Question about Optics
Took apart trigger and sping mechanism, need assembly instructions and diagram to put back togeather again
Took apart gun for a barrel restriction, cannot put trigger and spring assembly back together again. need a diagram and assembly instructions
  • 243 Answers
For what gun?
Posted on Jun 22, 2014
5 Suggested Answers
  • 73 Answers
SOURCE: I took my Crosman Recruit pellet gun apart, i have
hi download pdf exploded view here.
http://www.crosman.com/pdf/manuals/RCT525%20EVP.pdf
Posted on Jan 13, 2010
Adrian762
  • 425 Answers
SOURCE: i took apart my crosman .177 pellet rifle, and
See the answer:
http://www.fixya.com/support/t4047835-put_trigger_back_together
Posted on Feb 08, 2010
agent91
  • 2100 Answers
SOURCE: winchester model 88. with the trigger assembly
Less Than Perfect
The Model 88 had its faults. The trigger moves with the lever and the resulting linkage to the sear results in a rather spongy, creepy trigger break. If you want to see your gunsmith turn pale, waltz into the shop with an M88 and ask for a crisp three-pound trigger.
If you already have taken the gun apart, don't be afraid to hone the parts on a stone , keep them flat, you don't want anything rounded off. Especially the sear. I found that quote up top from a winchester sight,
Posted on Feb 22, 2010
miket756
  • 2702 Answers
SOURCE: Barrel will not stay open when broken for loading.
bad triger,,,getb it fixed,,,as for the bent barrel they bend if you let them spring back a lot!
Posted on Sep 06, 2010
Diagram trigger
Not without knowing what MAKE/MODEL the trigger assembly came off of!
Aug 22, 2014 | Optics
How to take a part a model 31 shotgun schematic to show how to take it apart
Make 100% sure it is unloaded before you start. Open the action a little bit, then unscrew the barrel nut until you can see space between the plunger and the detent. Turn the barrel and magazine assembly 90 degrees and pull it out (yes, the 31 is a takedown gun). Push out the big pin in the receiver from right to left (looking down on the gun from firing position). Turn the gun upside down. Push the trigger assembly toward the front of the gun until it aligns with the slots, and pull the trigger assembly out of the gun. For BASIC disassembly, most users should stop here. The slide/bolt assembly is a little more complicated, and unless you have some patience, experience, or mechanical knowhow, getting them back together can be a little frustrating. For those who want to go farther, look up a copy of "The NRA guide to Firearms Assembly," or find a M31 manual on E-bay for under $10.
Read more: http://wiki.answers.com/Q/How_do_you_disassemble_a_model_31_Remington_shotgun#ixzz176Xpe7hJ
Dec 04, 2010 | Computers & Internet
Gun leaks
Hi, there is a spring in the handle, to enable the trigger; is this what you mean. If so look to see how the trigger works and there is space for this sping to slot into. It can be quite fiddly to get this right!
Jul 27, 2010 | Karcher K 3.98 M Electric Pressure Washer
The shaft or pin that drives the nail does not retract on my mastercraft 3 1/2 framing nailer. #58-8434-4
take the back cap off of the nailer. There is another loose cap in that head, most times that gets stuck. Believe me, I was raised by a carpenter that had nail guns before anybody else did. Also, sometimes that plunger gets bent, just straighten it out. Check for blown o rings. If it is old, take the trigger assembly out and clean it out. Be sure to oil everything well before you put together. We use marvel mystery oil, or nail gun oil.
Jul 08, 2010 | Air Tools & Compressors
Air leaking aroung the trigger assembly from my Hitachi NR83A
if you took the trigger apart the part that you unscrew has a nylon ball and a black rubber ring you should check them and make sure that you didn't loose them when you took it apart,if they are there, then you need to service the gun, and after you clean all the moving part and you put it back together, it may still leak from the top,Take a rubber hammer and give it a good hit,now not to hard, and it should seal
Apr 27, 2010 | Hitachi NV45AB2S Coil Roofing Nailer
Out of order
from a gun shop
Nov 03, 2017 | Crosman (4032)
Fell apart!!
the transmission comes in assy. all u can do is to match the gear & test every small installed. if it's dw997 see www.erplacementparts.com for your guide how to re-assemble.
if dw988 trans diagram see similarity on how to put it back.
Aug 16, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Optics Logo
350 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
