Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
JOHN DEERE 318 LAWN TRACTOR WONT START
REPLACED PLUGS, POINTS AND CONDENSER, WONT TURN OVER, COULD IT BE COIL? HOW CAN I TEST IT
  • trplumley May 18, 2009
    it cranks, but won't start, no spark. what's left other than the coil? Thanks
  • rattosh51 May 11, 2010
    Won't turn over, as in won't crank at all? Or cranks but doesn't start?
  • 69 Answers
Ok, since you have the points, I assume you have the B43g Onan
engine. Was it running before the new parts were installed?
Check your point gap and make sure it is .016, plugs ahould be gapped at .025 Make sure your plug wires are good too. Should be somewhere between 0 and 10,000 ohms per foot, when measured with an ohmmeter. Once everything is rechecked for gap distance, make sure there is no spark by pulling plug out, leaving wire on and ground the outside of plug to the chassis of the tractor.
Crank over and look for the spark. Coils are about $100, so you want to eliminate everything else first.
Diagnosing a points ignition for no spark is really simple. Do you have 12V at the coil? Do you get a spark when you connect and disconnect the negative terminal of the coil to ground? If not you have a bad coil.
Posted on May 19, 2009
  • rattosh51 May 19, 2009
    Check the coil impedance on the primary and secondary side. You'll have to disconnect the battery negative cable so you don't short something out. Unplug the spark plug wires and the two sets of smaller wires connected to the primary side of the coil. The primary coil reading should be between 3.7 ohms and 4.6 ohms while the secondary (spark plug side) should be between 34.2 k-ohms and 41.6 k-ohms. If the resistance values you measure are outside of these ranges, you need to replace the coil.
  • TONY STRUNK
    TONY STRUNK Nov 18, 2013
    thanks will try
Why won't my mower start?
a weak spark indicates a coil problem
that problem can come from a faulty condenser in the ignition system or incorrect timing for the system
if it has an electronic ignition system test / replace it
if it has a points system replace the condenser and set the points to the correct gap
I
May 14, 2015 | John Deere Garden
STARTED AND RAN ROUGH AND WONT START AGAIN... NO SPARK
Drain gas completely from tank to ensure no water is in the tank, check for spark with spark tester, if no spark shows with spark tester, re check gap on coil, if points & condenser are present, sand down the gap between the points to ensure a proper connection. Make sure to change fuel filter with a high quality John Deere fuel filter and use fresh fuel... Fuel can "go bad" after 1-3 months, if the tractor is/ left outside chances are there is water in the tank.
Nov 18, 2013 | John Deere Garden
I'm wanting to change points & condenser
At that age, it's highly likely that there aren't any! You don't say what engine is fitted, but if it's a Briggs or a Tecumseh, they went solid state in 1982. If that's the case, just replace the coil module.
May 12, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
John deere 425 lawn tractor. it wont start but it has spark and fuel the starter engages and the fly wheel turns
If your tractor has an anti back fire solenoid in the front of the carburetor then it should start if you remove it and cap it off with a pipe plug.It should run if the solenoid is the problem,if so you really should replace it but if it is'nt prone to backfiring with it remove you don't have to.You may also have a bad seat switch,confirm this by jumping the plug with a piece of wire to temporarily test it.
Jan 14, 2010 | John Deere 420,1020,2010,2020,2510,2520...
I have a John Deere 317 tractor that does not start. The engine turns but does not fire. The plugs and points are good. I do not get a spark at the points or plug. What should I check next next.
We will be testing for voltage to the points, coil, engine to tractor wiring harness, ignition switch
Tools needed:
volt meter to read 12 volts, or test light
1) with the points open: is there voltage at the connection wire at the points
If yes; adjust points to .020" and try to crank engine and check for spark
*** you may want to determine if condensor is connected to this wire also
if no
2) check point side (neg or - ) of coil for voltage
if yes, engine should start
if no
3) check for voltage at the + side of coil
If yes, coil is bad
if no
4) check wire connector from engine to frame wiring harness
if yes; engine should start
if no
5) check wiring on the back of ignition switch
if no
6) check that ignition switch RED or BATTERY supply wire has voltage
if yes; switch is bad
if no
7) check supply wire and circuit breaker connected to the battery side of the solenoid
if no; circuit breaker could be at fault or wire connector at battery supply
Nov 08, 2009 | John Deere 420,1020,2010,2020,2510,2520...
My lawn tractor won't start no spark an I have aready replaced the electrical control circuit board. It is a LX277 lawn tractor year 2000 I think. After I replaced the circuit board It still did't start I...
May be the coil is bad. have you checked the spark plug? If there is gas and spark then it will have to start.check the circuit breaker points. is there current in the cb points?
Sep 10, 2009 | John Deere Garden
No spark
did you make sure the gap was set right on coil & flywheel it should be .020 between magnet on flywheel & the coil & the same thing with the points in the open possition between points & condensor
Jun 07, 2009 | Garden
HAVE A JOHN DEERE 318 LAWN TRACTOR, CHANGED POINTS AND CONDENSER, WON'T TURN OVER, TRIED STARTING FLUID IN CARB AND NOTHING. CAN IT BE THE COIL AND HOW DO I CHECK? THANKS
May 18, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Fuse blows when engage blade
The electro-magnetic coil side of your PTO is shorted out.On the 318 it is very easy to replace,just under front screen.
Apr 04, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
2,694 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
