Question about Nordic Track Nordictrack E3800 Treadmill Console For Model Number: 293162
Replace nordic track e3800 treadmill belt - Nordic Track Nordictrack E3800 Treadmill Console For Model Number: 293162
  • 14 Answers
SOURCE: replaced the motor controls
Is there a sheet of paper under the motor hood? It has the procedures for this calibration of the motor speed. Caution ! You should use a plastic screwdriver to make adjustment to the speed control on the motor controller. It is high voltage
Posted on Jul 08, 2009
Gackmaster
  • 12 Answers
SOURCE: I have a Nordic Track EXP 1000X treadmill and the
Probably 85% of the time, it's the sensor.
1. remove the screws from the bottom of the enclosure case. 2 or 3 in the front and 1 on each side
lay it back down, and power it up, and actuate your incline. watch the end of the motor, to see if the shaft is moving. It probably IS turning but only a little bit. NOT enough. In this case I'd say it is the sensor.
2. Unplug the unit of course.
3. the incline motor is in the middle of the pack,..you'll see a black tube looking thing sticking up.
4. on the bottom side of this, you will see,..or feel for a black square sensor attached to bottom of the motor casing.
5. follow the wires and unplug this.
6. pry it off with a screw driver. Remove incline assembly, if you cannot reach it.
7. replace sensor and try it again.
if the MOTOR does NOT turn when using the incline buttons, the problem backs up to possibly a bad control board. or a bad motor on your incliner, however, i'd say that's the last thing to go.
Order of failure: 1. sensor 2. control board 3. motor.
good luck
Posted on Jan 26, 2010
maxtreadmill
  • 832 Answers
SOURCE: My nordic track treadmill's walking belt stops
Unplug the unit remove the motor shroud inspect the drive belt if the rubber feel slick then my recommendation is to replace the drive belt. Adjusting the drive belt may take care of the problem if you do not need to adjust it too tight. If you choose to do the adjusting and feel you have adjusted the running belt thinking it would resolve the slipping, then back the tension down until it the running belt is slipping then adjust until the slippage is resolved.
Posted on May 18, 2010
  • 34 Answers
SOURCE: Nordic Track Ifit Treadmill has power but walking pad not working
If everything on the display console is working correctly then we know it is either a problem with the wires from the console to the controller or the controller itself. In most cases this means you need a new controller. To verify, take off the motor hood and find the green circuit board called the motor controller. With the power on go into manual mode and push the speed up button to a slow speed. If you see an LED light with "spd ctrl" next to it flickering but the belt still does not move then we know the problem is with the controller sending the signal to the walking belt, in which you should check the wires that go to the motor. If they are connected correctly then we know a new controller is in order. If you do not see a flickering light then it means the speed signal never got there and the problem will be with the wires going from the console to the controller. This is called an upright wire harness.
Posted on Aug 18, 2010
SOURCE: our belt is slipping on our nordic track c1900
I have the same unit. First, remove the hood. Then, the motor has an adjustment screw on the belt side of the motor. Loosen the nut a little, adjust the motor up or down to make the belt as tight as you can by hand, then re-tighten the nut. This always fixes mine.
Posted on Jan 03, 2011
Nordic track commercial 1750 treadmill. over the last day or 2 it has developed a humming that gets more pronounced the faster you go as well as what feels like a small vibration
Try to lubricate the treadmill deck and belt
Watch the video to know how to lubricate the treadmill.
Treadmill walking belt lubrication
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Dec 23, 2016 | Nordic Track Exercise & Fitness
How to instructions on replacing nordictrack c2000 walking belt
check youtube.com and search Nordic Track belt. There will likely be a video from Nordic Track to show you how to do it.
Jul 31, 2014 | Nordic Track Exercise & Fitness
I have a Nordic track commercial1500 and the belt motor will not run. Everything else works fine. The fuse is good on the board.
1) see if the belt is tight or loose, repair or replace the belt
2) test the input voltage motor, if there ARE the motor need repair see my personal TIPS for motor help
3) Test the output voltage board, for input voltage motor, if there are NOT the board is faulyt, replace see the b.diagram attached.
Jan 09, 2013 | Nordic Track NordicTrack Commercial 1500...
Nordic track c2420 how to reset treadmill
see the reset button to the side or main switch.and fix it.
God bless you
Jun 18, 2012 | Nordic Track Nordictrack C2420 Treadmill...
How do I replace a Nordic Track C2255 drive belt?
The black shavings are normal on a treadmill. It may be that you need to tighten the walking belt. Try tightening the two bolts on the rear of the machine that hold the rear roller in place. You need to tighten each of them the exact same amount or you'll throw off the alignment. Tighten them three turns of the wrist and see if that helps. If not, try three more turns. If still nothing then replace the drive belt. That can be a real undertaking and you might want to consider contacting a professional.
Jul 14, 2017 | Exercise & Fitness
Just purchased the nordic track 2550 pro treadmill and was wondering if you had to lubricate the belt, i was told that it was self-lubricating and never needed oiled.
You do not need to lubricate the belt, unless you speek with or read something from Nordic trac. Oiling wont hurt anything, but is not needed.
Dec 29, 2010 | Nordic Track NordicTrack A2550 PRO...
Nordic Track treadmill trips GFI.
Have you lubricated the the running deck? The lack of lubrication can increase friction thus causing the GFI to trip. simple test start the treadmill do not walk on a see if the GFI is tripped in it does trip then lubricate, then if after lubricate it still the you have a worn belt and possibly damaged deck depending replacement price and on what you paid for the treadmill it may or may not be worth fixing.
May 20, 2010 | Nordic Track NordicTrack Treadmill, A2550
Belt on nordic track exp 1000 not moving today but worked this week. machine turns on though
if you hear the motor moving with no belt turning the problem is either the front roller or the drive belt. If there is no motor movement then this is usually an indication of a bad control board located under the lower section of the treadmill.
Nov 12, 2009 | Nordic Track /proform Treadmill...
Nordic Track Nordictrack E3800 Treadmill Console For Model Number: 293162 Logo
37 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
