Question about Aqua Brass Home
How to replace aqua brass cartridge - Aqua Brass Home
2 Suggested Answers
  • 25 Answers
SOURCE: water leaking from under my Aqua Brass hot water handle
There's a little set screw that u have to take out with an allen key. then after u take the handle off u have to unscrew the cartridge and take it out and replace with a new one. they're made out of plastic- they break easily.
Posted on Jan 04, 2010
Thermostatic valve does not turn
followt this steps and fix it. God bless you
  1. Turn off the water supply and open the faucet handle to relieve water pressure.
  2. Carefully pry off the trim cap with a small screwdriver or putty knife.
  3. Remove the locknut with an adjustable wrench, then lift the spindle out of the faucet.
  4. As needed, remove and replace the O-ring. Before reinstalling, coat the stem lightly with plumber's grease.
  5. As needed, remove the retaining screw and pry out the washer. Install an exact-replacement washer and tighten it.
  6. As needed, inspect the seat and replace if damaged.
  7. Install the valve and tighten, then reinstall the handle and test.
Nov 28, 2013 | Aqua Brass Akro Shower Kit #2 AQUA BRASS...
Aquabrass tub drain control lever cover separated from nut
lock tight red or stronger will bond it together . but forget remove it after
Nov 16, 2013 | Aqua Brass Deckmount 5 pc tub set with...
Aquabrass tub drain control: cover separated from nut
Try using jb weld or another type of epoxy that is water proof. 100% silicone caulk may also be worth a try.
No water coming out of spout even though water enters system up to and beyond distribution valve.
this may sound stupid but i resently installed one and if then water pressure was not balanced between the hot and cold the unit would not work
Oct 30, 2011 | Aqua Brass Single lever faucet AQUA BRASS...
My volume control handle takes several rotations before shower finally stops dripping. Do I need a new handle and how would I replace it?
The splines are probably striped and the handle will need replacing. but it may be as simple as the handle set screw is lose.
http://www.aquabrass.com/sections/shower
Nine out of ten times these handles go bad when they get lose so if you buy a new one it will come with instillation instructions.
Jan 30, 2011 | Aqua Brass Akro Shower Kit #2 AQUA BRASS...
Water leaking from under my Aqua Brass hot water handle
Jan 04, 2010 | Plumbing
Power flush will not flush when handle is pressed down......
pull the lid off the toilet, disassemble the toilet handle mech and take the cartridge out of the big black tank under there. the cartridge should be available at any local plumbing parts house. let me know if you have problems
Jul 02, 2009 | Eljer Aqua-Saver Toilet Actuator -...
Home Logo
702 people viewed this question
Top Aqua Brass Home Experts
john h
Tom Chichester
Are you an Aqua Brass Home Expert? Answer questions, earn points and help others
