Question about Keurig Elite K45 Coffee Maker - -
K45 serial number - Keurig Elite K45 Coffee Maker - -
What model kitchenaid was made in december of 1973?
Is the brushed band around the head missing or worn off? The model is on that band. If it worn or missing in order to correctly answer your question I need more information. Is your mixer a tilt head or a bowl lift variety? Did you look on the bottom of the base for a serial number? Some models had them there. Can you describe the ceramic piece a little better? Many models shard the same internal parts and it might not be too difficult to locate that part.
Aug 03, 2014 | KitchenAid K45SS Classic Stand Mixer
KitchenAid K45 (not solid state)
You have a Hobart K45 that was produced up to 1978 when the SS model was started. You will have to search on the internet to find the capacitor or one of equal value, Also try eBay. You will need the numbers of the capacitor to do your search, which means taking the machine apart. Several models and manufacturers were used during the production of the K45 as it was made from 1962 to 1978, so the values of the capacitor are the same but the maker and size would or might be different. I have found them as rectangles and cylindrical in shape. The other option is to find another machine at a yard sale and keep it for parts. You might also take the capacitor to a real electronics shop for help in locating a replacement, (Radio Shack will not be able to help) You need a shop that deals with the electronics of machines. like a ham radio or a cb shop that does modifications or the like. I know this sounds daunting but the search and repair will be rewarding as when you are finished and the machine is back up and running you can say "I did that". Also as long as you have the machine torn down I would replace the power cord your re-assembly will be easier to complete. Hope this helped.
May 29, 2013 | Food Mixers
Kitchenaid K45 Mixer will only run at one speed, fast
is it a K45 or a K45SS? If it is a K45 you will have to replace the filters inside and probably the speed control plate, if it is a K45SS then you need a new phase control board. The K45 is pre 1978 and the K45SS is post 1978. Your information is correct on pre 1978 K45 models that the capacitor is bad, but it might be cheaper to go garage sale hunting and find a second machine as the parts are no longer made and having spares on hand may be a significant advantage in the future, also there are a great many of the K45SS parts that will also repair the K45 mixer so it may not be a practical solution. Watch ebay regularly for K45 parts, they come up every couple of months. On the parts diagram also look for the K5 diagram as it is identical to the K45, one is a 5 quart mixer and the other one is 4.5 quart, same parts same motor same everything.
Jan 30, 2013 | KitchenAid Food Mixers
Where can i find a hobart k45 replacement cord
You can purchase a replacement power cord from Amazon.com. It is part number 9701025 and includes the grounding style plug which the original did not have. It can also be purchased from your local Sears parts store but it will be much more expensive
Apr 26, 2012 | KitchenAid K45SS Classic Stand Mixer
Which is the better mixer of these old models: K5A K5-A or K45 SS and what is the difference? KITCHENAID HOBART K5A K5-A 300 WATT MIXER and the KitchenAid Hobart Vintage K45 250 WATT. Thank you
Hello ajlina,
All of these are great home use units, all the attachments are interchangeable between these. The difference between these mixers is the K5 is a 5 quart mixer and the K45 is a 4.5 quart mixer. As I own both of them they are great in the kitchen and have the same durability.
Have any more questions please post to this thread and I will be happy to assist. Thank you for using FixYa.
Dec 09, 2010 | KitchenAid K45SS Classic Stand Mixer
I took a KitchenAid K45 apart to clean (made in
What everyone is forgetting or they just don't know is that...The K45 introduced by Hobart in 1962 and was replaced in 1978 by the K45SS are two completely different machines. With completely different wiring systems. The K45 is wired together with wire nuts and the K45SS used connectors on the Speed control switch. All of the websites posted above are for the K45SS (Stands for Solid State) The manual for he K45SS is easy to get from Kitchenaid as the mixer electronics did not change from it's introduction in 1978 to 1986 when Hobart sold the Kitchenaid division to Whirlpool. The K45 on the other hand is a product and property of Hobart NOT Whirlpool or the Kitchenaid division of Whirlpool. The K45 Manual ... well I just can't find one! They way wires are routed is totally different in the K45 from the K45SS so the diagram in the K45SS manual does not help. Also the brushes in the K45 were square not camphor-ed like they are in the K45SS so there is no right or wrong way to insert the brushes in a K45. Whereas; in the K45SS there are four ways to insert the brushes in their holder and three of them are wrong. The K45SS brushes go into a completely different brush holder than the K45. The K45SS is the same today in 2012 as it was in 1978. The K45 is the same only from 1962 when Hobart introduced it to 1978 when it was replaced with the new Solid State model. prior to 1962 it was the K4-A model and it was different entirely. So if the people asking for help say their mixer is a K45 we should be asking for clarification as to a K45 or a K45SS.
Mar 22, 2010 | KitchenAid K45SS Classic Stand Mixer
Pcg k45 sony vaio
chek the adapter and female power soket on laptop. if they are ok, clear the bios by reset bottom(there is a small hole under laptop) or removing small battery on mainboard.if the problem not solved ,have to change the mainboard.
Aug 16, 2008 | Sony VAIO K45 Notebook
PCG-K45: No Power: Internal component issue.
The Power Charging Board Is Usually Known As A PWS Board.
It should have a model Number Stamped On It. you type this into a blank webpage and do a search. this will give you the model Number i.e PWS 13 OR PWS 15 et,c.
Mike @ Compurepair.
Apr 06, 2008 | Sony VAIO K45 Notebook
Keurig Elite K45 Coffee Maker - - Logo
96 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
