Question about Bosch Classixx KGV24323 Bottom Freezer Refrigerator
Red light is on and fridge is not cold - Bosch Classixx KGV24323 Bottom Freezer Refrigerator
Temperature light at back of fridge randomly goes from red/green and the temperature in the fridge does not appear to be stable?
on a fisher paykel I would call them direct, their help desk can walk you through some checks to see what the error is... if I needed service on this unit I would use who they suggest.. because if the servicer does not have access to the factory on FP HE IS GOING TO BE GUESSING WITH YOUR POCKETBOOK in hand... we work on FP everyday and we call often....... I hope this helps.... ken
Sep 29, 2014 | Fisher and Paykel Refrigerators
How do I hook up water andice maker?
Hi i have a hotpoint fridge freezer both my lights are on at the top,1 red 1 green,my freezer does not seem to be cold enough,there is also little drops thats can be set to 1 or 2 what are they for? Think my food in freezer will need to be binned but my fridge is very cold.
Jul 27, 2013 | Frigidaire FRS26RLECS Side by Side...
Fridge freezer isnt cold as normal
I have a Servis Fridge Freezer but the fridge is not as cold as it should be I think it just seems cool because the Freezer compartment is working
May 24, 2010 | Refrigerators
Red alarm light is on on Westinghouse upright freezer
Most probably during transportation either the coolant(previously freon gas) may have leaked out so the pressure on the cooling pipeline causing the red alarm because the compressor will overheat if the fridge is kept running at very cold thermostat readings and no effect of cooling the fridge will ultimately result in the compressor getting burnt. However fist have look at thermostat setting knob which could have loosened during transportation and just pushed into the spindle without knowing the correct angle, thus even though it looks as if on high cool but could also be the lowest setting..........sodeep
May 19, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
I have a Beko fridge freezer just over a year old. This is kept in an unheated garage and has just stopped working. The light is on so the power is OK. The manual does say that thew fridge should not be...
Switch off fridge unscew & lower stat & light housing, note positions of blue doulble wire & red/grey, the blue wire spade is permanent live for light, fit red/grey to this spade the motor should then run,I let it run for 5mins then replaced wires to there normal position,I think it is due to fridge not running enough when cold. it worked for me so try it. (at your own risk.) best of luck.
Dec 04, 2008 | Refrigerators
Red light on Hotpoint Iced Diamond freezer
got a hot point iced diamond fridge/freezer, just got back off hols and red light on, all food defrosted with water running out of bottom. whats wrong?
Aug 27, 2008 | Refrigerators
Hotpoint FFS70 fridge/freezer
This is normal  the red light tells you that there is a slight of decreased in coldness .Eventually the red light will  disappear after the refrigerator has recollected it's coldness... in 24 hours approximately .....Jack Arevian.(.Aleppo Syria).Refrigeration Engineer...........
Oct 16, 2007 | Hotpoint FFS70 Bottom Freezer Refrigerator
Bosch Classixx KGV24323 Bottom Freezer Refrigerator Logo
16 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
