Question about Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM
3/4 pump -is pumping water - but a a slow pace
3/4 hp flotec pump - is pumping water - not a steady stream ?
  • 142 Answers
Re prime the pump. Make sure the suction line is completly flooded so it will take a good suction from the well.
Posted on Jun 03, 2009
Why isn't my pump pumping any water
Flotec FP4012-10 1/2 HP Shallow Well Pump Jet ...
www.amazon-associate.com/Flotec-FP4012-10...Well.../B0002YXB14?...
Find helpful customer reviews and review ratings for Flotec FP4012-10 1/2 HP ... After realizing the failure was due to a high amount of sediment in my well I ...
Aug 30, 2015 | Flotec Pump FP4022-10
I hAVE REPLACED MY 1/2 WATER PUMP FROM MADE FROM GE WITH A FLOTEC 3/4 JET PUMP AN DNOW i AM HAVING PROBLEM WITH THE MOTOR. PUMP DOES NOT START, SOUND A MUMMM SOUND. WHAT IS WRONG WITH THIS PUMP?
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? have you tested the power?
Jul 27, 2014 | Flotec 3/4 HP Deep-Well Convertible Jet...
STORES THAT SELL FLOTEC 1/3 HP MODEL NO. FPSC2200A-08 115 VOLT 60 HZ 9AMP SUBMERSIBLE PUMPS
Your best bet is to get off this site, go to Google or Yahoo or any other search engine and type in "Flotec Pumps" and you will get several thousand places to shop.
Aug 03, 2012 | Flotec Plumbing
I have a 3/4 hp Flotec 4022 pump. Prior to that I had a goulds 1 hp pump on the same 120 circuit with no issues. The Goulds pump housing started to go so I replaced it. Since replacing it with the Flotec I...
Hi Eglenni,
Here are the specs for your pump:
Thermoplastic Shallow Well Jet Pump 3/4 HP. This new revision of an "old hand" provides good pressure pumping from wells where the depth-to-water is 25' or less.
BODY CONSTRUCTION: Thermoplastic
HORSEPOWER: 3/4
MAXIMUM CAPACITY: 12 GPM
FLOW at 10' LIFT and 40 PSI: 9.7 GPM
MAX LIFT: 25'
MAXIMUM PRESSURE: 78 psi
PRESSURE SWITCH SETTING: 30/50
SUCTION PIPE SIZE: 1-1/4" NPT
DISCHARGE PIPE SIZE: 1" NPT
AMP DRAW (full load): 6.1 amps on 230v / 12.2 amps on 115v
VOLTAGE: 230v / 115v, 60 Hz
RECOMMENDED BREAKER: 15 amp on 230v / 20 amp on 115v
MAXIMUM WATER TEMPERATURE: 140 °F (60 °C)
Note that this pump can be operated at 115 volts or 230 volts (A/C) It may have come wired for 230 volt use from the vendor.
Make sure the pump is piped correctly.
There should be a wiring diagram either on the pump or in the literature so you can check to see how the pump is wired.
MAKE SURE
you have the pump wired for 115 volt use in your case. Also make sure the wire size is #12 awg for the power wiring.
Make sure all connections are tight. If you have an amprobe (an instrument that measures electric current) you can check to see how many amps the pump is pulling when it runs.
You said your old pump was 1 HP. This Flotec pump is 3/4 horse so there could be some pump performance loss depending on the well depth and length of the piping runs.
Here's the link to the website for the pump. There are additional resources available on the website:
Thermoplastic Shallow Well Jet Pump 3 4 HP
Jul 05, 2017 | Northern Tool Electrical Supplies
I have a 1 month old Model FPOS1775A Flotec pump. The discharge hose is 3/4 inch with a level run of 20ft.It pumps water but only at 2 and a half minute intervals even when fully submerged!!! I now have a...
If the pump is only pumping for a few seconds at a time it may be a problem with the control board. On two of mine, the 10mf 100v smd capacitor came loose. Resoldered and potted with hot melt glue. One of them is working with the other yet to be tested. Don't recall what the exact symptoms were, only that it wasn't continuously pumping water while submerged.
Unit is oil filled so should be dismantled in the upright position.
Feb 23, 2010 | Flotec 1/4 Horsepower Sink Pump System
I got 1 year old flotec 3/4 hp pump and it take
I have had the same problem there are a few things that can cause it to take longer to shut off, if you are running a sand point well that's usually a sign that the sand point is clogging up,if you have a sistern or a dug well check the screen on the end of the suction pipe,another possible cause is the water level has dropped low enough the pump is having to work harder to pull the water up, you should also check your pressure tank and the points for the pump if the points are sticking the pump will keep running till it builds enough pressure to trip them.Check for leaks in the suction line, if it is sucking air that would cause it to run longer to.I hope these suggestions will help fix the problem. Have a great weekend
Sep 05, 2009 | Flotec Plumbing
Pump stopped working while pumping
Yes, most motors are thermally protected. It is usually bi-metallic, and resets itself.
--W/D--
Aug 08, 2009 | Flotec Corrosion Resistant Shallow Well...
Motor running but not pumping any water, why?
You very well could have a bunch of Sediment on the Intake for the Water OR The water table has Drpped Below the Pump.
Jan 19, 2009 | Flotec 1 Hp Deep Well Pump
Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM Logo
498 people viewed this question
Top Flotec Plumbing Experts
john h
Andrew Bugbee
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
