Question about KitchenAid Artisan Series Tilt-Head Stand Mixer
Kitchenaid mixer head lock lever his hard to move & sticks
4 Suggested Answers
hslincoln
  • 235 Answers
SOURCE: The kitchenaid speed lever is bent and jammed
Hi TIMDEIST, I hate it when you drop your mixer... they’re really not designed for gravity testing. Let’s see what you can do to get it fixed and operable again. The good news is that this can be fixed quite easily (OK, maybe a little effort) by yourself, if you are a DITY type person, feel adventurous, and your mixer is not under warranty. Be sure you have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals& Guides> then enter the visitor type “Consumer and enter the 6 character model number, in this case K45SSW, and then select the file under Parts List (1) K45SSWH0.pdf (341.41 KB) (definitely check to see it this matches your mixer).
Although not providing step by step instructions, the Parts List manual provides an exploded view of the various component assemblies allowing you to see how the mixer all fits together. It is helpful for the disassembly, troubleshooting, and reassembly of your mixer.
Turn to pages 6 & 7, titled “Motor And Control Parts”, and locate Ill. Nos. 1, 2, 3, & 4. #3 is your Switch Lever and stud. If you can’t straighten it out then you will need to replace it. It might also be a good idea to check and see if anything else might be out of alignment due to the sudden stop when it was dropped.
As far as parts go, here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com (for grease). Prices can vary widely between vendors, so do some comparison shopping. Here are some links to several excellent websites that detail the disassembling/greasing and reassembly of a KA Mixer.
Finally, here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble, fix/replace your Switch Lever, and reassemble your mixer.
Good luck, I hope this helps. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! – hslincoln
Posted on Jul 29, 2010
justinbur167
  • 257 Answers
SOURCE: Motor head locking lever is
Hello Flyfishing19,
The problem that you are experiencing is due to the torque that is put on the head while mixing dough. The lock is still working fine, although it is getting wear. You can replace the locking mechanism. However, it will work for a while longer. If you want to change the mechanism post back to this thread and I will be happy to locate you one and explain how to change it.
Posted on Mar 06, 2011
SOURCE: My KitchenAid tilt head lock
In my case the lock was not engaging fully because the internal mechanism was bent too short. I'm not sure if this happened over time or if it is just a manufacturing defect. If your mixer still has some up-and-down play to it when the lock is engaged, then you might have the same problem as me
To fix it, search this site and others for instructions on how to remove the motor cover. I found this video useful: http://www.youtube.com/watch?v=VeCiivPt7hk
With the cover removed you have access to the locking mechanism. In my case, the latch is connected to the locking lever via a bent S-hook. The hook was just slightly too short which kept the latch from engaging completely. If you remove the two screws holding the hook in place and that allows the lock to close completely, then you have the same problem as me. (You'll feel the difference immediately. When fully locked, there is practically no wobble in the mixer head.)
I lengthened the hook by placing it against a flat surface and hammering the bend out a bit.
Posted on Jul 17, 2012
How do you tilt the back up on the k45 kitchen stand mixer?
To raise the head you move the locking lever back & lift the front of the motor unit up. To lower it you also move the locking lever to the back and then lower the head and release or push the locking lever forward to lock the head down while using it.
Mar 16, 2015 | Food Mixers
How to tighten kitchenaid mixer motor head locking lever?
Adjust the head height first, flat paddle should just clear the bowl. Te head height adjustment can be seen in by the hinge looking from the front when the head is raised. Screw in (clockwise) to lower and out to raise. You cannot get the head lock right when head height is miles out
Jul 10, 2014 | KitchenAid KSM150PS Artisan Series Stand...
Head won't lock
It sounds like the latch, link & lever assembly need to be replaced, it does require taking apart the mixer, but is a fairly easy fix.
Here is a link to the replacement part: http://www.mendingshed.com/24452-2.html
And also here is a link to the service manual: http://ep.yimg.com/ty/cdn/mendingshed/kitchenaidservicemanual.pdf
Page 15 will specifically talk about replaceing that assembly.
Jan 17, 2014 | KitchenAid KSM95 300 Watts Stand Mixer
Kitchenaid artisan ksm150 - Motor Head Locking Lever stuck in locked position
Get a copy of the Repair Part List of your model from Kitchenaid.com
Remove the Motor Housing (1). The Latch Lever (3) is connected to the Latch (10)
and held in place to the Lower Gearcase (5) by the Latch Bearing Screw (8). This
screw is visible from the outside and located near the Latch Lever.
