Question about Zebra 140XiIII Plus Thermal Label Printer
Hi, Is it possible to run two Zebra xiIII's from one PC?
Do I need any extra software?
  • JDTec
    JDTec May 11, 2010
    no you just have to set the printers on 2 different ports on the computer.
  • 31 Answers
You can run as many Zebra printers as you have the connections to service with unless you are using a software program that limits you. Some of the LabelMatrix products from Teklynx will sell you 'seats' of software licenses. You can usually increment in 5's. Check out your software manual.
Posted on May 27, 2009
ginko
  • 19396 Answers
SOURCE: We Dont have the installation
CHECK HERE :
Drivers & Downloads
Posted on Nov 24, 2008
  • 5 Answers
SOURCE: XiIII Latest Firmware
I know when I was going through the zebra website I seen a bunch of firmware downloads. Once you are on their home page just click on downloads, then you should be able to find them.
Posted on Jun 27, 2009
  • 185 Answers
SOURCE: I have a Zebra 110 XiIII p it does print different size bar codes
Keeping up with the Drivers is a very good idea, it will fix little problems that come along from time to time. Try resetting the printer defaults by entering the menu system and exiting, at piont of exit don't save permanently but cycle around to load defaults and exit. Go back in and set the printer up again, this time exit saving permanently.
Posted on Jan 25, 2010
ozztech
  • 285 Answers
SOURCE: How can I rotate a graphic? we have a logo which
try to go to the driver and go to Advance Setup, here you can rotate or reverse the image.
Posted on Nov 13, 2010
printertech1
  • 96 Answers
SOURCE: I keep getting wrinkled ribbon in my zebra XiIII
Its probably not static. 1. Wipe the print head and platen roller with alcohol dampened qtip or lint free cloth. Print about 30 labels while gently pressing on the ribbon supply, causing it to drag a little and observe if the wrinkles stop. If so tighten the nut on the end of the ribbon supply a little at a time until wrinkles disappear. Check the head pressure toggles on top of the print head and make sure they are adjusted about the same. If you have been printing a lot of the same size labels, check the platen roller (white) at the point where the right edge of the label rides on it for a slight offset where the roller is worn down. If it is worn, the only fix is to replace the platen roller.
Posted on Mar 05, 2011
Chinese characters print
A quick way around that is to make a photograph (jpg) image of the text and then print it
Nov 29, 2013 | Zebra 140 XiIII XiIII + PRINTHEAD...
Jan 21, 2010 | Zebra 110XiIIIPlus Label Printer
Hi. I Recently inherited a Zebra 140 XiII(2) and I cannot set the print speed as the option doesn't show on the LCD menu or when I print out the printer config settings. Any help would be appreciated.
Print speeds on the Zebra xiII series printers are set via software. There is no printer menu speed setting on the xiII series. Zebra didn't allow speed adjusts thru the front panel menu until they made the xiIII series printers... The ZPL code command for print speed is "^PR"
Jul 16, 2009 | Zebra 140Xi II Thermal Printer
May 07, 2009 | Zebra 140XiIII Plus Thermal Label Printer
Hi, I have a zebra 110 xi||| plus which is printing extra labels.
Did you design the label? Do you have any control over the label design? This is usually a sign that the printer is trying to excede the page limit (usually by one dot row) and is going to the next label to finish. By making the label length slightly smaller, you can stop this.
Mar 20, 2009 | Zebra 110Xi III Plus Thermal Printer
Only printing 1/2 a label
recalibrate the printer in the set up.
Don't just do a quick cal from the front panel.
Make sure your driver is the correct dpi zebra driver, either zebra or my preferred seagull scientific.
by .5 of the label, do you mean width or heigth.
If it is heigth, check to make sure you are set for top of print correctly. Also you will have to back feed for a label that short.
Feb 24, 2009 | Zebra 110Xi III Plus Thermal Printer
140XiIII left side print right side completely blank
Verify your LCD Display Print Width setting is set wider than your actual label width. The printer will only print to the width of the PRINT WIDTH setting. Also verify any driver or software settings as these override your printer settings.
Jun 30, 2007 | Zebra 140XiIII Plus Thermal Label Printer
Zebra 140XiIII Plus Thermal Label Printer Logo
107 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
