Question about DeLonghi Dehumidifiers
Not coll we collecting water and pause light on
How do i fix it so that it will collect water?
1st ck that your humidistat is set correcly and unit cycles the compressor on/off correctly ,Not just the cirulation fan running all the time , next ck your filters , clogged up filters wont allow air to pull thru unit , also are you sure room has enough moisture in it to pull water from, Most units wont draw a percievable amount of water out of air thats got less than 52%rh , as most homes target a 70%rH as normal
Dec 18, 2014 | Dehumidifiers
Pause light is constantly flashing
Pause is not a term ive seen on a dehumidifier , but one would assume that its waiting for something to occur in that mode , and with these the only logicial reason to wait is to "wait" for Moisture to return to room , maybe your room has been voided of %rh to the setting on unit and its waiting for more water to return ??
Dec 13, 2014 | Dehumidifiers
The full bucket light stays on yet no water is collected
if water full light stays on the compressor wont start and remove water from air , investigate why light stays on ? is bucket really full? is sensor knocked out of its fragile holder ? is bucket all the way inside machine so that sensor is connected ?
Jul 04, 2014 | Kenmore 54501 Dehumidifier
My dehumidifier's red light illuminates seconds after turning on the unit even though no water has been collected... it is unusable
Shannon, this is also an indication that the water collection bucket was not reinstalled properly. Turn the unit OFF, unplug the unit and remove the water collection bucket. While it's out, check the top of the bucket for a float valve (if yours is so equipped). As it may be stuck in the UP position. If so, jiggle the arm of the float valve to make it return to the down position. When you reinstall the bucket, be sure that it fit's "squarely" from top to bottom into the bucket holder and makes firm contact with the bucket safety removal switch on the back wall of the bucket holder. The bucket should not tilt down at the bottom when installed properly.
Lug the unit in and turn is ON. If all was checked and done correctly, the bucket full light should not illuminate.
Hope this helped you and thanks for choosing FixYa.
Sep 08, 2011 | Dehumidifiers
Runs but no water appears in container, also the filter light does not come on when button is engeaged, why is no water collecting? is there a filter I should be replacing? Thanks, Matt
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 04, 2011 | Frigidaire FDF70S Dehumidifier
The dehumidifier runs, but does not collect water in its reservoir. (the lights all light up, it cycles on and off, but all it appears to be doing is running the motor - not actually functioning.) And,...
heatman101
Jun 22, 2011 | Kenmore 54701 Dehumidifier
Unit shows green light for dehumidifying, but no water collects in tank. Dank smell in basement does not diminish
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Feb 09, 2011 | DeLonghi DE40P Dehumidifier
Haier dehumidifier will turn on but does not collect water.
hello. If your dehumidifier doesn't seem to run often but the humidity in the room is high, try adjusting the humidistat control on the dehumidifier to a dryer setting. If the dehumidifier seems to run constantly, but there's little or no water in the container, there may be a problem in the refrigeration system. Try cleaning the unit. If that doesn't work, you can't repair the refrigeration system yourself, you need a qualified appliance repair technician to do that.
Apr 14, 2010 | Haier HD656E Dehumidifier
Dehumidifier runs without collecting water
1- check if the water collecting bucket is properly installed (the light will show is ON but if the bucket is not propely installed -pushed in the proper position ) -make sure the slots on the bottom of the dehumidifier are posisioned correctly.
Sep 13, 2008 | LG LHD45EL Dehumidifier
Dehumidifiers Logo
Top DeLonghi Dehumidifiers Experts
Mike Kolbay
Level 1 Expert
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
