items within your coffee maker.
Mar 26, 2009 | Mr. Coffee FTX49 12-Cup Coffee Maker
Coffee perks luke warm
Your heating element is toast! If you want to risk taking it apart, there is a fuse inside that can be replaced and if the fuse is still in working order, (test it using a meter), the heating element is dying.
There is nothing else to do, but buy a new coffee maker.
Feb 27, 2009 | Hamilton Beach BrewStation 47224 Coffee...
42115
This often happens when there is too much coffee put in to start with. The coffee grounds expand when wet so take up more room. If it is too full to start with then the water has to build up too much pressure and that raises the boiling point. When the espresso is finished the coffee grounds should not be packed solid. You should be able to poke a hole in it with your finger.
Jan 26, 2008 | Bialetti Venus 4 cup stainless steel...
Coffee Makers & Espresso Machines Logo
93 people viewed this question
Top Faberware Coffee Makers & Espresso Machines Experts
Starnley Johnwells
Starnley Johnwells
Steve
Kolbrun...
Are you a Faberware Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
