Question about Dryers
Clothes getting caught in drum of Kenmore dryer
There was a plastic ring that came off my dryer drum but have been issues with clothes that have strings attached and getting stuck on the dryer drum. I had a repairman come in today and he said even if he replaced the plastic ring, the gap is too big and would need to replace the drum. Is that correct? The cost of the drum and labour alone I figure I should just buy a new dryer but my dryer is only about 5 years old. I had issue with dryer when it was new as well and in the first six months I placed a service call and they put felt around the dryer drum.
    Top Expert:
  • Dryers Master
  • 43,014 Answers
The repairman is trying to upsell you to a replacement drum. The felt sealer can be an expensive item to replace. Go to www.repairclinic.com and enter the model of your dryer. With luck, you will be presented with a list of common replacement parts that will give you some idea of cost.
Posted on Apr 29, 2017
ginko
  • 19396 Answers
SOURCE: dryer not hot
Tht means that the element is not heating on.
You need to call a technician to test the element, the thermic sensor, and the control assembly.
The most likely is a defective heating element, that must be replaced.
Posted on Jan 31, 2009
  • 1122 Answers
SOURCE: Brown marks from Kenmore dryer
do they look like burn marks??????
Posted on Mar 13, 2009
  • 84 Answers
SOURCE: Frigidaire dryer drum liner
yeah, i think there called "drum glides" www.partselect.com type in your model number and you if they have that dryer in the system, then breakdown of the dryer will show, multiple diagrams. And look for the glides that are supposed to go there...hopefully this helps
Posted on Jul 31, 2009
heatman101
  • 43501 Answers
SOURCE: The dryer drum seems to be out of alignment
I think that the real problem you are having is because of wear in the guide wheels that hold the drum. The easiest way to see where the guide wheels are and to get replacements is to do a search for "appliance parts" you will get a number of different parts sites come up.
Enter your model number and the sites will have exploded views of your dryer. You can see from these where the guides are and also get replacements.
Check a number of sites as the prices can vary greatly from site to site and there is no one site that seems to be always the best price.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Dec 01, 2009
sonicboomele
  • 1557 Answers
SOURCE: The grey "felt" padding around the circumfrance of
this is a common problem with dryers in most cases the glide runner (felt ribbon) wears out and needs replacing but if the belt is ok then it simply needs gluing back on as there is large amounts of heat you will need to use an apoxy application glue. simply re adhease it to the barrel
best of luck
Posted on Dec 28, 2010
Clothes getting caught in Kenmore dryer
The bearings under the drum may have failed, making the drum drop, so the gap is bigger. Replacing drum or bearings is a lot of work, cheaper to replace the dryer. Or you could make a plastic ring yourself that is thicker to fill the gap....
Dec 27, 2013 | Dryers
Leaving spots on clothing
Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set.Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Dec 24, 2010 | Kenmore Dryers
Maytag dryer is leaving black marks or rings on clothes
If your clothes get marked or torn in your dryer, check these: Rollers Rear seal Front glides Front seal Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Aug 01, 2010 | Maytag Dryers
Clothes are getting caught and torn
yes. your drum gasket is bad
May 24, 2010 | Dryers
My dryer leaves burn marks on the clothes. What
Hi. Thanks for using fixya. I can help you. When clothes get marked or torn in your dryer, check these: Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it. small_8_13.jpg
Nov 09, 2009 | GE DBL333EA Electric Dryer
Clothes get stuck between dryer and barrel
If your clothes get stuck, marked or torn in your dryer, check these:
Rollers
Rear seal
Front glides
Front seal
May 31, 2009 | Electrolux Kenmore 5.8 cu. ft. Super...
Drum spins off center and clothes get stuck between drum and casing
Rollers
Rear seal
Front glides
Front seal
May 28, 2009 | Kenmore Dryers
Money (change) caught inside interior drum plastic pieces.
Remove the top lid.
Rotate the drum until a vane is at the 12 o'clock position.
Remove the screws from the drum holding the vane in place.
May 10, 2009 | Kenmore 63942 Dryer
Burnt lines
Your problem is a bad rear drum seal-if these become worn, torn, or missing close can get caught torn or discolored in the space between the clothes drum and rear of the dryer. Replace the rear drum seal.
Aug 13, 2008 | Kenmore 98702 Stacked Washer/Dryer
Torn clothes
Rollers
Rear seal
Front glides
Front seal
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Mar 30, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
37 people viewed this question
Top Dryers Experts
