Question about Husqvarna Garden
Husqvarna 137poorly works at full throttle
I have a H-137, and for two years it worked perfectly. This year when I started it, at the idle it worked perfectly, but when I tried to saw and pressed the trigger, the saw began to gain speed much slower than usually, and then it gained speed (seemingly) much higher speed than it's nomal, and it refuses to saw -- when the chain contacts the log, the saw stops.
What's the matter?
Best regards,
Michael
  • 181 Answers
It seems to me the you have either a clutch problem or a spur gear problem.if it is the clutch the clutch drum will be blue.witch means you need to replace the clutch and drum.if it is a spur gear problem you need a new spur gear.to check it out,take the chain and bar off the saw.now look at where the chain rides in the gear.there should be no markings on the gear.if the spur gear has any dents on the gear then the gear is bad.if you are getting denting on the surface then you are over tighting the chain.this causes the chain drivers to ware also.most likely this is your problem.hope this helps,let me know if you have any more questions............
Posted on Jun 01, 2009
REVS HIGH WHEN FIRST CRANK IT, GETS HIGHER WHEN PUSH CHOKE DOWN. RUNS OK AT HALF CHOKE.... TRYING TO SELL IT, RAN FINE HAS JUST BEEN SITTING UP FOR A YEAR. PLEASE HELP!?
Hi, Anonymous and the usual suspects are:
1. Throttle cables improperly adjusted or pinched.
2. Idle adjusting screw needs to be backed off.
4. Air fuel mixture adjusted too lean start with 2 full turns.
5. Intake system air leak.
6. Fast idle choke ramp is not releasing.
7. Broken throttle return spring.
8. Damaged diaphragm or slide.
9. Faulty MAP, TPS, ATS, O2, sensors or wiring/connector
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Dirt Rider Magazine
YZ 125 Climbing high idle Yamaha 2 Stroke
How to Get Your 2 stroke Idle Perfect YZ125
Yamaha YZ125N1 Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Feb 17, 2014 | Yamaha YZ 125 Motorcycles
Husqvarna trimmer hard to start and doesn't run fast enough at full throttle
Check the vent on the cap, most of fen an air vacuum stopping the flow of fuel.
Dec 25, 2017 | Husqvarna Garden
Why wont my saw idle
you can tighten its idle screw next to where its throttle is and you should get it to idle
Aug 11, 2012 | Husqvarna 136 137 141 142 Replacement...
Chainsaw dies at full throttle, idles fine and works with half throttle
hi
check the fuel filter,clean the gas tank,the carburator ,check the fuel pump(not to be tired).the fine filter inside the carb under the fuel pumpand the sparkplug.
by for now savumihai71
Oct 29, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
1982 Yamaha sr250 runs great but when I come to a stop the idle will run up. I have worked on carb and replace almost every part inside.
Hi, Stephens1302 and the usual suspects are:
1. Throttle cables improperly adjusted, pinched or need lubrication.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Rough Cold Start High Idle When Warmed Up
82 GL1100 Idle speed increases LOTS
Yamaha SR250 Yamaha SR250G Years 1980 1983 Service Manual Download Manuals... $10
http://mybikemanuals.com/yamaha/yamaha-sr-owners-manuals
Oct 10, 2010 | 2001 Yamaha SR 125
The chain brake on my little 137 husqvarna saw is broken. The metal strip is snapped . Do I need to buy a complete new brake assembly or can I get only the metal strip and fit it into the perfectly good...
You ask a 2 part question, I start with brake band repair/replacement.
A link to a 2004 Husqvarna 137/137E IPL (exploded parts list) follows (may not be your saw):
http://weborder.husqvarna.com/order_static/doc/usa/2004/I04000/I0401903.pdf
See the Chain Brake illustration, item 13 for the band. Item 14 (see Bailey's description. Your local Husky dealer will save shipping fees and is likely about the same price.) is a complete clutch cover $22
Sep 13, 2010 | Husqvarna Garden
Hi there, I got the Husky 240e, with only ~4h of running. my problem is that the chainsaw starts smoothly but when pressing the throttle it is suffocates and turned off. When gently squeezing the...
The symptoms indicate lean running, so check the fuel filter for plugging and the fuel lines for decay or other damage. Husky seems be having troubles with our ethanol treated fuel and may require some warranty attention. We have a year old 435 Husky that would not start after about 3 days of excellent running--warranty replaced the carburetor which seems to have us working well now. Good luck!
Aug 09, 2010 | Husky Husqvarna Chain Saw 240E w 16in bar
How to assemble the chain brake on a Husqvarna 137 chainsaw
A link to a Husqvarna "IPL, 137/ 137 e, (revised 2008-04) 2006-12, Chain Saw" follows (may not be your saw):
http://weborder.husqvarna.com/order_static/doc/usa/2006/I06000/I0601906.pdf
Page 1 displays the chain brake in good detail. The hand guard must be rotated aft to latch the brake band in the expanded position or it will not be possible to reinstall the cover. It requires a fair amount of force to latch and a vise (use wooden blocks on cover flats to protect the finish) or a large C-clamp to a work surface will probably be required.
HusqvarnaUSA.com (if the above is not your saw, IPL displays parts)
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 06, 2010 | Husqvarna Garden
When chain saw is starte it goes to full throttle.
You understand there is a fast idle start position? If your saw is new it is triggered when the choke is pulled and remians in this position (even when choke pushed in) until the throttle is advanced once. Read your warm start instructions, it says pull clutch, push clutch, start. This is why we should buy saws from a chainsaw seller/mechanic NOT Home Depot!!!
I made the mistake ONCE of attempting to start mine without the fast idle engaged... my shoulder aches just thinking about it. GL
Lou
Sep 13, 2009 | Husqvarna Garden
Garden Logo
255 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
