1981 1983 YAMAHA 60CE OUTBORD MANUAL - Computers & Internet
What year and model is my evinrude outbord motor the only numbers I can find are: A0104016 M
That will be the serial number ,need model number to age it located on the same tag a serial#
Jun 18, 2014 | Boating
How to set timing on 60 hp mariner outbord motor 87 model
You're not asking about a cell phone, are you? You might want to repost this question in a more appropriate area of FixYa, and specify the make and model of whatever device you're asking about when you do.
Nov 30, 2013 | Cell Phones
Hi , i have an evinrude lightwin 3hp 1969, water does not circulate and the outbord is overheating !
2 CRITICAL THINGS:
1. Replace Thermostat
2. Replace Water Pump:IMPELLER, CUP, PLATE(IF APPLICABLE) SEALS & GASKETS
***ALSO: MAKE SURE DISCHARGE AND INTAKE PASSAGES ARE CLEAR
Jul 25, 2013 | Boating
To hook guitar to sound source fendercd60ce
You must have the matching input jack and connecting the guitar cable to the amplifer INPUT and selecting the source will let you play on the guitar.
Check the cables and see they fit correctly.
Oct 18, 2011 | Electric Eyeware Fender Cd-60ce Black...
Yamaha outbord motor will not idle up it did when i first started it but a buzzer came on and it stop revving up
The buzzer is the chock on you may need to manually release it.this should fix your problem
May 08, 2010 | Boating
I need to change a water pump on a johnson 6hp outbord moater. modle no. 6R-70B
unbolt lower unit and you will be right there . shift rods vary so check where it is and how to unhook.
Mar 15, 2010 | Light Outboard Motor Boat Bass Fishing...
The fuel mixter for a 90 hp tracker force power serise outborde moter
Should be 50 to 1. a call to any mercury outboard dealer will give you the exact ratio
Mar 27, 2009 | Boating
Mercury 50 hp outboard
I actually thought it was down by the prop... i was wrong....
Pretty good diagram here.... look at part number 1
http://www.sterndrive.info/mercury-outboard-parts/60hp_to_125hp_component_layout.html
scroll down for the part cost and description.
Robert
Please take a moment to rate this solution.. thanks
Jan 23, 2009 | Computers & Internet
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
