Question about Nokia Cell Phones
My sim card registration failed in my nokia c5-00.2 when i switch my phone on, it ask for the sim card pin code but then it says sim card registration failed
SOURCE: SIM card registration failed
i have the sme problem
Posted on Oct 06, 2008
  • 7 Answers
SOURCE: the phone keeps displaying sim card registration failed on phone
The sim card holder is too loose on a lot of new Nokia phones. Place some folded paper (3,4,5,6 times) between the sim card and the sim card holder. It should fix it. I have an E65 and had this problems for two days after buying it. Since I fixed it 3 months ago, never had this problem again. Hope it works for you too.
Posted on Mar 17, 2009
  • 106 Answers
SOURCE: SIM CARD REGISTRATION failed, N70
Factory resetting the phone will do absolutely nothing with this problem
There are 3 causes of Sim Card Registration Failed, when you first turn on the phone, the sim card attempts to connect to the network if it can not do this it gives a message like Sim Card Registration failed.
1, The sim card is turned off (is it Orange) if you have had the sim card for a while and it hasnt been used they will turn it off, you need to contact them from another phone to get it turned on or get a new sim card.
2, The phone has a hardware reception problem, when it attempts to register itself with the network it can not... There is a reception problem and it requires repairs, this isnt really an easy diy job on this handset.
3, The phone is blocked, i.e reported lost or stolen. Some networks when a phone is reported will allow it to get reception but will not let it make calls, however other networks will not give it reception at all and hence you get a Sim Card Registration failed message.
I hope this helps, these are the causes of the message.
Posted on May 08, 2009
  • 83 Answers
SOURCE: SIM card registration failed, whats wrong?
The first thing to try is put the SIM into another handset - if you get the same error message on that, the SIM is blocked. If it works in another phone, the most likely explanation is that the IMEI of your phone has been blocked by the network.
Posted on Jun 10, 2009
  • 3 Answers
SOURCE: Problem nokia 6300 ( Sim card registration failed )
i want to know that this problem solve
Posted on Dec 29, 2009
C2 01 doesnt accept the sim card, the pops out the "sim registration failed' message. the sim card is just fine, it works perfectly on other cell phones
1.Bad SIM -if it wasn't unlocked you'd get a message asking you to enter a PIN.Get the pin from an online vendor like http://www.theunlockarena.com/nokia-c2-01/rs13wp9/ .
2.With a warning that you have 10 attempts to enter the correct PIN code or it could be locked forever ,if you don't get that message it's "mostly likely" unlocked.BUT find a phone with a known working SIM and see if it will work and connect to the network.
3.May be a hardware problem try flashing with a custom rom.
4..This has to be a problem with the SIM card slot, which is soldered down to the logic board. It's possible that it's a mechanical problem , you might be able to open it up and discover that the card-detect switch is failing to detect SIM card insertion.
5.The os system has been updated and your phone is not being recognized with the right settings , this happened after a update a year or two ago..
Feb 12, 2014 | Nokia C201 Cell Phone
Nokia 6300 SIM card registration failed
If your Nokia 6300 phone displays an error message saying "Invalid Sim (or) Sim Registration failed" then your phone is probably network locked.
You can unlock it easily by using an unlock code.You can get this code at reasonable cost from TheUnlockArena.com with easy step by step unlocking instructions and unlock it.Then you can use freely any GSM network Sim card.
Dec 31, 2013 | Nokia 6300 Cell Phone
How to fix nokia n73 sim card registration failed
this is what happened to my 5230 before..suggest u try to contact ur service provider to check ur sim registration details.normally,registration failed when u type a wrong pin code more than 3 times..or try to reset ur phone by press *#7370#...gud luck..
Oct 21, 2012 | Cell Phones
Nokia N 70 - Error - 'Sim Card Rejected'
IF you put PUK code many times depending on the model it wil lock the sim card. This is because to prevent unathorised person using your SIM card.
Default PIN code for nokia mobile is 0000
PUK code will be given by the service provider only.
Please call your service provider or go to service provider office,they will assist you in this issue.And they will have a security check like name,Phone number and other information to check weather the SIM card belongs to you only.Then they will assit you.
Thanx
Jul 23, 2010 | Nokia N70 Cellular Phone
Nokia 5800 locked to orange unlock code,it keeps saying sim registration failed,locked and iv tried 3 different orange sim cards
If it showing you that sim card registration failed then then make sure your sim card is work or not. if your same Sim card works in different phone. it could be that your phone has been blocked by the network
Nov 17, 2009 | Nokia 5800 XpressMusic Smartphone
Check that sim valid,
Check with another sim card if problem not shows sim card may complaint do as follows
Take the sim crd out and rub gently with a cotton cloth, and reinsert it.
Or take to service provider & ask him to give duplicate sim.
If problem with mobile try to dial *#7370#(Format),
Or take mobile to Nokia care(Problem might be network ic).
Sep 29, 2009 | Nokia N73 Cellular Phone
Unlocking code for nokia n70
(First: copy all contacts from the phone to SIM card)
1.Switch off the phone.
2. Press and hold the following three buttons:
Green(call answer) button, (*) button, (3) button.
3.Now press the switch on button.
4.Then the message 'Formatting" appears on the screen release all buttons. I hope this can assist you in the fix .
Sep 05, 2008 | Nokia N70 Cellular Phone
Nokia 6300
SIM Card Registration failed, means your SIM card serial number does not exist in your SIM provider's Server.
Generally when a SIM not used for a long period (About 6 months or any fix duration by SIM provider), the company remove that SIM card serial number from server.
In some cases if your SIM is new then it might not be activated by company, so you can ask regarding this the customer care of your SIM provoider.
Thanks
Iqbal
Jun 12, 2008 | Nokia 6300 Cellular Phone
Cell Phones Logo
67 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
