Question about Frigidaire FPHB2899LF
We returned from one week away to find our ice maker very full. I emptied the ice maker and now there is no water flow into the cube tray. The plastic arm on the left hand side appears to be stuck in the raised position. Can I just pull this arm down to get things going again? I don't want to pull down too hard and break something.
fridgetech
  • 473 Answers
SOURCE: Ice dispenser only dispenses crushed ice
Pull out your ice bin. In the back of the bin you will see a rod protruding from one side. That rod goes into an opening in the rear of the freezer. There is a solenoid behind that opening that raises and lowers the arm on the ice bin giving you crushed or cubed ice. Check to see if that solenoid is froze up or if your rod got stuck under it. If all check ok then replace that solenoid.
Posted on Nov 06, 2007
  • 1073 Answers
SOURCE: Water not flowing into ice maker
yes there is a problem with the water valve or the fill tube that puts water into the ice maker is frozen not letting water into the ice maker
Posted on Apr 17, 2008
  • 409 Answers
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Posted on Sep 25, 2008
  • 142 Answers
SOURCE: water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Posted on Jun 02, 2009
woodchuck789
  • 4070 Answers
SOURCE: ice maker not working
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow.
Posted on Apr 29, 2010
My ice maker does not make ice but water does run to front of fridge plz Help ????
I can't make out the words in your picture so there is not a lot of information to go on, but I will give it a try. If yours is like my refridgerator, there are a couple of off switches for the ice maker. One is on the control panel like the one you tried to photograph. Mine selects crushed ice, cubed ice, or ice off. The other soff switch is the lever switch that sits over the ice cube reservoir inside the freezer and shuts off the ice maker when the reservoir is full. If this lever switch is stuck in the up position you will make no ice. You say that water runs out of the front. Another problem that I once had with my ice maker was that the plastic housing around the ice cube tray cracked. One tray of ice cubes was made but when the ice maker flipped the tray over to expel the ice cubes the cracked plastic prevented any torque on the tray and the ice cubes would not come out. When the tray returned to the upright position new water would flow onto the tray, but since it was already full of ice cubes the water would simply overflow into the ice bucket reservoir. It did this over and over until I had an ice sculpture in my freezer and reservoir instead of ice cubes.
Jan 02, 2017 | Refrigerators
Freezer wont make ice cubes
This is not difficult to troubleshoot.
  • When the arm is up the ice maker is off
  • When the bucket is full the arm is up the maker is off.
  • If the ice maker has a on/off button in off the ice maker is off
  • If the ice maker internal heater fails the cubes will not release and the white plastic ejector arms will be rotated CCW and pressing against the ice in the tray, Normal position for ejector arms is vertical.
  • If water solenoid has failed or water supply not available the ice maker will cycle. The ice tray will be empty,(hard to see if ice tray is empty). Check and replace water fill solenoid.
  • If ice in tray and ejector arms vertical several possibilities.
    • Freezer not cold enough to trip thermostat in ice maker to initiate release cycle.
    • Check freezer temperature <10 Fahrenheit thermostat in ice maker failure
    • Ice maker motor failure,
    • Internal ice maker electrical connections rotary switch failure,
    The best way to check the operation is to manually lock the arm up into the off retention position. Wait a minimum of one hour. Open door and release arm down. Observe the operation of the ice maker. Is after a minute or so the ejector arm does not rotate then it is likely the ice maker has failed internally. If the ejector turns and no ice than you can assume either the water supply is off external from the refrigerator or more likely the water solenoid located behind the bottom back cover has failed. It is also possible that the hose that connects the solenoid to the ice maker has frozen right where it enters the freezer just above the ice maker. You should see ice built up at the entrance where the water fills the tray if this has occurred.
Ice Maker Repair
Dec 22, 2015 | GE Monogram Side by Side Refrigerator
My srf7520ss is not making ice
These fridges are renowned for this problem & even Samsung seem to not know the answer. BUT I DO & WILL SHARE.
