Question about Radio Communications
Ground wires 94 w900l 3406c cat ,seem to have a ground problem found 3 ground wires so far is there a main ground that in missing ,buzz sound thru cb radio when i turn on headlight switch ,anysugestions
  • Mitchell Cathey
    Mitchell Cathey May 11, 2010
    Can you describe the location of the wires you did manage to find?
    Also, with the sound, does the buzz noise happen while the radio is off? Does it happen if the key is not in the ignition when turning on the headlights?
    -Mitchell
Communicomm
  • 90 Answers
SOURCE: wiring a midland 78/999 cb radio microphone
Pin 1 = white
Pin 2 = shield
Pin 3 = black
Pin 4 = red
Posted on Sep 29, 2008
Shuttle83
  • 1139 Answers
SOURCE: TRC520 CB wont power up
Hello, First of all you only have the Power wire Red, and the ground wire Black to connect for 12v DC to power the unit. If you memory power it is usually connected to a constant power source such as the cigarette lighter or continuous 12V dc powersupply off of the battery. These are the only connections that should be connected to provide power. Since the unit will not turn on I suspect that the CB's power supply and regulator have been blown. Another possible choice is that the radio was working and someone removed the antenna cable and the the RF power amplifier malfunctioned taking the power supply and regulator with it. To solve this problem, check the voltages on the wires before connecting them to the radio (these should be the 12 volt power off of the radio circuit, and the 12 volt power off of the continuous 12V connector (or the cigarette lighter). These voltages should read 12V. Connect the CB with it turned off and measure the voltages (should be 12V) Turn the radio on and check the voltages (should be a little less than 12V) If the radio does not come on then the internal power supply of the radio might be defective (In this case I would advise taking the CB to a qualified radio repair shop) I hope this helps Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Posted on Jun 11, 2009
tbirdfan1
  • 3051 Answers
SOURCE: With my CB I am getting feedback through the am fm radio speakers
Hello there:
the shielded coax rgu-45 series is probably the best one for this application also if you run the radio to a different fuse or u can also get a surpression filter that goes on the coax line I own a WL9000 KW. i had the same problem untill i got the filter installed at a loves truck stop in texas and no more problems since ok?
drive safe and best regards mike (warner transp.)
Posted on Aug 17, 2009
SOURCE: Wiring Johnson Microphone to cobra 29 CB Radio
Use trial and error systemathically. If still refuses to work, mike and radio aren't compatibles.
Posted on Nov 23, 2009
  • 29 Answers
SOURCE: On a Maxon MCB-30 cb radio, there are three wires.
Hello stud
The orange wire is for memory retention for the last channel you were on if the red wire loses power as in switched on and off with the car ignition just hook up the orange to a 12 volt source that is on all the time. By the way those are some neat little radios wish I had one.
Ray
Posted on Aug 23, 2010
Help...Extremely high swrs. Galaxy dx 44v twin tdin Wilson 2000 antenna's, custom new rg59 coax. Mounted on a 99 Kenworth W900L. Swr is near set mark. Good continuity, radio just back from shop for peak...
Measure out your coax in 3ft intervals. Like if you need 7ft use a 9ft length of coax. Also make sure your mirrors are grounded use a external swr meter as well, the internal swr on the galaxy could be off. .
Nov 13, 2014 | Radio Communications
I have a general lee cb with a 4-pin standard mic. the wires in my mic cord broke at the plug. does wnyone know how to wire this type of mic back and what color wires go to the correct pin?there are 6...
Here are the Pin outs for different mics that will work with your radio. If a wire is not listed then you cut it off. It's best to keep the wires as short as possible no longer than a half inch is suggested. Normally the Cobra pin out is standard for most radios.
Stock - 1- Shield (Ground) 2- Yellow (Audio) 3- Red (Transmit) 4- White (Receive)
Astatic - (4 wire) 1- Shield 2- White 3- Red 4- Black
Astatic - (6 wire) 1- Shield & Blue 2- White 3- Red 4- Black Yellow NC
Daiwa EM-500, Cobra, CA Series - 1- Shield & Black 2- Red 3- White 4- Blue
Galaxy DC-521S - (4 wire) 1- Shield 2- Yellow 3- Red 4- Black
Galaxy CB-660EI - 1- Shield & Black 2- White 3- Red 4- Blue
Sadelta - 1- Shield 2- White 3- Brown 4- Green
Turner - 1- Shield & Red 2- White 3- Blue 4- Black Yellow NC
Jul 12, 2011 | Magnum DeltaForce CB Radio
My radio seems to receive fine but people tell me my radio squeels up close but sounds fine a couple miles away?any ideas
make sure you have a good ground.. low SWR's, and minimum of 10ga or larger like 8ga wire to a main power source.
Dec 26, 2010 | Connex CX-4300HP CB Radio
I listen my self on my car sound system when i transmit
Sometimes theres no fix for this problem. Make sure your antenna is set for your car and the SWR is low. Then try to sheild your radio wires.If this doesn't work then you probably want be able to fix it.Like I tell my drivers use one at a time, just to much power in a small space.
May 11, 2010 | Midland 1001Z 40-Channels Base CB Radio
I am useing a em27 with power pack in my home and receiveing is all crackly but when use my other cb not connected to power pack everything is fine, please help
There is probably a loose ground wire inside the power pack. This would cause the cracking, buzzing, or hissing sound, as it is not getting a solid connection. Open it up and look inside for loose wires. If you have a soldering iron, you can heat up a few joints, to check for bad soldering joints on the board.
Hope this help out,
J.R.
Nov 04, 2009 | Midland 1001Z 40-Channels Base CB Radio
Noisy/buzz
Usally a ground loop isolator will fix that problem. It plugs into the RCA's between the radio and the amp.
Try to reground the amp in a different spot.
Or run a refrence ground from the deck to the amp next to the remote turn on wire. (still keep your main amp ground hooked up)
DO NOT run your power wire next to the RCA's, that will induce a field which in turn can cause that buzzing sound.
Jun 03, 2009 | Crate SPA1600 Power Amplifier - SPA Series...
Wiring diagram for a road king 56 4 pin mic
4pin roadking 56 wires came off need to know where they go 1 thru 4
Dec 01, 2008 | Magnum DeltaForce CB Radio
Mic wiring
Hello, In case you haven't found it yet, here is for a 2510/ which is a cousin of a radio.
1 - Modulation/ Audio/ White
2 - Ground/ Shield
3 - Transmit/ Red
4 - up button/ NC
5 - down button/ NC
Thats if the D104 is a 4 wire, Mechanic
Aug 30, 2008 | Cobra 18 WX ST 40-Channels Base CB Radio
Radio Communications Logo
46 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
