Question about Blanco Plumbing
Blanco master gourmet faucet leaking - Blanco Plumbing
gary1121
  • 332 Answers
SOURCE: Leaky Blanco Single Lever Kitchen Faucet with separate sprayer
you can call or e-mail the company, if the faucet is the one in the picture it is a single cartdridge, turn of bith hot and cold water, take an allen wrench into the little plastic cover to remove the handle , unscrew the top cover or it might pop off, that there is either a large lock not or 3 screws holding down the cartdridge, take it out replace it put some faucet frease around all rubber gaskets then install it in the smae way it came out
Posted on May 30, 2009
  • 1584 Answers
SOURCE: Blanco harvest kitchen faucet with pullout spray low flow rate
Check fine filter at tip, probably blocked, got caught with same thing myself recently!!!
Posted on Jan 26, 2010
  • 349 Answers
SOURCE: remove water saver device from Blanco Grace kitchen faucet
Remove the aerator at the end of the spout. It will unscrew and once off it will have a dime sized restricter in it that can be removed this restrict's the water down to about 1.6 gpm to save water.
It will either be plastic or metal and about the size of a dime with a small holw in it to let water pass by maybe 1/8" hole just remove it and put aerator back together.
Clean aerator screen out before you put it back together.
http://www.plumbersurplus.com/pdf/07163.pdf This link has a breakdown of parts. Look at parts 8b-10 for aerator breakdown.
Posted on Jun 13, 2010
packrat1948
  • 528 Answers
SOURCE: My Blanco Torino faucet is
Check the hose connections at the spray head nozzle it sounds like it is leaking there and running down the hose and ending up under the sink.
Posted on Feb 08, 2011
  • 8 Answers
SOURCE: leaking blanco single handle faucet with sprayer
minarl deposit bildup in the handol best to just replace the sprayer any hardwer store hose is still good only sprayer head needs replaced comen threds
Posted on Mar 11, 2012
Leaking at collar
Check youtube videos posted by Blanco on how to fix their faucets.
Apr 08, 2014 | Blanco Classic Single Handle Faucet with...
Leaking blanco single handle faucet with sprayer
Mar 11, 2012 | Blanco Plumbing
How do we repair leaking faucets and clogged drain
Hi. To fix leak, replace cartridge in valve. To clean out drain, Clean out trap under sink.
Jun 09, 2011 | Blanco Classic Single Handle Faucet with...
My Blanco Torino faucet is leaking under the button when you press the button on top to use the spray.
Feb 08, 2011 | Blanco Classic Single Handle Faucet with...
I have a blanco kitchen faucet that is about 5 years old. it seems to be leaking from inside the unit itself , problem is , trying to figure out how to get it apart to repair it.
behind the handle there should be an allen screw under a crome cap . once you reove the screw the upper metal ring should just unscrew then there are a series of o rings that can be replaced
good luck James
Dec 26, 2010 | Blanco Classic Single Handle Faucet with...
I have a single handle blanco classic that is leaking around the base I have removed the handle and cartridge but cant figure out how to remove the sprayer to replace the seal
You need to turn the water off under the sink. Disconnect the sprayer hose from the threaded shank under the center of the faucet body. Pull the spray head out of the faucet. Contact Blanco to receive your faucet parts free.
Nov 06, 2010 | Blanco Classic Single Handle Faucet with...
Leak from blanco aderlphi tap above sink line may be a washer required
this could be a leaking cartridge or more likely a likely a leaking o-ring that sits around the base and seals the joint between the spout and the base
Jul 01, 2010 | Blanco Plumbing
Jan 26, 2010 | Blanco Harvest Single Handle Faucet with...
May 30, 2009 | Blanco Classic Single Handle Faucet with...
You only need one small o-ring. If you put two of them it will not work properly and will mostlikely leak like crazy. If this helped please rate.
Feb 12, 2009 | Blanco Classic Single Handle Faucet with...
Plumbing Logo
87 people viewed this question
Top Blanco Plumbing Experts
Mack Baxter
Andrew Bugbee
Are you a Blanco Plumbing Expert? Answer questions, earn points and help others
