Question about Dishwashers
My smeg dwf 64 sse blew the main fuse yesterday. The machine was up to its rise stage on program 8 then the breaker went. Every time I switch the main back on it blew. I have managed to stop it blowing the panel but now it seem to be stuck mid-cycle and won't complete. There a re all sorts of noises and the 1st led stays on then the 3rd one illuminate. Any ideas?
  • 20 Answers
Your element was initially short circuit, which caused circuit breaker trip. It is now open circuit and timer will not advance because water has not reched required temperature, recommend thermostat replacement also.
Posted on May 23, 2009
Washing machine wont work
If it's more than 6 years old, it's time for a new one. Or maybe you blew out your fuses. Try resetting the fuse box and switch off and on. Then after you switch back the power, go and try to turn on washing machine again.
Feb 13, 2015 | Washing Machines
Smeg dwf 409 ss went bang
is the power light on the board or a separate indicator?
were did the current go when the capacitor in the filter blew? probably into the board......
Oct 16, 2013 | Smeg Dishwashers
Blows mains fuse
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Aug 26, 2012 | Smeg SE210X/1 Stainless Steel Electric...
I have a DAEWOO DWF-1150P top loader washing machine and when I switch it on I get an error code E9. Can you please tell me the fault and how to repair it?
I have a daewoo top loader washing machine ,,
Mode W/M-DWF-200MP
The power main board does not take the programs to work how should be its olny one program
Apr 29, 2010 | Daewoo Washing Machines
Fuse blew on power now stuck in Protection Mode
Sounds like the out put stage of the amp is shorting, They are either 4 large transistors attached to an aluminium plate (heatsink) or one large chip with heatsink. also sounds as the driver stage went too when you switched it on the second time. If you know nothing of electronics I suggest you take it to an audio repair shop, as it is cheaper to repair than replace high power amplifiers.
Mar 29, 2009 | Audio Players & Recorders
SMEG DO4SS-5 double oven not heating up
If the fan is running, then it is safe to say that the oven element has gone.
Replace with a new one,(element that is).,
Plz rate this solution.
Thanks.
Dec 15, 2008 | Smeg Ovens
My Smeg dishwasher DWF 64 SSE won't go onto rinse or dry
Easy one first try this to see if it helps
Water pre-heating
Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Jan 29, 2008 | Smeg 24 in. DWF612WH Free-standing...
Aquarius WD62
Did it pop the main breaker or something on the machine??? If on the machine not sure. If the main breaker to the machine, there must be wires or something shorted out in the machine...Either way if it is not obvious, I would suggest letting someone familiar with electric help you directly trace down the short.... With more detail and your knowledge of voltmeter use I can help you. Look for bad insulation on the main wires..
Jan 20, 2008 | Hotpoint Aquarius WD63 Front Load...
SMEG A 2.5 Range Oven
sound like the TOD to me. have a technician replace it.
Dec 22, 2007 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Power Surge and WD16BA
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Sep 18, 2006 | Smeg WD16BA Front Load Washer / Dryer
Dishwashers Logo
272 people viewed this question
Top Dishwashers Experts
