Will trendnet736 still work if the modem and trendnet router are in two different buildings
    Champion:
  • 329 Answers
Distance and obstructions are factors. It may or may not work.
Posted on Jun 06, 2014
SOURCE: Can't get Trendnet TEW-432 router to connect to internet with motorola modem
I had this same problem. I was going to go ahead and call ATT and ask them to put my modem into bridge mode, but I messed around a bit more....
I went ahead and turn on PPPoE...tried to run the set up again. Well it worked. Not the internet connection is working through the modem. For some reason, the setup changed PPPoE back to DHCP Client, but it's working now. Give this a shot before calling ATT if you like. Good luck.
Posted on Jun 18, 2009
SOURCE: how can I set up a speed stream 4100 modem/router
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. here are the steps u need to do:
1. press the reset button on the back of the trendnet router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the trendnet router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe. Im sure if the computer is connected to the speed stream 4100 modem router you can have an internet access. just in case u did a pppoe settings on the trendnet router and ur done setting the router, u did the connection, then u dont have an internet, set the speedstream modem router to bridge mode
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
if you have any querry pls feel free to get in touch.. good luck
Posted on Aug 30, 2009
  • 13 Answers
SOURCE: Trendnet router
I know you've heard this many times by now, but disconnecting the power from the router for about 30 seconds then reconnecting power should work. Obviously not. If your Xbox and laptop are doing the same, then it's not a computer problem; we can narrow it down to the router, the modem, or the internet connection itself (whether it be DSL or Cable). You may end up having to throw money at the problem and purchasing a new router. I'd recommend an 802.11n router from Linksys. If you're not willing to shell out money, even if you are, you should really try the Trendnet web site or giving them a call. You may just need to update the firmware. Try starting with Trendnet since the problem can be narrowed down to your router. Please let me know what happens.
Posted on Jan 15, 2010
  • 103 Answers
SOURCE: Same Problem. Port frowarding not working. Very confusing.
Virtual Server Name can be anything specified by you. Protocol if not sure TCP/UDP, it is better to select "*" which means both. Both public and private port has to be camera's port. Like in your case it is 50001. LAN server is the local IP address of the Camera given by your router's DHCP or a Static Private IP address f0541ce.jpg
Posted on Sep 02, 2010
  • 6 Answers
SOURCE: I have a Westell 7500 DSL Modem (with built in
Try changing the IP on the D-link to 192.168.1.2 .
Posted on Dec 29, 2010
Does the internet modem and the trendnet router have to be in the same building
No, unless the distance is to great in which case the signals attenuate.
Dec 27, 2013 | Trendware TEW-432BRP Wireless Router...
How do i cable 10 computers, a docsis 3.0 modem, 8 port edgewater 881 router and 5 port trendnet TEG-S5G unmanaged switch
Connect 7 computers to the 881 router. The last port on the 881 router go to Trendnet switch. Connect the last 3 computers to the Trendnet.
Feb 11, 2013 | Computers & Internet
My TrendNet modem has the "System" light always
Hello
Your going to need to log into the modem/router.Check with manufacturer on how to log in.
Once logged in there should be a page, to turn wireless on.
Here is a link to your router user manual.
http://www.trendnet.com/downloads/list_subcategory.asp?SUBTYPE_ID=1504
Oct 19, 2011 | Trendnet Wireless Home Router TEW651BR
How can i connect a trendnet (tew-652brp) 300mbps wireless router on aevdo wireless modem
depending on what you are doing with the two devices, there are a bunch of different answers. usually connecting two like devices requires a crossover cable. This is different from the traditional straight-through cables that you can buy at walmart. but for simplicity sake, use a crossover cable
May 09, 2011 | Trendnet TEW652BRP 300 Mbps WiFi N router...
Error 103
This may or may not be of help, but this is easy enough to try....
Power off computer, cable modem, and router.
Connect router to cable modem via WAN port, PC to router via LAN port
Power up cable mode first, wait until for connection light
Power up the router, wait about a minute
Power up the PC
I have Cablevision and have had an issue when you are going to connect a different device directly to the cable modem (eg router instead of PC), you need to reset the cable modem first or it will not work.
The following link shows you how to log directly into the router and run the setup Wizard from the router.
http://www.trendnet.com/kb/kbp_viewquestion.asp?ToDo=view&questId=1442&catId=524
Apr 09, 2011 | Trendware TRENDnet TEW-432BRP Cable/DSL...
Hi, I'm an idiot! PLEASE HELP
you may be suffering from mixed Cat 5 and Cat 6 cabling.
The wiring is slightly different and they don't work well when mixed in routers and modems etc. One or the other will work , but when they're mixed it'll do what you have going on here...
I would recommend wiring everything with cat 6 ethernet cabling. Look on your cable and you will find the labeling on the outer casing.
Sep 20, 2009 | Computers & Internet
Trendnet router
Dec 27, 2008 | Belkin (F5D9230-4) Wireless Router...
How to solve it???
your trendnet is just a router and it should work with any ISP whether if it's cable or dsl. you just need to connect it to the broadband modem provided by your ISP and configure with the correct settings.
with cable conncetion you just simply connect the ethernet(LAN) port of the modem to the internet(WAN) port of the router. then perform a power cycle by turning all the devices off. after that, turn on the modem first and wait for the lights to lit up before powering on the router and the computers. if this will not work you need to access the router's page and perform a mac address clone.
for dsl connection, you need to get the username and password of your internet account from your ISP then set your router to PPPoE or PPPoA.
you need to also check that your modem and your router has different ip addresses to make them connect to each other properly.
hope this'll help you but if you still have the same problem, just give me the exact model of your modem and who is your ISP
ciao!
Aug 01, 2008 | Trendware TEW-432BRP Wireless Router...
May 13, 2008 | Trendware TEW-432BRP Wireless Router...
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