Tighten this screw to fix your problem.
Aug 03, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Motor head locking lever is hard to unlock on Kitchenaid mixer after kneading dough.
Hello Flyfishing19,
Mar 06, 2011 | KitchenAid KSM150PS Artisan Series Stand...
The tilt-up head on my KitchenAid KSM90 stand mixer has a lot of free play, the head moves (bounces)up & down when mixer is in use. Adjusting the beater for clearance using the dime method, when you...
The head bounce sounds as if the locking hook is not engaged properly when you slide the head-lock lever to the locked position.
If this is the case, you will need to disassemble the mixer to make sure the link from the lever to hook is not bent. Another possibility is that the slot in the base the hook engages. If this is broken away, the hook will not be able to hold the head in place (I sure hope that this is not the problem).
The Service Manual can be found at:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Apr 04, 2017 | KitchenAid KSM90 Ultra Power Series Stand...
New kithenaid artisan mixer top of mixer is moving left to right while mixing and it is lock in.
Hi, ALEICAR, Merry Christmas & Happy New Year! Sorry to hear about your new mixer head stability issues. By the symptoms you describe, I would say that your head locking mechanism (or a component) of it is either broken, or loosened and needs to be readjusted (or repaired) to keep your mixer head stationery.
Since it is brand new, I’d let KA stand by their warranty and replace your mixer on their dime. Contact them immediately and tell them about your problem with the Link & Lever Latch Assembly not working correctly.
The KA website is at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Contact Us> and the toll free phone number is listed to speak with someone. You can also look under the Warranty & Service Plans to see what KA will do for you. I've extracted parts of it here:
Hassle-Free Replacement Warranty
We’re so confident the quality of our products meets the exacting standards of KitchenAid that, if your mixer should fail within the first year of ownership, KitchenAid will arrange to deliver an identical or comparable replacement to your door free of charge and arrange to have your “failed” mixer returned to us. Your replacement unit will also be covered by our one year full warranty. Please follow these instructions to receive this quality service.
If you reside in the United States and your KitchenAid® mixer should fail within the first year of ownership, simply call our toll-free Customer Satisfaction Center at 1-800-541-6390, 8 a.m. to 8 p.m., Monday through Friday, 10 a.m. to 5 p.m., Saturday, Eastern Time. Give the consultant your complete shipping address. (No P.O. Box Numbers, please.) When you receive your replacement mixer, use the carton and packing materials to pack-up your “failed” mixer. In the carton, include your name and address on a sheet of paper along with a copy of the proof
of purchase (register receipt, credit card charge slip, etc.).
If you want to try to troubleshoot it yourself, particularly when your mixer is out of warranty (for later) make sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the same website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> and enter the 6 character model number, in your case KSM150P and select this file KSM150PSWH0.pdf (773.44 KB)listed under Parts List (61). (Check to see if this matches your mixer model).
This parts list manual provides an exploded view for the disassembly and reassembly of your mixer, along with all the part names and numbers. Turn to page 5, titled: Base and Pedestal Unit and locate Illus. #11, Link & Lever Latch Assembly (including Illus. Nos. 10, 12, 13,14, 15, 16, and 17), which locks the mixer head to the pedestal when you run the mixer. Check to see if something is just loose or broken (it shouldn’t be if it’s brand new, but strange things happen in transit…). If something has broken, you can order replacement parts and install yourself (again, let KA replace it for you…).
As far as parts go, here are four potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com. Prices for the same part can vary widely between vendors, so do your comparison shopping.
I hope this helps. Good Luck with KA! - Howard, Burke, VA
If this solution has been helpful, please rate it, thanks! - hslincoln
Dec 26, 2009 | KitchenAid KSM150PS Artisan Series Stand...
I can't find out how to tilt the motor head on the K45SS model Kitchenaid mixer. The user guide indicates there is a lever to tilt it but there is not one to be found. Help!
On my kitchenaid stand mixer, the lock lever to lift the head is located on the opposite side of the speed control. If there is no lever there, check to see if there is a spot that looks like there should be a lever there, if there is, but the lever is missing, you might have ended up with a mixer with a manufacturing error. In that case, your only option is to take it back to the store where you bought it.
Dec 23, 2008 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid mixer
Try replacing the moter brushes,if not its probably ether wiring or in the switch board.
Jun 01, 2008 | KitchenAid K45SS Classic Stand Mixer
KitchenAid Artisan Series Tilt-Head Stand Mixer Logo
41 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
