Question about Kenmore Electrolux, Eureka Central vacuum bag by Filtrete Type CV-2
460451 wiring diagram for kenmore central vacuum model 34430
I have a kenmore central vacuum model 34430. I purchased a replacement control module from sears. Model 460451 sears part # 102038. I require wiring diagram as this model is different than the kenmore board.
reddevil6
  • 1673 Answers
SOURCE: VACUUM WON'T SHUT OFF
Need a model number to be sure, but alot of the Sears cannisters have a relay and it is found mounted in the motor comparment, it may be sticking in the on position.
Posted on Jan 29, 2008
SOURCE: Replace Kenmore Vacuum Hose
check out this solution http://www.howtomendit.com/answers.php?id=25754
Posted on Feb 03, 2008
  • 6 Answers
SOURCE: Kenmore Elegance Upright Bagged Vacuum Belt Broken and Smelling
It sounds like the brushroll has caused your belt problem and will be the cause of your burning smell as well. What commonly occurs is that carpet fiber,hair,string, thread,etc got wound around the brushroll and some will get caught in the end caps which is where the bearings are.The end caps need to be removed and cleaned so that the bearings can allow the brush to rotate freely.Check that there is no melting of the end caps or the base plate where the end caps fit into the machine._Good Luck
Posted on Oct 26, 2008
  • 2692 Answers
SOURCE: Kenmore Manual
Sears/Kenmore central vacuum systems are no longer being made ergo no manuals available,especially on line on line. If contacting Sears parts directly, maybe one may be purchased ?
http://www.searspartsdirect.com/partsdirect/contactus.pd
The below website is an example or parts available (outside of SEARS) to fit you centeral vacuum.
http://www.centralvacuumplanet.com/sears_central_vacuums.htmI hope I have been of some assistance with your problem.
Posted on Dec 25, 2008
galati2k
  • 281 Answers
SOURCE: I WOULD LIKE TO KNOWHOW TO ACCESS THE FUSE IN THE
look around on the outside of the vacuum probably around where the cord is .look for a round black cap that has ridges around the outside of it.sometimes they say fuse on the cap.i'm not sure if there is one on the inside or not
Posted on Apr 30, 2009
Why Kenmore Central Vacuum wont power on?
The unit is overloading proberbly because the motor is seized or burnt out
Remove motor and bench test
Aug 09, 2014 | Kenmore Vacuums
I'm looking for CV1801 Vacuum Motor, Greator Toronto... Thanks
Hello There,
I've looked up your model vacuum cleaner, and it seems that I am able to still get this motor for your Eureka central vacuum cleaner. We're located in the United States, but we can certainly ship this to you.
Here's a picture of the diagram for you;
We sell the genuine Eureka motor for $199.00, however you may save substantially on this motor by purchasing it under the Lamb Electric name. The motors are identical, and Lamb actually makes this motor for Electrolux, and sells the replacement parts for MUCH less money they Electrolux. We sell the motor under the Lamb name for $119. I went ahead and added this part to our site so you could place your order if you wanted to. I don't have it in stock today, but my parts distributor is showing 3 in stock, so we can easily have your order shipped out within 2-4 business days.
Here's the link to the Eureka CV1801 Central Vacuum Cleaner motor, Part number 54586;
http://www.govacuum.com/10661-Eureka-Central-Vacuum-Cleaner-Suction-Motor-Assembly-Part-54586-.aspx
Hopefully this was helpful to you. I've also left you a link below to the parts diagram of your vacuum cleaner, in case you need some visual help to see how it comes apart. If you found this repair to be helpful, please be so kind and rate the repair helpful, or leave feedback for me. I really do appreciate it, and this also helps people with the same question find the answers easier. If you have any questions, please feel free to email me at chris (dot) jones (at) govacuum (dot) com.
Full Size Schematic in .pdf form:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/eureka-cv1801-central-vacuum-cleaner-part-diagram.pdf
Thanks so much,
Chris Jones
GoVacuum.com
Jan 06, 2011 | Eureka CV1801 Bagged Vacuum
We just moved in - the house is about 9 years old. I have a Eureka Mega Boss central vac - looks like model # is CV20220. 12.4 amps, 120 volts. Can't figure out what type of bags I need. Can you...
