Question about Igloo FR1082 White 10 Cu. Ft. Refrigerator Top Freezer, Energy Star
Refrigerator plugged in, the light is on but the motor is not running.
The refrigerator is only 7 weeks old. it just stopped running
LG Fridge not cooling refrigerator (freezer is fine, fan is running)
those sensors do fail but if the freezer is not as cold as it should be .then the refrigerator part will also not get proper cooling . TEST the freezer temp .
Sep 25, 2015 | LG Refrigerators
Our gladiator bottom freezer/refrigerator stopped working while we were on vacation last week. The motor still runs, but the air blowing out is not cold. We cleaned it out, unplugged it and plugged it in...
It is possible that your compressor has redduced in pumping or the gas pressure has redduced, ;leakage of gas. Sicne you had put off the fridge for sometime and tried again without any result, I think the compressor needs a good check. Since the fridge has to cool definately when the motor runs we must start from here . I hope you check this out or maybe get help to confirm definetely with an estimate. Good day.
Aug 02, 2010 | Gladiator GAFZ21XXMK Bottom Freezer...
Refrigerator runs for a week or two at a time
Defrost cycle is not working rightso ice is building up and hitting the fan...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 12, 2010 | Maytag 21.9 Cu. Ft. Bottom-Mount...
Neither freezer or refrig will not cool.
The relay switch is plugged into the compressor and you disconnect the OLD relay switch from that and unplug ( I think it was ) 2 smaller plugs from the OLD relay switch and then replug those 2 smaller plug into the NEW relay switch and then plug the NEW relay switch back into the compressor. I hope I made sense.
Feb 28, 2009 | Amana ARS266ZBS Side by Side Refrigerator
Refrigerator not cooling although lights and sound are OK
your condensor had been chocked therefore the gas is not circulating. contact your service authority..... as because it cannot be done by your self.
Feb 27, 2009 | Whirlpool ED2FHEXN Side by Side...
Kitchenaid refrigerator stopped cooling
Yes, it will cost you at least $150.00 for a repair tech to walk to your house, but your case sounds like your motor had problem, When the motor running loudly for several weeks, because it lack Freon R-22, that why made a loudty noise, some place is leaking very slowly, your compressor need freon. I think it is going to cost you at least several hundred to repair it, but if you can find a used working Reg.probably you can save some money.
Please ask your friend who might give you some their opions.
Jul 10, 2008 | KitchenAid KSRS25IL Side by Side...
Unit not running (cooling)
Hi ,
My fridge motor will not kick in or make any sort of sound, there is light on in fridge, where would I find the fuse or overload button.
I need help, thankyou. Coaxing.
Jan 18, 2008 | Refrigerators
Kenmore 106.7687461 about once a week refrig stop, light still on?
Try to locate the defrost timer. It sounds like the defrost timer has an intermittent fault and is not operating as it should. It should be situated in the compressor compartment. It is a white or black box with a little knob protruding from it. When the motor stops again, try turning the little knob on the timer untill you hear a loud click. The motor should then start running again. If it does, the timer is faulty. Replace it.
Oct 30, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerator stopped cooling
The most common problems for refers not cooling is a condenser fan motor (the one that cools the compressor) is out. This can be caused by either a mouse has tried to jump trough the fan and it came on or a loss of grease or oil. There is no way to oil them so they have to be replaced. That is the problem especially if you unplugged the refer and it worked for a while then quit. If the fan doesn't cool the compressor it will overheat and shut down coming on intermittently then shutting off again. As for the refer that still doesn't cool when everything else does you may have an burnt overload also. Check the compressor area for burnt or stalled components ex. fan motor, relay, overload. If your compressor is out plan on spending from $300.00 to $500.00. But check the suggested components first. And beware there are appliance shops out there that will find one of these problems and give you an estimate for a compressor. Find someone reputable.
Jun 18, 2007 | KitchenAid Superba Architect KSCS25INSS...
Igloo FR1082 White 10 Cu. Ft. Refrigerator Top Freezer, Energy Star Logo
Top Igloo Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you an Igloo Refrigerator Expert? Answer questions, earn points and help others
