Question about Refrigerators
Igloo model # FR1082 light is on but motor not running
Refrigerator plugged in , the light is on and the refrigerator motor is not running or cooling
wheelshot
  • 102 Answers
SOURCE: Amana refrigerator stopped cooling.
Have you been hearing a clicking noise coming from behind the unit? This is the first indication of a failed compressor relay. Pull the unit out and unplug it. Remove the back cover and go to the compressor. You will find a device on the side of the compressor that has the wires hooked to it. This is the compressor relay and overload. It may be under a black cap. Remove the cap to access it. It may have 2 pieces to it or it may just have the 2 pieces encased in a white and tan box. Remove this box and shake it. If it rattles like gravel in it then it is bad. If it is in 2 pieces then it will have a brown relay. This is the piece that will rattle if bad. The white and black piece with one wire is the overload. They most never go bad. Use this replacement part kit...8201786 and follow the detailed instructions included in the kit. Thanks for the question. Hope this helps.
Posted on Apr 11, 2009
  • 454 Answers
SOURCE: motor not running Refrigerator not cooling
There are three possibilities why the compressor motor is not running. #1. The thermostat switch is not closing to turn the motor on. #2. The compressor motor is bad. #3 The defrost timer is engaged, preventing the compressor motor from starting.
Solution for #1: Locate the thermostat switch behind the console in the refrigerator. It is attached to the freezer temperature adjusting knob. If you jump the switch out, the compressor motor should start. If it does, replace this switch.
Solution for #2: get another refrigerator. It is not worth repairing.
Solution for #3: Turn the freezer temperature switch to the coldest setting. Locate the defrost timer in the console on the ceiling of the refrigerator compartment. Look for position labels like "cool control" and "compressor". Jump between these two wires. The compressor should start. If it does, replace this module.
Posted on Mar 07, 2010
  • 93 Answers
SOURCE: refrigerator is not cooling
Dirty condenser, condenser fan or evaporator fan motor are not running, Ice build up on evaporator and restricted the air flow. If compressor, condenser fan and evaporator fan motor are running but not cooling, then either compressor or sealed system problem.
heatman101
  • 43501 Answers
SOURCE: GE Side by Side Refrigerator model GSS22JFMC WW Is
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
rggasd
Posted on Sep 29, 2010
SOURCE: I have an Igloo mini refrigerator that seems to
Not cooling. Compressor running. Is it serviceable?
Posted on Jul 31, 2011
Where can I get a thermostat for an FR1082 igloo
Sorry we would have no way to know that since we have no idea where you are located. I would say any product dealer can help you
Mar 21, 2017 | Freezers
Need owners manual
What is the model number of the refrigerator
Feb 03, 2016 | Refrigerators
Igloo fr1082
Sounds like an airflow problem. No air going into ref section. Usually a defrost problem and the coil is ice up in freezer section preventing airflow.
Aug 13, 2014 | Refrigerators
What does the on off switch for inside the frig "?"
Defrost heater.
It should stop the compressor and turn on a heating element to speed up defrosting.
Jul 15, 2014 | Igloo Cooler Igloo - 10.0 Cu. Ft....
Igloo FR1082 not getting cold
Sounds like lost gas in transit from supplier, or compressor running but not pumping. Is it under warranty?
Apr 10, 2014 | Igloo FR1082 White 10 Cu. Ft. Refrigerator...
Igloo MIS1530 not cold
If it is out of warranty..... Take it to a football field, and see if you can make three points through the goal posts.... Sorry, wish I had a better solution. They just are too inexpensive to warranty $80/hour work plus parts on them.
Jan 09, 2014 | Igloo Cooler Igloo 3.2 cu. ft....
Fr1082 igloo problem
I had contacted Best Buy to inquire about this. My fridge, just a little over a year old, has quit working (motor not running, no sign of cooling). They informed me that unfortunately, they don't do "repairs" on these, just replace them if you're lucky to be within the 1yr. warranty. Anyway, the company that you can order the thermostat is called Curtis International, in Ontario Canada. Their contact number (good luck getting through, I held on for over 9 min, to no avail) 1-800-968-9853. As far as payment for the part, the company request payment by either certified check or money order. In addition, they want you to make sure you send them your name, complete mailing address, phone number, model number of unit and all information printed on the thermostat for proper match-up. Hope this helps. Oh yeah, according to the website, the thermostat replacement cost is $12.00. Again, I hope this helps. Mr. Martin - Williamston, NC
Oct 07, 2013 | Refrigerators
What does the on and off switch do on the inside of the igloo fr1082
When in the Off position the light inside the refrigerator will never come on, when this switch is in the On position, the light comes on when the door is opened. See: http://s3.amazonaws.com/szmanuals/5414b6a6e7d7b6aa69270397065a7de8 Page 5.
Sep 11, 2013 | Heating & Cooling
Refrigerators Logo
219 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
