Question about Emerson EWR20V4 DVD Recorder/VCR
VCR I put a tape in, it says PLAY on the screen but nothing happens, then it shuts itself off. If I try to push play or ffwd or rewd nothing happens. this just recently started after a tape got stuck in the vcr and I had to pull it out.
  • Anonymous Nov 21, 2007
    VCR played for a couple of weeks, now it won't play them. Although, I can put one in & hit record & it will record to the DVD. But, I can't watch VHS. I have only had this for a few months.
  • Anonymous Dec 28, 2007
    the vcr turns off after two minutes
    Scholar:
    New Friend:
  • 67 Answers
You have probably bent the tab that holds the tape end sensor or its light. The tapes have a clear section at the end of the tape and the light shines through to the sensor to tell the unit that the tape is finished. The light should not pass through the recordable part of the tapes. If anything is bent the light may shine on the sensor and tell the unit you're at the end of the tape and to shut off. Some units have a tape tension sensor also that tells the unit that the tape is broken and to shut off. Only way to know is to remove power and take it apart and look for anything that may be bent. Stay away from the rotating head assembly and the posts that the tap travels on. Do not apply power with the unit open. Do not load a tape and remove power as some units freeze in the loaded position and will not load new tapes unless manually placed back in the unloaded position.
Posted on Nov 30, 2007
I insert the cartridge and the vcr spits it back out
the take up belt is worn try put the tape in hit stop then fast frwd a little bit then rewd a little then play
Aug 17, 2014 | Symphonic Televison & Video
Have a Sony HVR M25U deck and put in a mini-dv tape and the tape played fine but not able to play, ffwd, rwd or stop. So I unplugged power cord on deck. Plugged power cord back in and now the tape is...
DO NOT , UNPLUG THE POWER CHORD, DO ONE THING SWITCH ON THE VTR AND THEN HAVE AN ALL PIN .. THEN RESET THE MACHINE ... WITH THAT PIN .. AND THEN PRESS EJECT ... YOUR TAPE WILL COME OUT ..
Jul 14, 2011 | Sony HVR-M25U HDV VCR
I put a tape in and I hear a loud clicking noise and the VCR doesn't play the tape and turns itself off after 8-10 seconds.
first, try another tape. if it does the same thing the vcr is out of alignment. many times a broken lever inside the vhs tape can cause the vcr to shut down.
Mar 05, 2010 | Panasonic PV-9662 VCR
We put a tape in vcr. we push record and the vcr ejects tape and shuts off.
Does the tape play normally? Does this happen with several tapes when you try to record? Check the record protect tab on the lower left hand side on the facing end of the tape. If this is broken or bent it will not record, you can put a piece of tape tightly across the tab as a repair
Oct 01, 2009 | Philips Televison & Video
VCR not working
The heads are dirty or misalligned. Try running a cleaning tape through it. If that fails, it needs to be serviced.
Sep 01, 2008 | Sanyo VWM-800 VHS VCR
Shuts down after 8 seconds of play.
Does the tape hang out when you eject the cassette?
8 seconds is about the time that the VCR brain allows the mechanism to run when there is a problem before shuting down. Just guessing from the model number, but I'd say the unit needs a belt job.
Dec 24, 2007 | Televison & Video
Sony ccd-fx310
My camera won't play back.  Occasionally, if I ffwd it will show the picture otherwise its a blank screen.  Any ideas?  I've tried cleaning the heads a few times now
Dec 04, 2007 | Sony Handycam CCD-TRV37 Camcorder
Magnavox msd804 vcr/dvd combo
I think what you are referring to is the pinch roller. This roller sits at the right side of the mechanism, and in play mode, presses the tape up against the capstan shaft. These pull the tape through the machine at a precise regulated speed. If the roller isn't being engaged or the capstan isn't turning, then these conditions need to be corrected. Does the capstan turn freely? How about the noted roller? Perhaps lubricant has dried/hardened/gotten sticky...
There is electronic circuitry for the capstan motor (a direct drive type motor integrated on the underneath side. Something could be awry with this circuitry.
There is a drive clutch mechanism which could also be defective. This drive clutch assembly sits in between & swivels between the supply and takeup spindle, depending on whether VCR is in Play/FFWD or REW. In the Play/FFWD, it is engaging the right spindle (takeup) and in REW the left spindle (supply). If this is what you are describing, perhaps this clutch unit needs replacement or the grease at its pivot is hardened/sticky.
Most VCRs of the last 10+ years don't use a rubber tired drive (very common on late '80s VCRs), rather a gear toothed drive.
Beyond a simple mechanical problem, repair might not be economical feasible. Most VCRs of the last 10+ years are poor quality, disposable, unlike the machines of the '80s and early '90s, which were built like tanks comparitively speaking.
Nov 03, 2007 | Televison & Video
VCR eats tape when rewinding
A couple of possibilities: 1. Braking problems: When VCR goes from FFWD, REW, Play to stop, there are a pair of "brake pads" engaged to stop the reels, and prevent tape spillage out into the machine. These pads, often rubber like, are on levers which contact one side of each reel. If you take the cover off the VCR, and look down where the tape is loaded, you will like see these brake assemblies. If the rubber pad is missing, or lever pivot points gummied up, then this is your issue. 2. Take up reel isn't being engaged to take up the tape on tape eject. When a tape is loaded into the machine, tape is pulled from the cartridge and threaded into play ready position. When eject mode is engaged, the tape must be pulled back into the cartridge, or you will have tape hanging out the front end of the cartridge, and may get caught on the VCR internals, or at least be mangled by the cartridge door. The often issue here is likely the idler assembly pivot point is sticky. This idler pivots, moving from the take-up reel (right reel) to the supply reel reel (left one), depending on what mode is selected. FFWD & play to the right, left for REW. If this idler is gummed up at it's pivot point, movement will be sluggish at best, and might not be engaging the right reel quickly enough to pull tape in before tape eject. This idler is sitting right between the reels down where the tape sits. A little light oil on the pivot point may be enough to loosen it up. Otherwise it might need to be removed and the old grease removed, and a drop or two of light oil applied.
Jul 09, 2007 | Mitsubishi HS-U781 S-VHS VCR
Emerson EWR20V4 DVD Recorder/VCR Logo
154 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