I was about to replace the ice maker, as that is what everyone seems to recommend. BUT being a skinflint & a why is it so person, I decided to do some logical fault finding first.
There is this thing called fuzzy logic & these ice makers need to know you are using lots of ice, so as to make more.
I found that emptying a near full ice tray into a plastic bag & putting this bag in the freezer, the ice maker would not necessarily make more ice! If it did it was very little.
A few days of this & I decided to operate the ice discharger motor for like a minute & a half when the ice tray was empty.
Within 10 minutes one could hear water being loaded into the ice cube maker. Some time later the cubes being dropped into the tray & the filling/discharging process repeated, until next morning the tray was near full again.
In summer [like now, with our very hot 30*-38*C [90*-100*F] weather] I do this, all the time, so as to ensure we always have plenty of ice. Works everytime.
Away for an extended period, as we are often the tray will fill then no more [or turning off the ice maker while away] & the ice maker won't get back on track until you do the above.
Mar 17, 2012 | Samsung Refrigerators
Ice freezes into one solid block and won't dump out of the tray
remove cube tray from ice maker. clean with limeaway adn rinse. Spray with a light coating of PAM cooking spray. wipe dry and reinstall. be careful not to damage the sensor ( in center of tray)
Aug 26, 2009 | Samsung RS2578BB Side by Side Refrigerator
Ice maker will not work
There's no ice If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Small or too few ice cubes If the ice maker is producing ice poorly--making small cubes or too few cubes--you probably have a clogged water line, a defective water-inlet valve, or a defective ice maker mold thermostat that isn't cycling properly. Check these:
  • The water line that's attached to the back of the refrigerator. Make sure you have good water flow. If the flow is poor, repair, clean, or replace the tubing or the shut-off valve that supplies the water.
  • The water-inlet valve. Replace it if it has failed.
  • Check the freezer temperature. If should be 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker mold thermostat. Make sure that it's cycling properly.
Specks in the cubes If you find black or gray specks in your ice cubes, have a look at the ice cube tray. If the protective coating is peeling away, the most economical solution is to completely replace the ice maker.
Apr 01, 2009 | Frigidaire Optional Icemaker Kit
The ice is working fine. However, the water will not flow. Water was working fine. I was out of town for about 4 weeks and the filter light was on when I returned. I changed the filter and now water...
Remove the drawer containing the Ice cubes , and blow a hair on the pipe where the water come in. If it wasn't used for 4 weeks perhaps the nozzle in the inlet pipe froze. Then put the empty drawer back in so the ice maker thinks it needs to make ice and see if it will work
Hope this helps
Loringh
Nov 01, 2008 | Samsung RS2630SH Side by Side Refrigerator
Fridgeidare freezer
how old is it ??? it only makes 8 ice cubes every 2.5 hrs or so when running correctly.some times 5 cubes depending on model. try reaching into the ice maker and feel the ice being made is the tray full or is there empty slots in the ice mold(asif not enough water). are the cubes hollow??( a sign of low water pressure)). have you replaed the waterfilterrecently (if applicable) old filterwill restrict water flow.
Mar 16, 2008 | Refrigerators
Kitchen Aid Ice maker Stopped working
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Nov 22, 2007 | KitchenAid Superba Architect KSCS25INSS...
Ice maker stopped working and no Water in Ice maker,,,
I had this same thing happen and I just fixed it! After returning from a long trip, I threw out the old ice (now mostly shrunk), but no new ice was being made. The tray where the ice is made was completely empty/dry (maybe any ice cubes there had "shrunk" away to nothing as well? perhaps part of what keeps the freezer "frost free"?).
So I filled the tray with water using a small measuring cup -- which is what the manufacturer suggests when the refrigerator is new. Now it's making ice again just fine! This might or might not work for you, but trying it won't cost you anything.
Aug 27, 2007 | KitchenAid Superba Architect KSCS25INSS...
Frigidaire FPHB2899LF Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
