Question about Dometic Rooftop RV Air Conditioner
Carrier air-v AC is not blowing cold air
Fan is blowing air and compressor is coming on but no cold air. unit worked fine a week ago, coils checked and are clean. What can I do to solve this problem?
    Problem Solver:
  • 4 Answers
There could be a freon leak, or just low freon levels. If this is the case, you have to call a certified a/c technician to recharge your system.
Posted on May 19, 2009
Byant ac not blowing cold air
Check outdoor unit ,if the outdoor fan is spinning ,check if the compressor is coming on , if both fan and compresseor are working
it may be low on refrigerant
Jul 01, 2014 | Bryant Heating & Cooling
Carrier home AC #BRC036 quit blowing cold air thru vents
Possible indoor fan motor not working or if it's blowing air just not cold air then compressor not coming on on outdoor condenser
Jun 05, 2013 | Heating & Cooling
I have a 2006 Gulfstream Cavalier 8'x 32' Fema Travel Trailer with a Dometic Duo Therm AC unit which I have recently replaced the fan motor on. Had the dealership bench test motor prior to lea
There is ice forming on the evaporator coils. This is either from a low freon charge or a leak in the seals or windows and doors. Could also be that the drains are not working and water is building up and freezing
Oct 10, 2012 | Dometic Heating & Cooling
My carrier ac unit does not cool, I read the previous posts but they are not relative. The fan does not come on at all when the knob is in fan position. Correction, the ac cools but is not COLD. it is the...
These units are known for not working too well even if the rear coil is the least bit stopped up. This is the first thing you need to check. Pull the unit out of the case, (unplugged) Peer through the rear fan blade and inspect the rear coil. The rear coil looks like a radiator. When it is plugged up with dirt, the unit will only work partially and will overheat quickly. The compressor may only work part of the time. If this is not the problem, you either have a compressor that has weak rotary veins (valves) or low on refigerant.
Cleaning the coil: The rear coil is screwed to a rear fan shroud. You can take these screws out and carefully pull the rear coil out enough to wash it out good with a water hose and sprayer. Be aware, there are two line of tubing connected to the coil . If you are too agressive pulling this coil out of the shroud you can break these copper lines or kink them causing all kinds of problems. So, be careful and take your time. Also, make sure you don't have a real high pressure coming out of the sprayer so that you won't bend the aluminum fins. Hope this finds your problem
Jun 19, 2011 | Heating & Cooling
I have a Rheem 10 series ac that is only 11 years old. The coils are clean inside and when i opened up the unit outside and ran water over the compressor and frosted lines, the unit appeared clear of any...
TO LO OR HIGH!!! ALSO THE FILTERS COULD BE DIRTY OR AN AIR RESTRICTION IN YOUR RETURN AIR DUCTWORK OR DUCT IS NOT BIG ENOUGH.{ NOT ENOUHG AIR BLOWING ACROSS THE INDOOR COIL} IF THE UNIT ISEQUIPPED WITH A TXV THIS COULD BE CLOGGED AND WILL HAVE TO BE REPLACED BY A CERTIFIED A/C TECHNICIAN. FIND A FRIEND WHO HAS A TRUSTED AND HONEST A/C GUY... GOOD LUCK
Oct 17, 2010 | Heating & Cooling
I have a new kenmore ac unit model 580.75101500 i bought about two weeks ago and installed last week. its been blowing ice cold as it should no problems until today. Now the ac turns on runs about 5...
Take it back or call Sears. A 2 week old unit should not do that. I'll assume the settings are right like set on AC Auto or Max cool and not just fan. Are the coils icing or were they icing behind the filter? If not, I think it may need to be serviced.
Aug 07, 2010 | Kenmore Heating & Cooling
Air Conditioner blows air, but does not cool
Go to the outside unit and see if the compressor is running. It may be hard to hear. If you need to you can disconnect one fan lead so you can hear the compressor. If it isn't running then check the capacitor. If it is running then get the refrigerant charge checked. Also check air filter(s) and make sure the coils are clean.
Jul 17, 2010 | Heating & Cooling
Carrier air conditioner isn't cooling the house. It is blowing air, but it doesn't seem to be cool air.
Check the outdoor unit to see if it is discharging hot air out of the top ofd the unit, check the insulated suction line to make sure it is cold or sweating. Try to listen to the outdoor fan and the compressor to make sure they are both operating
Jun 24, 2010 | Carrier 38CKC036 Air Conditioner
Ac fan on, blowing air, but not cold
Check outside unit if unit and compressor are running feel the large line to see if it is cold. If compressor is running and line is not cold possible charge problems. You may have a capacitor problem outside. they go out quite often. You can change this yourself, Open up outside unit and the cap is the silver bullet with terminals out the top. Bad cap can cause compressor to not operate and also the fan. You need to clean the coil inside or at leat check the coil to see if it is clean. You can clean theis with a toilet brush do not go against the coil bit brush with the fins. You may need to call a service tech but try these options first. russ
Aug 15, 2009 | Heating & Cooling
Dometic Rooftop RV Air Conditioner Logo
1,090 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
