Question about Xerox Phaser 8200 Laser Printer
Error Msg: Maintenance drawer A is missing - Phaser 8200
Error says maintenance drawer is missing, but it doesn't seems to be.  I'm new to this office and not familiar with the machine.  No manual available.  Staff say all parts appear to be in place.  Tried removing any parts that would come out, and put them back.  Emtied toner waste tray.  Turned machine off (& unplugged) for an extended period of time.  Error message remains.  Suggestions?
  • Anonymous Jan 13, 2009
    Error says maintenance drawer is missing, but it doesn't seems to be. Epmtied toner waste tray. Switch out the old maintenance kit. Turned machine off (& unplugged) for an extended period of time. Error message remains. The orange chip is there. All parts are in place. Suggestions?
    Novelist:
  • 208 Answers
There is supposed to be an orange chip on the back of that tray.
If that is not present or seating properly that will cause that problem.
Pull out the green tray and see if the chip is snapped on the back ot the maintenance tray.
Posted on Dec 07, 2007
How do I replace a Transfix Assembly
There should be a door on the right side of the printer. Replace the maintenance kit and clean the waste ink tray.
Apr 14, 2012 | Xerox Phaser® 860, 8200 Standard Capacity...
Xerox phaser error code is : 07.002.44:10318 what dose this mean
07,002.44:
PM_FAULT_PROCESS_MOTOR_STALL
Verify process motor operation with the Process Motor diagnostic
test. Also exercise processes run with the process motor;
transfix, drum maintenance and head tilt. This can be caused by
the power control board. The process motor may have more than
one task initiated. Reset all solenoids and the pressure roller
prior to cycling power.
Jun 17, 2009 | Xerox Phaser 8200 Laser Printer
Phaser 8200 Smears on Linen Paper
Your maintenance kit is running low on oil and needs to be replaced. Since the image drum is not getting enough lubrication, some of the ink from the previous page is sticking to the drum and carried over onto the next page. Also, try to match the printer paper type to the paper you are using. It will adjust speed, temperature, etc. to optimize print.
Mar 24, 2009 | Xerox Phaser 8200 Laser Printer
Fault Code 07.005.47.201057
From the service manual:
PM_FAULT_DM_CAM_
POSITION_ERROR
The Drum Maintenance home sensor actuated, but not at the
expected time. Inspect the maintenance drawer lift pins for wear.
Run diagnostics to verify clutch and sensor operation. Also verify
that the drum maintenance shaft is properly assembled.
If you need the SM, let me know and I'll shoot it out to you. Thanks and please take a moment to rate as fixya.
Jan 26, 2009 | Xerox Phaser 8200 Laser Printer
Tektronix Phaser 840 Model Z840 shows error 08 001 44 215264
Check for broken Maintenance Drawer Guides, or the Printhead Cap/Wipe/Purge assembly is defective. (If it is for a Phaser 840)
Dec 05, 2008 | Xerox Phaser 8400 Laser Printer
Error message
07,005.47 PM_FAULT_DM_CAM_POSITION_ERROR
"The Drum Maintenance home sensor actuated, but not at the expected time. "
Inspect the drum maintenance drawer lift pins for wear. That is the black assembly you remove to clean out excess ink and also holds the maintenance kit roller and IC chip.
There are two arms that stick out on the sides....if they are worn on the bottom, or grooved out, that will cause this error.
Nov 21, 2008 | Xerox Phaser 8200 Laser Printer
Reset counter on Xerox Phaser 8200
I think the maintanance kit runs out based on time and usage, which ever comes first, roll back your printers clock a few months or more and see if that fix's the problem.
Oct 05, 2008 | Xerox Phaser 8200DP Thermal Printer
Phaser 8200 will not start up
Are you getting any fault codes on the screes? A fairly long number..
Jul 29, 2008 | Xerox Phaser 8200 Laser Printer
Phaser 8200
Normally its the maintenance tray clutch slipping.
Or the maintenance tray ends are worn.
You can remove the left cover and clean the clutch, its on the lower part of the frame, and take your kit out and there are 2 tabs sticking out the ends that were on the last 1/4th inch.
The Printer's Front Panel Displays Printer Error - Report Fault: 07,005.47
Cause:
The Drum Maintenance home sensor actuated, but not at the expected time. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. TRY FIRST (Solutions without parts): The wiring harness from the clutch is not seated properly on the I/O Left board. Check all wiring connections to the I/O boards and verify. connectivity. TROUBLESHOOTING TIPS AND HINTS: Inspect the maintenance drawer lift pins for wear. See Service Bulletin #445 Rev #1 Replace Drum Maintenance Cam Followers for Inadequate Drum oiling Due to Worn-out Lift Pins. Run diagnostics to verify clutch and sensor operation. Also verify that the drum maintenance shaft is properly assembled. PARTS:Parts are listed in the order of highest probability for repair. NUMBER QTY DESCRIPTION PROBABILITY% MODEL S/N FROM S/N TO S/N 401087100 1 CLUTCH; LARGE,DM,SAFETY CONTROLLED 436041400 1 MAINTENANCE DRAWER W/10K ROLLER & COUNTER/PHASER 860/8200 367051501 2 FOLLOWER,CAM; DM CAM,SAFETY CONTROLLED, QTY 1
May 05, 2008 | Xerox Phaser 8200 Laser Printer
Maintanance kit replace
Problem:
The machine displays the Replace Maintenance Kit after the Maintenance Kit has been replaced.
Cause:
There may two causes for this issue.
  1. The machine does not recognize that the Maintenance Kit was removed. This would likely be caused by a defective Drum Maintenance Pivot Plate.
  2. The machine corrupts the CRUM on the new Maintenance Kit. This may be caused by a defective Drum Maintenance Pivot Plate or IO Board.
  1. While the Replace Maintenance Kit message is displayed, remove the Maintenance Kit. If the displayed message does not change to "Maintenance Kit Missing," replace the Drum Maintenance Pivot Plate and install a new Maintenance Kit.
  2. While the Replace Maintenance Kit message is displayed, remove the Maintenance Kit. If the displayed message changes to "Maintenance Kit Missing," replace the IO Board and then install a different NEW Maintenance Kit. If the problem persists, replace the Drum Maintenance Pivot Plate and install a different NEW Maintenance Kit.
ETI v1.3.20.0 610606.Replace Maintenance Kit Message after it Has Been Replaced 2007-11-18 21:37:39
Mar 30, 2008 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8200 Laser Printer Logo
204 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