Well, for this unit you will need any of the following bags,
Eureka genuine Part# 90610
Eureka replacement (Central vac bag)
another genuine bag style called CV-1, and/or CV-2
Kenmore Central vac bags
Most of the bags there are available at your local vacuum shop, and sometimes even Sears. The Kenmore central vac bag is, can and will fit your Eureka Mega Boss. Prices range on these bags anywhere from $12-$20 for packages of 3. Generally you will replace a bag once every 3-4 months.
Good luck,
Mark
Nov 10, 2010 | Vacuums
I am buying a central vac system, can you tell me the better of the easy flo or nutone brand. I want the one with the least problems. It appears to me that the easy flo has fewer problems, thank you
between the two brands... stay away from the nutone. If you can get it, the Beam, Eureka, or even the Electrolux and Kenmore(sears) would still be better. The warranty would be better on the Beam and Eureka (7 or 10 and one model is even 15 years)
Good luck on your purchase.
Mark
Nov 09, 2010 | Easy Flo EF1525 Central System Vacuum
Hi ! I have a Kenmore central vacuum (model # 34326), 3 inlet valves on different floors. the inlet valves on the second and third floors are already connected. I need to connect the inlet valve...
By your description it seems that You have telephone wire used. You only need two low voltage wires to complete the circuit to turn on the power to the central vacuum unit. The low voltage wires must be arranged so that when you insert the hose into any valve it closes the circuit. You will wire it as if the black and red are just one wire and the green and yellow are the other, they are actually doing exactly the same as if you only had two wires.
Mar 05, 2017 | Kenmore Vacuums
I have a kenmore canister model number 116.2645083 I need a replacement motor. I was given 2 different numbers: 1. 4147248 2. AC92FAUX200 I can find the 2nd motor, but it doesnt have the 4 wires like the...
Greetings from GoVcauum.com,
Ok, so good news, I have looked up your model number for your Kenmore vacuum and found that your Kenhmore canister takes the motor AC92FAUX2000.
#13 on diagram Image not available Motor Number: 4147248 Substitution: 705357
#13 on diagram Image not available Motor Number: 4147248 Substitution: 705357In stock
You may buy this part from the link to GoVacuum.com above. I have personally gone back and checked this motor, and it does have 4 wires that come off the motor itself.
I also verified this by pulling up your parts diagram for your model, and it did call this part number as well.
We offer the best return policy in the industry. We give you 60 days to return any product purchased from GoVacuum. We will even include a return label with every order, and if for any reason the motor doesn't fit, send it back with the free return label, and we give you a full 100 Refund, no restocking fees.
Please feel free to call me or email me if you have any further questions.
Chris Jones
GoVacuum.com
1-866-468-2288
Nov 27, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore Manual
Dec 25, 2008 | Kenmore Vacuums
Kenmore central Vac - where to connect low voltage wires?
Mosy central vacs have 2 spades close together that stick out on the side, usually where the circuit breaker and auto/manual switch is. This is where you plug the low voltage wires into.
May 13, 2008 | Vacuums
Wireing up central vac too braker box.
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=579196
Generic problem for all Vacuums
Wiring up central vac too
Posted by brneault on May 08, 2008
Wiring up central vac too breaker box.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
A central vac not knowing the brand name or model # uses regular household current and plugs into a regular household inlet and I have never heard of wiring the central vac to the breaker box. The central vac is usually out in the garage or down the basement and will be in the regular household current. You may want to ask the manufacturer or the vac dealer you purchased the central vac from and they might have more information for your and if your central vac needs to be wired to the breaker box they will give you instructions, but I don’t believe that you need to do so. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Don – The Vac Man
Go Ahead. Use Us.
May 08, 2008 | Vacuums
Kenmore Electrolux, Eureka Central vacuum bag by Filtrete Type CV-2 Logo
118 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
