Question about Dell OptiPlex GX280 PC Desktop
Long low bleeps after adding RAM
I was going to upgrade the ram in my dell computer but now when i turn it on it just beeps a long low note and doesnt do anything, i am almost certain I have put the ram in properly i have tried taking it out putting it in all that business but nothing works please help!
  • imnot18 May 18, 2009
    Thank you for that it is a desktop and ddr2 memory on both the stick that works and the sticks that dont work. The thing i dont understand what you said is about pc100 and 113 could you please clarify it might help solve my problem thank you alot
  • Frank Zhang
    Frank Zhang May 11, 2010
    are you sure the added RAM is compatible parts? how about use original one, booting ok?
  • 39 Answers
It is either incompatible or dead.  try it in another machine.  if the stick of ram runs, it is likely an incompatibility.  refer to your documentation included with the motherboard/laptop (you didn't clarify) to see what it supports.  there is actually a huge difference between pc100 and 133 (which are now obsolete) and ddr2 and ddr3, although they respectively share similar pin count and layout.
Posted on May 18, 2009
Computer won't turn on, All the USB has no power
Check your ram remove all, then replace each stick one by one, if any bleep its more than likely bad. remove it. if that doesnt help, your motherboard could be going. try removing ram first.
Apr 24, 2014 | Acer Aspire M AME600-UR378 Desktop PC
Adding Memory to Inspiron 546
Try them in slots 1 & 2 also make sure your ram is all the same .Also try 1 at a time you may have a faulty ram module. .
Jan 17, 2014 | Dell Inspiron 546 MT Desktop Computer
What should i do my desktop goes on bleeping after I changed battery?
Bleeping? Sure it's not a Sheep?
OH, I'M JUST KIDDING!
The beeps you hear are BIOS Beep Codes. The computers way of telling you something is wrong, and an area to look into for it.
http://www.5starsupport.com/info/beep_codes.htm
I hope you had the computer unplugged, and FOLLOWED Anti-Static Precautions.
If so you probably just knocked the Ram Memory loose.
Remove all Ram Memory module/s ('Stick'), and then reinstall.
It is the only way you will be assured they are installed tightly, and correctly. Visual inspection will NOT do.
[ Positive ( + ) side of battery goes UP ]
http://www.dell.com/support/troubleshooting/us/en/19/Product/inspiron-530s
Regards,
joecoolvette
Nov 25, 2012 | Dell Inspiron 530s Desktop Computer...
Added RAM to E210882
This common.
You either added the wrong size or type of RAM (verify this)
or
You need to take it out (power down first)
reboot... wait for the beeps to go away
Power off
Place the ram back in again... be sure it is in the right channel
If you have 4 slots... one stick per set of slots.
Sagacious1
Aug 07, 2009 | Dell (E210882) Motherboard
Error after memory upgrade
the frequency of 256mb ram is nt equivalent to one gb ram
Jun 20, 2009 | Dell Dimension 2400 PC Desktop
Computer wont turn on
There are over 20 bleep codes, it sounds like morse code with short & long bleeps, these bleeps are for on board memory, remove RAM from slots & re instal one at a time in another compatable machine to check if RAM is OK, check power pack, also check power switch connection on front panel conection block on mobo
Apr 10, 2009 | Dell Dimension E310 PC Desktop
Dell dimension 3100 when turned on bleeps and no display on monitor
It depends on how many times it bleeps.
Beep Codes Possible Causes Corrective Action 1 - 2 No video card detected Reseat the video card 1 - 2 - 2 - 3 BIOS ROM checksum error 1 - 3 - 1 - 1 DRAM refresh error Reseat the memory modules 1 - 3 - 1 - 3 8742 Keyboard Controller error Reseat the keyboard connector 1 - 3 - 3 - 1 Memory defective or not present Reseat the memory modules 1 - 3 - 4 - 1 RAM failure on line xxx Reseat the memory modules 1 - 3 - 4 - 3 RAM failure on data bits xxx of low byte on memory bus Reseat the memory modules 1 - 4 - 1 - 1 RAM failure on data bits xxx of high byte on memory bus Reseat the memory modules
More info here: http://www.bioscentral.com/postcodes/dellbios.htm
Oct 28, 2008 | Computers & Internet
Finding ram
try to get a eraser to clean the contact of you're new ram!
May 13, 2008 | Dell Optiplex GX150 Tower Computer - 1GHz...
PC turns on then quickly turns off
Does it boot fine if you remove the memory you just added? If it does then try switching the memory that was in it before with the memory you just added. You want to first determine if the ram you bought is bad or incompatible.
Dec 06, 2007 | Computers & Internet
Dell OptiPlex GX280 PC Desktop Logo
99 people viewed this question
Alun Cox
