Question about JBL BP600.1 Car Audio Amplifier
How to bridge jbl bp600.1
Wiring dvc to 2ohm
2 Suggested Answers
  • 73 Answers
SOURCE: Amp has no sound
it is posible that you used a power cable that is too small i guage and smoked the power supply
Posted on Jul 28, 2010
I have a kx800.2 and two 10' dvc @ 2ohm. Do i need to bridge tha amp or would it be better to use both channels
use both channels. if you bridge it and run to 2 speakers you will en up with the same power drop per speaker as you would if you ran it in stereo. also if you bridge it you will be running mono in stead of stereo for no reason.
Oct 14, 2010 | Kicker KX800.2 Car Audio Amplifier
Amp has no sound
Jul 27, 2010 | JBL Car Audio & Video
I got two 12'' 800rms subs n a powerbass asa600.2 class a/b amp i need to kno the best wiring diagram... subs are dvc 4ohm & the amp is 4ohm 2ohm & can be bridged to 1 channel..
Use good quality wires-- the cost is the factor for high connectivity with low resistance- You can bridge the two sub's in parallel to the 2 ohms output of the amp. Please be careful to see the likeness of polarity of the subs to the amp. or lese you will get a phase difference resulting in poor low frequncy.
Jun 25, 2010 | Car Audio & Video
How many svc subs at 4ohm does it take to get this amp to 1ohm stable and can you reccomend a good sub combo for this amp whether it be dvc or svc
It depends if your sub is 4ohm svc, or 2ohm svc. 4ohm would take 4 subs wired in parallel, 2ohm would take 2 subs wired in parallel. But for a amp that big, subs that'll handle it are definitely gonna be dvc. I'd recommend 2 Orion 4ohm dvc hcca's. They come in either 15in or 12in. the 15s are louder if you have the space for them. As far as wiring goes, wire the voice coils on the subs in parallel to 2ohm per sub, then wire the 2 subs in parallel to 1ohm. Goodluck and congrats on the equipment, Orion is about as good as you can go for subs and amps. just be ready to lay down some dynamat cuz this system'll bloww your vehicle apart! good luck...
Oct 08, 2009 | Orion 2500D Car Audio Amplifier
How do i bridge 2-4ohm dvc's to a mono block
If you have a DVC 4ohm speaker, and you are using both voice coils, the amp is seeing a 2ohm load.
If you bridge the amp, you CAN run both subs as long as the amp is Two Ohms Stable.
Wire each subs voice coils in parallel.(Positive to positve, neg to neg.) (2ohms) each.
Then wire the two subs in series.(Neg from amp to neg of sub one, pos of sub one to neg of sub two. then pos of sub two to pos of amp.
If it sounds too hard, leave it as you are already running the amp at two ohms.
Sep 13, 2009 | Car Audio & Video
Amps on woofers are fine just won't hit
your probably making your amp run to low ohms if its a 2 channel amp bridged to one channel you can probably only run it at four ohms
Also seeing as your subs are 2ohm dvc you can't wire them individually to 2ohm and use each channel separately. So i'd recommend buying a 2ohm stable monoblock or running it at four ohms. a 1400 watt amp'll still pound at 4ohms and it'll extend your amp's life span
Aug 29, 2009 | Pioneer GM-7200M Car Audio Amplifier
I have a Pioneer GM-5300T amp wired to a 10 inch kicker sub. The music plays throughout the speakers of my car but the sub goes in and out. I noticed that the amp's power light dims when the sub goes in...
Hello pburgfootbal,
You do not specify which Kicker sub you have or how it is wired to the amp. The GM-5300T is only stable to 4ohms in bridged mode and if your sub is a 4ohm DVC with the coils in parallel, it presents a 2ohm load. If the sub is 2ohm DVC with the coils in parallel, the load is only 1ohm. Either configuration would be too low of an impedance for the amp in bridged mode. I'd check the sub specifications and make sure that the wiring configuration properly matches it to the amp.
Hope this helps.
Jul 31, 2009 | Pioneer GM-5300T Car Audio Amplifier
Hi,just bought a 6x9 jbl gto937 speakers for my car,each speaker is 100watt rms and 300 max .Can anybody advice on what amplifier should i get for them?I know i can run them without any amp but think they...
Pyramid makes the PB series of amps. I have one that's driving a Sub.
The PB 700 puts out rms 60watts x 2 @ 2ohms, which gives you some "headroom" for your speakers. You don't want to over drive speakers with , for example, a 1000 watts for 100 watt speakers, because that's a good way to blow your speakers.
There are many brands and models of amps that will fit your speakers. Just make sure the amp will drive 2ohm speakers, since your jbl's are rated at 2ohm impedance.
You may want to consider adding a Sub woofer to your setup. A single Sub would fill in the low end very nicely. If you got a 4 channel amp, then two channels will drive your jbl's, and you can bridge the other two channels to drive the Sub. That would be a kick'n sound!
Just make sure the amp is bridgeable
For example, the Pyramid PB 1200 is a 4 channel, bridgeable amp. This particular amp will drive the 2ohm jbl's, but you would want a 4 or 8 ohm Sub connected to the bridged channels.
Jul 05, 2009 | JBL GTO937 Car Speaker
How do you wire four 12 inch kicker cvr dual voice coil, to a 2400 watt 1 channel class d amp
Hello brysonford00,
The wiring configuration depends on what final impedance you want the amp to see. If the subs are 4ohm DVC's, you can wire them to present a 2ohm impedance or an 8ohm impedance. The diagrams are here. If your subs are 2ohm DVC's, the wiring is the same. The impedances will be 1ohm and 4ohms.
Hope this helps.
Jun 07, 2009 | Kicker CVR12 Car Subwoofer
Wiring Diagram
i HAVE 2 12 KICKERS L7 RUNNING ON A PERFORMANCE TECHNIQUE AMP 2000 WATS THE ampl its a mono //and i want to know how to wire the speakers
Jul 26, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
JBL BP600.1 Car Audio Amplifier Logo
Top JBL Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Mark Skinner
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
