Question about JVC DR-MX1S DVD Recorder/VCR
I plug it in to mains and all that happens is a white light comes on on front panel it also flickers every now and again?
You almost certainly have problems with the power supply board which fails fairly often in these machines. They are available for around 80 euros, trouble is that having bought one it is not uncommon to plug it in only to find you have another problem. Your best bet is to take it to a big JVC service centre where they will have the spares to try substitute components without you having to buy them first!
Posted on Nov 22, 2009
When I plug in the TV, why does a green light come on at the bottom of the TV?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Aug 04, 2015 | Televison & Video
When my 50 inch hp plasma tv shows white colors or when the picture lightens up for abrighter scean . It starts to flicker , The white ends up having faded pink colors in it . or the white flickers b
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
If the DC output from the SMPS [Power supply regulator board] is abnormal, this can happen. Check and adjust the Va & Vs voltages. Details about how to adjust it can be get by the above site.
Sep 14, 2014 | Televison & Video
Philips 52pfl5704 no screen image
Sounds like main board fault. Contact the authorized service center for Philips. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 28, 2014 | Philips 42PFL3704D LCD TV
Lg 47lv355u tv
Ok t-con board is connected to main board which is giving signal and logic supply.. If the main board failed or giving a over voltage to the t-con it possibly your T-con gone out (new) again.
To isolate the problem try to replace the main board.
Dec 05, 2012 | Televison & Video
Flickers until all monitor area turns gray - just like tv without signal
Sounds to me like bad caps on the power board or main board.
The monitor is faulty for sure. Bring it back to the shop and tell them the problem is still happening and ask them to leave it on connected to a computer overnight since it takes a while to happen. They should see it happen and then troubleshoot it further.
May 26, 2009 | HP Compaq FP 7317 17" Flat Panel LCD...
My Hotpoint 960 is 18 months old and has develped a fault where the mains light and programmer display flicker simultaneously, and the machine cannot proceed through the programme. It does not respond to...
Flickering lights might just be caused by loose wires in the mains plug on the machine's power cable. I would suggest checking that first - for some reason the neutral wire seems more likely than the others to come loose. There might be brown / purple marks around the terminal inside the plug if this is the case. Also try replacing the mains fuse in the plug.
While you are there you might also try plugging a normal table lamp into the socket you use for the machine - if the house cabling to the socket is defective the lamp should flicker too.
If neither of these ideas is productive, the problem would appear to be within the machine, so please ask again. Good Luck D.
Jun 29, 2008 | Hotpoint Washing Machines
White horizontal flicker on screen
Sounds like the logic boards on its way out
Feb 01, 2008 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
JVC DR-MX1S DVD Recorder/VCR Logo
461 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
