Question about Bosch Nexxt 700 Series WFMC6401UC Front Load Washer
Bosch nexxt 700 door hinge is broken - Bosch Nexxt 700 Series WFMC6401UC Front Load Washer
  • 139 Answers
SOURCE: Bosch dryer nexxt 500 (wtmc3521uc) broker plastic window
The plastic window can be repalced you dont need to get a new door...
Just remove the door from the washing machine and undue the screws around the rim and unclp the plastic rim and you should be able to fit in a new one with no problem...
hope it helps any questions dont hesitate to ask..
Posted on Jan 21, 2008
barkencoa
  • 3463 Answers
SOURCE: How do you replace the
Tilt the m/c back and remove the clamp securing the seal to the front of the cabinet, double the seal back inside the washer door opening, and then pull the retaining spring off the inside of the door seal which is fitted in a groove at the back of the seal.
Refit the new seal starting at the topmake sure the seal is fittef the right way up, drainage holes to the bottom.
Work the seal on all the way round the drum, and then roll the spring into the groove at the back of the seal and work it round all the way round the seal, you will find it easier if you have someone to help hold the spring in place..
Refit the seal round the front of the cabinet,and refit clamp at front.
Plz rate this solution.
Thanks.
Posted on Dec 19, 2008
  • 74 Answers
SOURCE: Is it possible to reverse the doors on a Bosch
yes ,it is possible,you don't require a kit from bosch,however,you will need to disassemble the machine.if you are not confident,get someone who is.
Posted on Oct 16, 2009
57 varieties
  • 1653 Answers
SOURCE: Bosch Nexxt 700 won't drain water
Do the following.
  1. Switch off the machine and disconnect the mains power.
  2. Remove the access panel on the lower right front of the machine.
3. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray. It may take a few minutes to empty but it will save a small flood.
4. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
5. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
6. Reconnect the power and switch the machine on.
If the problem persists then do the following.
7. Switch off the machine and disconnect the mains power.
8. Check the electrical connections at the pump and make sure it is operational.
9. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
10. Makes sure the pump appears clear and that the impeller looks in good condition.
11. Reconnect the hoses and then reconnect power and switch the machine on.
12. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Posted on Oct 23, 2009
Macmarkus
  • 2605 Answers
SOURCE: door will not open bosch nexxt 500 series
Hello, Welcome to FixYa.
Hopefully the info below will supply you with the assistance to get the door open for now at least...and a little more with some luck.
The door typically locks as a result of the unit failing to drain, so....
**Unplug the washer from the wall or turn off the breaker before attempting any repairs**
  1. Locate the round door on the front of the machine (about 6" in diameter, lower right corner) macmarkus_26.jpg
  2. Find a drill bit or small screwdriver that fits in the hole in the round door.
3. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free. (the edges are very sharp so be careful).
4. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand or with the aid of pliers.
**NOTE - you should also see a ring attached, if you pull this the door should unlatch, but getting the water out first if present is usually a good plan
Once the door is open and you've removed the items you wanted. Unplug the washer for 20minutes or so and then plug it in again, to see if the control "resets".
Let me know if you require further assistance and if not and this solves your problem, please rate the solution I provided accordingly.
Thank you for coming to "FixYa" and good luck.
Regards,
Macmarkus :)
Posted on Apr 15, 2011
Can i stack the nexxt 700 series machines?
Hey there, welcome to Fixya! The above answers were pretty helpful, did you fix your problem with them? Did you check the manual for further instructions? You can find a PDF copy here: Bosch Classixx 5 Manual
Jul 10, 2014 | Bosch Nexxt 700 Series WFMC6401UC Front...
I can't figure out how to reverse the door on my
You need a left sided hinge kit...here is the link to the part from Bosch http://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/us/prodlg.htm?Maktx=wtz1260&eshoptype=A
There is a PDF on their site under "support" and your model number wtmc3321us that shows this on page 8. Hope this helps you! :)
Jun 11, 2012 | Dryers
Door Fell Off and broke off the hinges Not the hinge itself but the white plastic part of the door that attaches to them How can I fix it
Spares Suppliers
You will need to type into your search engine/web browser '(make) washer spares' and you should be presented with a number of sources from which you can order. During the process you will be asked for the actual model number. You could also try the Bosch site direct.
Good luck,
John C
Mar 21, 2011 | Bosch WFMC2100UC Nexxt Essence Washer
Leaking
This video will show you how to replace the Bosch Next 300 Series WFMC2201UC washing machine door seal with step by step guide on the process of how to fit and replace
Apr 17, 2010 | Bosch Nexxt 300 Series WFMC2201UC
We have the same mould problem with our Bosch washer . We should sue them in a class action. The door doesn't close right has to be lifted and then slamed. The Bosch dryer also stops before the clothes are...
I don't have this problem with the same washer. I noticed my wife keeps the front door open for few hours after using the washmachine. This helps drying the inside of the washer and not allow any mold to grow.
It is worthwhile trying. I may even be recommended in the user manual to do so.
Cheers,
Peter
Dec 27, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch HDS7282U oven door won't close properly.
I am a old bosch repairman and i know for a fact that the door can be fixed. tighten the hinges with 3-4 washer on both hinges. nyc can fix this problem . if your door is really bad then both hinges has to be changed. but sometimes the old hinges willdo the same after awhile.
Dec 20, 2009 | Bosch Evolution Pro-Style 700 HDS7282U...
Reverse doors
Call Bosch...there is a kit (inexpensive) to change the hinge to the other side.
Mar 25, 2008 | Bosch Nexxt WTMC 3300 Electric Dryer
Not draining
Clean out the lint draw and then run vinegar through a cycle.
If this doen't work try CLR. or/and put the drain hose to the lowest level and then put a flexible clear tube down to unblock it.
Use less detergent in the machine. I make my own detergent and I don't have any problems as one of the ingredients in it help keep all lines clear.
If that doesn't solve the problem contact Bosch directly.
Jan 08, 2008 | Bosch Nexxt 700 Series WFMC6401UC Front...
Bosch Nexxt 700 Series WFMC6401UC Front Load Washer Logo
16 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
