Question about Coffee Makers & Espresso Machines
Nespresso serial number
Where can I find the serial number on my new Nespresso Essenza M100 auto
  • 537 Answers
SOURCE: Help I Lost the directions
https://secure.nespresso.com/precom/manuals/pdf/C100_Zone1_EN.pdf
Posted on Dec 13, 2007
  • 5 Answers
SOURCE: nespresso essenza problem
It's not supposed to make holes in the capsule until the water comes through. So, basically, when you put the capsule in, it pierces the capsule in three spots, on the top. The aluminum part will not pierce until you press the button and water comes through. If water is not coming through, then you can clear the air bubble by opening the lever on top of the machine, pressing the coffee button, and then closing the lever once the water begins to come through.
Posted on Aug 30, 2009
  • 23 Answers
SOURCE: nespresso essenza en90,o
I opened up my krups nespresso xn 2105 essenza C100N machine today. It was not starting up quick enough, so silly me decided to dunk it in hot water. My nespresso is an automatic, it has the on/off switch down in the back. My guess is the water that went in there is what is killing the house fuse now. So I really needed to open it up. Not knowing how to proceed, I looked at fixya first, No details yet. So here is what I did.
I looked at the screws, (post on fixya suggested they are screws) at the bottom. There is 6 of them. They look like rivets as if they have been made into round blobs after putting them in. So I took a dremel-like small grinder (a really small drill would do better) and made two small notches on the side of each one. Be careful not to chip away too much plastic of the machine ;) Then I used very small and long pliers to get them turning. That is actually easy, they are lightly set in plastic. Hard part is to keep the pliers from sliding off. Actually once loose the most of the turning I did using a narrow rubber tube, I guess you could use the rubber on the back of a pencil as well. So, remove 6 bottom screws, actually you can remove the sides now. This gives you access to the area where you can see all the wiring and many of the parts. For me I needed access at the bottom, so I removed two more screws near the bottom, and removed the bottom plate. The on/off switch for the automatic sits down the back of the machine, there is one additional screw (six pointed star shape) in the internals for this. I did pull off the switchy bit of the switch - do not do this as springs andcontacts fall out... Mine also still has water in there so I guess I found my problem.
Well, thet is how to dissassemble. I will have to find out how to reassemble tonight, to be able to get my wife het coffee in the morning ;)
Posted on Oct 17, 2009
  • 21 Answers
SOURCE: water not coming through nozzle of nespresso essenza
I have had this issue. I have removed round silver plastic piece from around coffee spout,(gently -do not crack it) I then removed and washed the black spout, I even used a toothpick once, to remove the stubborn coffee ground, Once it was cleaned - it worked perfect. If you run water from the faucet into spout it should flow smoothly. I warn you though, not sure what this does to any warranty, but don't mess with my morning coffee! I hope this helps.
Posted on May 08, 2010
SOURCE: light don't stop blinking .... Nespresso Essenza C100
My guess is that the Essenza is in 'Descaling' state. See section 7 of the essenza manual. To get out of it, hold both the buttons down for 3 secs. The lights will then blink at normal rate for a bit and then turn solid.
Posted on Jun 28, 2011
My Nespresso C101 shows flashing lights when turned on, but when buttons pushed for coffee, nothing happens and pump doesn't operate. Do I need new pump and is it worth fixing?
Hello, Paul -
I found the user manual for the Nespresso C101 online:
https://www.nespresso.com/shared_res/manuals/essenza/2012/www_Essenza_C101_Z1_NESPRESSO(EN_FR_ES_BR).pdf
In the Troubleshooting section of the manual (page 14/image 16) for the problem of "irregular interval blinking" the solution given is to call the Nespresso Club.
Page 19 of the online manual gives a full list of Contacts by country name.
Best wishes.
Feb 17, 2018 | Nespresso Coffee Makers & Espresso...
Nespresso Essenza 90 leaking at the bottom seam underneath the used capsule holder, HELP
Try gluing the seam with lock tight glue or similar plastic gluing compound. Let it dry overnight and try again.
Oct 16, 2014 | Nespresso Essenza C90 Espresso Machine
Does anyone know how to pull apart a Nespresso coffee maker ?
Most expresso coffee makers can be taken apart manually.
Start removing screws, nuts, etc. Take a picture every so often so you know how to put it back together.
See the DeLonghi website to get eerie product manuals. (delonghi.com). Search harder for repair parts and you often can get the sequence of how the parts assemble.
You are right, cleaning the jets is the biggest problem area.
Jan 23, 2018 | Nespresso Essenza C100 Espresso...
Where to buy replacement water tank for Nespresso Essenza C100
I need to find a replacement water tank for my nespresso essenza C100 coffee machine. Mine broke, any ideas where I might be able to find one?
Jan 12, 2013 | Nespresso Essenza C100 Espresso...
Nespresso essenza lever stuck
My Nespresso lever won't push back and it won't produce any coffee from capsule that is stuck in machine.
Jun 13, 2012 | Nespresso Essenza C100 Espresso...
How do I get replacement parts for my Nespresso C100 Essenza?
you can find them by searching on amazon. click here Amazon com nespresso replacement parts. Hope this was helpful. cheers
Jun 09, 2012 | Nespresso Essenza C100 Espresso...
WHEN SWITCHED OFF, WATER LEAKS AT THE BASE OF NESPRESSO C100 MACHINE
I opened mine when this did this - it also happened to my second Magimix Nespresso Manual machine. A short pipe carrying pressurized water had burst. I called Nespresso . parts were not available and they offered me a new half-price machine. We are talking a 4 inch piece of plastic tubing here. Shame on you Nespresso for encouraging me to throw what is otherwise a fine machine....
Nov 14, 2010 | Nespresso Essenza C100 Espresso...
Light don't stop blinking .... Nespresso Essenza C100
Jun 21, 2009 | Nespresso Essenza C100 Espresso...
Dec 13, 2007 | Nespresso C100B Essenza Single-Serve...
Coffee Makers & Espresso Machines Logo
24 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
