I cannot find a manual for the Vokera 7 day room thermostat code 20059643 and it is not easy to use
2 Suggested Answers
  • 12 Answers
SOURCE: How to wire tower rs room thermostat to Vokera
if you go on thier web site you can down load a manual
Posted on Nov 01, 2009
Vokera boiler problems
need to change thermostat and a thermocouple
Jan 28, 2014 | Water Heaters
Noma thermostat HFD2003SL2D manual
You're in trouble when google search for your product shows fixya as page 1 results.
Re-post your question on fixya and provide link to photo of your product so better identification can be found.
Or buy a Honeywell thermostat because that company posts all manuals online using product number located on back of each thermostat.
Jun 10, 2012 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
The heater will not kick on. It's a programable 7 day that reads 69 degrees and if I arrow up to 72 degrees, nothing happens
Change Temperature Setting Until the Next Program Period (Temporary Change)
? Press UP Arrow or DOWN Arrow until the screen shows the desired temperature setting.
NOTE: The temporary temperature setting is displayed for about 3 seconds and then the room temperature is displayed.
Temporary appears in the display. The setting cancels when the next program period starts or when
you press RUN PROGRAM.
Change Temperature Setting Indefinitely (Hold)
? Move the System switch to the desired position (Heat or Cool).
? Press HOLD TEMP then UP Arrow or Down Arrow to change your setting if desired. (The display changes from showing the setpoint
temperature to room temperature after approximately three seconds).
? To cancel Hold press RUN PROGRAM.
The downloadable manuals for this t-stat are here, and the addendum, here. Page 17 and 18 detail thermostat operation I have copied above. It has graphic representations of keys that do not copy over very well, so if you have questions about the steps above, you should view the manual in the links provided above.
I hope this helps! Please take a moment to rate my reply - thanks!
Dec 23, 2010 | Honeywell CT3600 7 Day Electronic...
E1 code flashing
E-1 Room temp sensor which if fixed in front of the coil is defective replace it. Helpful?
Dec 20, 2010 | Carrier TSTATHPP 7-Day Programmable...
If i am away for any length of time, do i put the temp on vacation? does the water still get warm?
Since you didn't provide the brand & model of the thermostat, only generic help can be provided.
Most furnaces that run on oil or gas, make hot water all the time, 24 / 7 - winter, summer and everything between so to speak. They are controlled by an aquastat that may be set for any value between 140 - 180 degrees F. This is called "hot start" - simply because when the thermostat is set to a temperature higher than the room (turning heat ON), the water is already hot in the furnace, and is circulated immediately. If it was a "cold start", you'd have to wait for the water in the furnace to heat up from room temperature. This would substantially increase the amount of time it would take to heat the room.
Generally, the "vacation mode" simply halts the program from running. If your thermostat changes temperatures several times during the day / night, it will simply hold the lowest temperature - or a predetermined temperature built in - or chosen by you. You'll need to consult your manual to determine just how your thermostat handles the vacation mode setting. Post again if you can't find the manual - but tell us what brand and model it is.
I hop ethis helps - good luck!
Many heating thermostats don't allow for setting a temperature below 45 degrees F so freeze ups shouldn't be a problem.
Sep 30, 2010 | Heating & Cooling
How to wire tower rs room thermostat to Vokera unica boiler
Oct 30, 2009 | Heating & Cooling
No power
check transformer in furnace... thermostats get there power from it....not the room its in
Mar 15, 2009 | Honeywell Electronic Programmable...
Replacing Round Honewell Mercury Thermostat
try to get one that is made for oil heat, the installation is easy only two wires, and the instructions make it easy.
Oct 23, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
103 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
