Question about Maytag MSD2454G Side by Side Refrigerator
Maytag Refrigerator Leaking Water MSD2756GEB - Maytag MSD2454G Side by Side Refrigerator
5 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: Maytag refrigerator is leaking water
Your freezer has a drain that leads to the exterior drain pan beneath the unit. Occasionally this drain can become clogged resulting in standing water inside your freezer,due to line freeze over. This can, also, cause a run-off, as stated in your post. In the freezer, standing water will become ice and may result in defrost problems or inadequate coldness.
You will need to Clear the drain by forcing a solution of water and bleach or water and baking soda into the drain line with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog. This will correct the issue.
The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
NOTE_It is important for the refrigerator to be level. If it is not level, doors may not open or close properly and may not seal tightly. Also, drainage from the defrost cycle might be impaired as might the ice making cycle. The appliance was engineered based on it being installed in a level position. While there may be some tolerance for out-of-level installation, the appliance will operate at its best when properly leveled.
Place a level on top of the refrigerator near the front. Do not put it on the door because the door may not be aligned with the refrigerator case. Check that the refrigerator is level from side to side. Next turn the level to check that it is level from front to back.
If it is not level, adjust one or more of the adjustable leveling feet until it is level. The feet are bolts that can be turned to raise or lower the refrigerator. If they cannot be adjusted with your fingers, use a crescent wrench or pliers.
If you have an ice-maker, it should also be checked for level after first leveling the refrigerator. An ice-maker that is out of level will spill water into the ice bin or into the freezer. It can be repositioned by loosening the mounting screws, adjusting it for level and then re-tightening the screws.
Posted on Dec 13, 2009
SOURCE: Maytag refrigerator PTB1949FR, water is
the housing in the fresh food compartment that holds t-stat, damper and defrost timer keeps breaking, 4 times replaced any thoughts?
Posted on Apr 07, 2011
Sea Breeze
  • 4654 Answers
SOURCE: water dispenser will not stop
One of two things that I can think of and one being the switch being broken in the on position where you press the cup to fill. Part Mumber=> 61005520 Item 11 or position 11 in the large photo below. Here is the water control valve that goes to the model; with water filter=> 12001892 Water Control Valve for Filter
It also can be in the stuck on position
12001892 Water Inlet Valve
Click Here for Large View of Fountain Parts=> MSD2756GES Maytag Fountain Parts If you have any questions please ask, Thanks, Sea Breeze
Posted on Apr 19, 2011
bcat913
  • 3 Answers
SOURCE: My Maytag refrigerator is leaking water from under it. Model MFI2569VEM
Just how old your fridge is I don' t know. But is your defrost timer working on your freezer. It should defrost at least once a day. You may want to check out the drain on the bottom of the fridge also. It may be partly clogged up. Then newer models have the coils go over the pan to help evaperate the water.
Posted on Aug 05, 2012
Water leaking from bottom of refrigerator
You have a sheet of ice in the bottom of the freezer? If so, you have a clogged drain line.
Mar 24, 2013 | Maytag PSD2450G Side by Side Refrigerator
Water dispenser will not stop running on my model msd2756geb maytag refrigerator
Apr 19, 2011 | Maytag MSD2756G Side by Side Refrigerator
My Maytag msd2756geb freezer is too cold.
You are probably right that it is always running. This is because the thermostat/sensor has gone bad. The fridge adjusts by a door that allows air to come from the freezer to the fridge side. Therefore this will still work...
You will need to replace or have the thermostat replaced....
Heatman101
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
Feb 04, 2010 | Maytag Freezers
Freezeer and fridge quit working
It's possible that the Adaptive Defrost Control part number 61005988 has your compressor shut down. It is also possible the temperature control is defective. Jumping the 2 wires behind the control will answer that. And its also possible that the start capacitor, start relay and overload has failed on the compressor. I would like you to unplug and examine the ADC and also need to pull away from wall and remove the cover over the compressor so you can feel the top of compressor. Is it warm, cool or too hot to keep your hand there? Sea Breeze
Sep 19, 2009 | Maytag 22.6 cu. ft. Side-By-Side...
Msd2756geb water tube coming out door not hooked up?
Check diameter of pipe. Suspect its quarter inch. You will then probably need to purchase e.g. from ebay etc a 1/4'' to 3/4'' adapter which will allow you to connect your fridge pipe to a typical water pipe connector (i.e. similar connecting a washing machine), assuming you already have an available water conenction in the lcoation of the fridge!
Jun 16, 2009 | Maytag MSD2756G Side by Side Refrigerator
I have a Maytag side-by-side MSD2756GEB that quit cooling.
sounds like either the fan motor or the compressor. go ahead and open upo the bottom baclk panel and see if the fan is running or if the compressor is. could be just a burned wire.
Feb 07, 2009 | Maytag MSD2756G Side by Side Refrigerator
Maytag S/S model # MSD2756GEB
di you see or hear the fan running fan might be stuck check that out no fan no circulating cold air you may have problem with the heating element what make frost free inside you should melt all the ice inside around the damper check if you see broken glass the little heating element if it not broken and listen for that important fan if it running check it uot thank for using fixya pierre
Feb 05, 2008 | Refrigerators
Maytag MSD2454G Side by Side Refrigerator Logo
63 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
