Question about Microwave Ovens
LIGHT BULB REPLACEMENT
HOW DO U CHANGE THE LIGHT BULB IN A SHARP MICROWAVE #R-420CW????
  • Microwave Ovens Master
  • 9,047 Answers
You'll have to unplug it and remove the outer cover, then the bulb is located in a holder in the cooling duct attached to the magnetron on the right side of the unit.
We have a similar service / repair manual for this model and have uploaded it to our site here to help you.
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
You can order it ahead of time from Encompass here or you can call them toll-free at 866-779-5835.
Posted on May 20, 2009
HOW DO i CHANGE THE BULB IN MY SHARP R-651ZM MICROWAVE OVEN
Changing the light bulb on your Sharp carousel microwave will allow you to have needed light inside the oven. Microwaves are not designed for consumers to change the light bulb due to manufacturer liability, but it can be done. Following the proper steps will ensure a successful installation. Step 1 Unplug the Sharp carousel microwave from the electrical outlet.
Step 2 Locate the screws around the outer cover of the Sharp carousel microwave and unscrew all the screws.
Step 3 Lift off the covering.
Step 4 Locate the bulb and unscrew. Screw in your new bulb.
Step 5 Replace the cover and screw back tightly. Once done, test your new bulb.
Oct 10, 2017 | Sharp Microwave Ovens
How to change R-430cs light bulb
You have to take off the cover off the microwave and you would see an plastic cover on top off the bulb.One screw should be holding the cover, take it off and you should be ready to change the bulb.
Sep 05, 2014 | Sharp R-430CS Microwave Oven
How do I find a replacement light for my sharp r-320fw microwave
Sharp Carousel Microwave / Light bulb replacement: http://youtu.be/36RE1bG0aVk
Check out this video, it may help you. Looks like they're a common bulb.
Sep 03, 2014 | Sharp Microwave Ovens
How do I replace the bulb for the display panel of a Sharp Microwave oven Model # R-314F ?
Normally switch power off and remove plug from wall socket, undo screws around side and back panel and remove outer cover, then the light socket will be visable so change light bulb and reassemble, CAUTION: high voltage may be present so best left to service person for safety
Jul 23, 2014 | Sharp Microwave Ovens
How do I replace the light bulb in a Sharp R-308KK microwave?
Google the model number with "how to change bulb" and there are some with video instructions on You Tube the Google searches should also bring up.
Nov 07, 2012 | Sharp R-308KK / R-308KW 1100 Watts...
How do i change light bulb in sharp carousel R-320HQ microwave oven?
open cover and
change bulb
before open it turn off woven at last 30 minutes
Jan 30, 2011 | Sharp R-320HQ Microwave Oven
Replacing lightbulb in Sharp R953M combi microwave oven
most microwave ovens built in the last 20 years do not have an
access panel to the light bulb. you must remove the screws on the back of the microwave that hold the outer sleeve in place.
Then pull upward and backward on the sleeve to disengage it
from the front lip of the chassis. the light bulb should be close to the front of the microwave behind the control panel. Some lights
are not unscrewable from the socket, but the socket and bulb
come as an assembly.
Mar 26, 2008 | Microwave Ovens
Sharp MICROWAVE CONVECTION R-8465
I fixed it by reading how to fix another model. What you do is take the cover off, the bulb is on top. Make sure that you unplug it before starting.
Jan 12, 2008 | Sharp R-320H Microwave Oven
Where is the light bulb in an old Sharp Carousel Microwave?
Microwave_svc's site is awesome! I was able to get all the help I needed for a similar Sharp Carousel microwave. My bulb was simply loose in the socket base causing intermittent bulb lighting. Microwave_svc's helpful links got me to the service manual and, along with a nice set of "tamper-proof" screw compatible TORX bits I bought at HarborFreight, I was easily able to get cover off, remove bulb socket, tighten bulb, re-install bulb socket, button unit back up, and, voila, the light now works without intermittent blinking. FIXYA!!!!
Many thanks to guru microwave_svc!!!!!!!
Nov 21, 2007 | Sharp R-510HW Microwave Oven
Microwave Ovens Logo
386 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
